Dear gurus, THE PROBLEM: Recycle2 can't complete a transfer to my sampler (K2000)! WHAT HAPPENS: Recycle detects the sampler, it starts to transmit, but then during '1 slices left' (right at the end), it pauses and then: "Midi communication failed! Please check your connections and settings, then try again!" Then it says 'cleaning up...', and then: "there may be keymaps and samples left in memory that are not assigned to any program" When I've tried to cancel the 'cleaning up', the samples ARE in the K2000, in a Keymap, but no program associated. So its like the scsi sample transfer is fine, but during the final step of making and naming a keymap and program, something 'midi' is supposed to happen and doesn't. I go back to <sampler settings>, and click 'verify, and it says: "Midi communication failed! Please check your connections and settings, then try again!" ?? I click 'verify' again: "Verify successful, Your sampler could be reached with these settings" And as I keep clicking it keeps saying everything is fine, until I actually try to transmit again. any ideas? Andy Ps: I'm using: K2000(v3.54), midex3 USB midi interface (latest drivers, works perfectly w Cubase) WinXP
