Cubase Studio 4 for Windows. I've got a dry VST instrument track set up sent to an FX track with a delay on insert. (example only) Is there a setting that I can use to export only the wet output of the FX channel? I want to do bad things to it. Currently I am exporting a wet track using the effects as an insert on the instrument track, setting them to full wet, and then changing them back to full dry and recording the instrument in a separate pass. I think I am missing something.
XODDI a écrit : > Cubase Studio 4 for Windows. - Hi there - > > I've got a dry VST instrument track set up sent to an FX track with a > delay on insert. (example only) > > Is there a setting that I can use to export only the wet output of the > FX channel? I want to do bad things to it. - If I understood what you mean to do: On the track of wich you want to record only the wet signal, set your effect send to "pre" instead of the default "post" setting. This should route the signal before its level is modified by the fader. Once you've done that, you just have to pull the channel fader al the way down and bounce the master channel. You will only have the wet signal of the muted channel. Don't know cubase 4 though. Huey
XODDI schreef: > Cubase Studio 4 for Windows. > > I've got a dry VST instrument track set up sent to an FX track with a > delay on insert. (example only) > > Is there a setting that I can use to export only the wet output of the > FX channel? I want to do bad things to it. > > Currently I am exporting a wet track using the effects as an insert on > the instrument track, setting them to full wet, and then changing them > back to full dry and recording the instrument in a separate pass. > > I think I am missing something. I believe the following should work. In the Connections setting, create a separate output bus. No matter if you have only one physical stereo output pair, just add a bus and name it something like Tumbolia. Now you can set the output of the FX channel to "Tumbolia". In the Export Audio dialog, select "Tumbolia" as the output to be exported. Hope this helps (and works), Jos. -- Ardis Park Music www.ardispark.nl
"Jos Geluk": > XODDI schreef: >> Cubase Studio 4 for Windows. >> >> I've got a dry VST instrument track set up sent to an FX track with a >> delay on insert. (example only) >> >> Is there a setting that I can use to export only the wet output of >> the FX channel? I want to do bad things to it. >> >> Currently I am exporting a wet track using the effects as an insert >> on the instrument track, setting them to full wet, and then changing >> them back to full dry and recording the instrument in a separate >> pass. I think I am missing something. > > I believe the following should work. > In the Connections setting, create a separate output bus. No matter if > you have only one physical stereo output pair, just add a bus and name > it something like Tumbolia. Now you can set the output of the FX > channel to "Tumbolia". In the Export Audio dialog, select "Tumbolia" > as the output to be exported. > > Hope this helps (and works), Or go the easier route and select the fx channel als source in the audio export window. ;-)
Phil W schreef: > "Jos Geluk": >> XODDI schreef: >>> Cubase Studio 4 for Windows. >>> >>> I've got a dry VST instrument track set up sent to an FX track with a >>> delay on insert. (example only) >>> >>> Is there a setting that I can use to export only the wet output of >>> the FX channel? I want to do bad things to it. >>> >>> Currently I am exporting a wet track using the effects as an insert >>> on the instrument track, setting them to full wet, and then changing >>> them back to full dry and recording the instrument in a separate >>> pass. I think I am missing something. >> I believe the following should work. >> In the Connections setting, create a separate output bus. No matter if >> you have only one physical stereo output pair, just add a bus and name >> it something like Tumbolia. Now you can set the output of the FX >> channel to "Tumbolia". In the Export Audio dialog, select "Tumbolia" >> as the output to be exported. >> >> Hope this helps (and works), > > Or go the easier route and select the fx channel als source in the audio > export window. ;-) <facepalm> yeah, that would work too. -- Ardis Park Music www.ardispark.nl
