Help using ME1 as sole sound source for PC Comp Midi files
Discussion in 'alt.music.synth.kurzweil' started by user@satx.rr.com, Aug 8, 2004.
  1. Guest
    Message Count:
    I recently purchased an ME1 that I was hoping to use as the sound
    source to play miid files from my PC. I use Voyetra Record Producer.
    Here's the problem. When I send the midi signal from my PC to the
    ME1, the instruments seem to get played all wrong. Specifically, the
    drum track triggers a piano-type sound and the other tracks also sound
    different than their intended instrument. This occur for the 100 or
    so midi files I have. This problem does not occur when using the
    sound card as the sound source.
    Is there a way to set up the ME1 to play the "correct" instruments as
    indicated by the midi file or do I have to do this manually for each
    file? Any advice/opinions would be greatly appreciated. Thanks.
    Ohms
      • Advertising
  2. Michael Houston Guest
    Message Count:
    Well, this may or may not help. Let me explain:
    Your sound card is undoubtedly a General MIDI device with GM voice
    assignments, and the ME1 isn't. So when you send it GM tracks it
    plays the right notes but the wrong sounds, since the voice assignment
    numbers are different.
    There MAY be a way to put the ME1 in GM mode, which would be the
    quick-n-easy way to fix it, but you'd have to check your manual to
    see. Otherwise you'll need to re-assign voice numbers.
    Hope that helps.
    Later,
    Michael Houston
    >Ohms
    Michael Houston
    musicianmike at cox dott net (you know what to do)
      • Advertising
Share This Page
