help needed importing video file / track
Discussion in 'alt.steinberg.cubase' started by randall_o, Nov 28, 2009.
  1. randall_o Guest
    Message Count:
    Cubase 5, 64 bit version, Vista Premium, quad core, 8GB ram. I just
    can not figure out how to get a video file to import and play in
    Cubase, very frustrating. I have read the instructions here:
    http://www.soundonsound.com/sos/nov05/articles/cubasetech.htm
    but I just can not get a video file to import and play no matter what
    I try, Cubase keeps giving me an error that it can not play it. Tried
    rendering (from Sony vegas) an avi file with Cinepak, mpg with Cinepak
    codec, nothing seems to give me a video file that will open and play
    in Cubase. Any ideas? Help greatly appreciated. What is the fricken
    secret to getting a video file on a track in Cubase and have it play,
    and also play in a video player window (F8)? I did configure the
    Devices: Video: Playback (only options tehre are DirectShow Video and
    Video for Windows; no option there for Quicktime playback).
    randall
      • Advertising
  2. randall_o Guest
    Message Count:
    >  randall
    Solved! (somewhat). The link in my original post was to an article
    that said the Microsoft Video 1 codec did not work with Cubase. But
    then I just found this forum post that says that the MS Video 1 coded
    solved the problem, worked!
    http://www.cubase.net/phpbb2/viewtopic.php?p=810292&sid=01726acf15d732f272aa4ca1f36a1325
    So i just rendered a video as an 640x480 AVI and used the Microsoft
    Video 1 codec and then opened it into a new Cubase 5 project and it
    loaded just fine, showed thumbnails, and when I pressed F8 I had a
    little window showing the video which would play as the Cubase
    timeline scrolled. Awesome. I even added a midi file to hear and see
    some music play while the video played.
    So I sort of solved the problem for now, but I will gratefully accept
    in other tips to making video import and viewing a better experience
    in Cubase. So frustrating when it did not work. Oh yeah, I had also
    gone to cubase.com but the site was worthless-- the links to the FAQ
    and Forum were not working, browser just spinning its wheels.
    randall
  3. Hueyduck Guest
    Message Count:
    > randall
    Hi Randall,
    Quicktime playback is available if a version of quicktime is installed
    on your system. Be it a free version.
    Have you tried with both renders (Dx and VfW)?
    What are the exact dimension of the files you tried to import? (in pixels)
    What color depth do they use?
    Can your reproduce the error with all the small video files you can find
    or are some of them accepted?
    I guess you have several video players on your system. Can you find one
    that refuses to play the problematic files?
    Huey
  4. Hueyduck Guest
    Message Count:
    > randall
    You could consider installing ffdshow.
    This is an open source multi-codec that will allow you to try several
    codecs.
    I use it in a 32bit environment, in order to make MJPG files to work
    within cubase.
    I chose s MJPG because it's a codec that does'nt rely on other frames to
    decode one. It makes video "scrubing" more easy, CPU wise. This is a
    personnal considerationand many will tell you the use other codecs with
    no problems.
    At least with ffdshow, you can try many of them ;)
    Anyway, MJPG from ffdshow works flawlessly whereas a commercial MJPG
    codec was clearly bugging cubase for no reason.
    again: I'm not useing a 64bit OS.
    But I think ffdshow is available for 64bits OS.
    Huey
      • Advertising
Share This Page
