Help me on where to look for Halion sounds Please :-)
Discussion in 'alt.steinberg.cubase' started by Danny T, Feb 26, 2010.
  1. Danny T Guest
    Message Count:
    I've used cubase since about version 2 but I haven't ever dealt with
    ivst's or samplers. I always just use cubase to capture what I play or
    someone else's playing.
    OK, I was to branch out a bit. I have the sound set 1 for Halion that
    was free and I started messing with it. I'm a little impressed with
    what I can do with my midi drum set and the sounds there. I'd like to
    try out more things, especially piano and keyboard sound libraries but
    also everything else.
    Where do I look, what is good and what should I have to pay? Also, if
    there are any free libraries, I'd like to start there first.
    Thanks for the help - I'm a total newbie on this stuff
      • Advertising
  2. XODDI Guest
    Message Count:
    "Danny T" <> wrote in message
    news:...
    You can get the Halion sound set directly from Steinberg - it's free.
  3. Danny T Guest
    Message Count:
    > news:...
    I have the "sound set 1" but I'm sure there is more to have. Any
    recommendations?
    Thanks
  4. XODDI Guest
    Message Count:
    news:...
    > news:...
    >recommendations?
    >Thanks
    I only use it for utility sounds so I haven't looked for others - but I
    prowl kVr regularly and I haven't really heard of any.
      • Advertising
  5. Phil W Guest
    Message Count:
    "Danny T":
    Native Instruments has 2 free VSTi plug-ins, which also have stand-alone
    versions besides the plug-in versions. As you seem to be a piano/keyboard
    player/performer, this might come in handy for you, if you only want the
    sounds "live", but don´t need a sequencer host software taking up
    resources... ;-)
    The first one is called "Kore Player" and the second one "Kontakt Player".
    Both are available free and at least KorePlayer includes a sound set. In
    addition to that, free sound sets can be downloaded separately! Of course,
    you can also buy more sound sets, but there should be something usable in
    the free ones.
    NOTE: you need to register with NI to request the download links!
    http://www.native-instruments.com/#/en/products/?search=freeware
    It should at least be a good place for a start. If you don´t like the sounds
    in the free packages or can´t really use them for your purposes, you haven´t
    lost money, but only some time...
    Good luck and fun!
    Phil
  6. Danny T Guest
    Message Count:
    On Feb 28, 9:07 pm, "Phil W" <> wrote:
    > "Danny T":
    > sounds "live", but don t need a sequencer host software taking up
    > resources... ;-)
    > The first one is called "Kore Player" and the second one "Kontakt Player"..
    > the free ones.
    > It should at least be a good place for a start. If you don t like the sounds
    > in the free packages or can t really use them for your purposes, you haven t
    > Good luck and fun!
    > Phil
    Thanks for the link Phil. I'll go check that out right away. I
    actually had thoughts of good drum and percussion sounds bouncing
    around in my head. I think live would be a disaster for me. I have 3
    88 key boards anyway. I often use an electric drum kit to play parts
    with but the sounds don't rarely match my expectations. Rather then
    getting a real drum set re-recorded on the song, I thought I might mix
    and fiddle with the sounds I am using.
    I'm no newbie to recording- actually, worse, I'm old school and have a
    hard time fitting into the digital world. It would be easier if I was
    new to it.... its like a bad habit you have to break first, before you
    relearn.
    Thanks again
    Danny
      • Advertising
Share This Page
