How I repaired my Fatar Studiologic SL-880
Discussion in 'cakewalk.audio' started by Malachi, Nov 21, 2006.
  1. Malachi Guest
    Message Count:
    Which is an 88 note hammer action MIDI controller, and basically nothin'
    else.
    Here's what the problem was: all of a sudden, certain notes sounded really
    weak and quiet (the unit wasn't transmitting sufficient velocity to sound
    the note properly), while other notes would only sound if you played the key
    very gently. If you hit the note too hard, no data was transmitted.
    Upon opening the case, which conveniently hinges upwards like the hood of a
    car, you find that this unit is basically a small motherboard, a couple of
    pots for the pitch and modulation wheels and a big honkin key unit. There
    are relatively few connections.
    I started by cleaning the ribbon connectors. Didn't help.
    Then I pulled the MOBO out and checked for bad connections or solider
    joints. Didn't see anything.
    Then I unbolted the key bank from the bottom of the case and flipped it
    over. Two more ribbon connections to clean. Again, that wasn't it.
    Then I removed six brackets from the bottom of the key bank and unscrewed
    the circuit boards that contain the velocity and on/off sensors. These
    consist of a bank of 88 rubber boots with little carbon dots inside to close
    the circuit on the surface contacts on the pc board. Crude, but effective.
    I pulled all the little silicone rubber booties off of the pc board and
    cleaned the contact surfaces on the pc board with iso alcohol on a q-tip.
    This is the point where you tell yourself, "Either I'm going to fix this
    thing and feel smug all afternoon, or I have just given myself a reason to
    go to Guitar Center with a stupid look on my face."
    I likewise cleaned the small black contact dots in the rubber boots, let
    them dry and reinstalled them on the pc boards.
    Reinstalled the pc boards on the key bank.
    Reinstalled the key bank and reconnected the ribbon cables.
    Screwed the whole mess back together.
    Plug in. Turn on interface. Open a VST synth.
    Pray.
    Play.
    It worked!
    According to what I've seen on Google, this is a common problem with this
    unit. I have to conclude that it is very sensitive to humidity and that
    this causes poor contact problems with the surface mounted contacts on the
    pc boards underneath the key bank. It's a relatively low-skill-level
    maintenance task, but it's a royal pain-in-the-arse to do because it
    involves removing and re-installing something like 20-30 screws in the
    process. Plus the silicone boots for the contacts are much easier to remove
    from the pc board than they are to reinstall.
    This is the only complaint I have about this unit. It has the most
    realistic piano feel of any controller I've tried and the only thing I've
    seen that seems similar is on some Yamaha synths like the S-90.
    Worth the effort, IMHO.
    malachi
      • Advertising
  2. Orangefreak Guest
    Message Count:
    "Malachi" <> blatted:
    >else.
    >Pray.
    >Play.
    >It worked!
    >malachi
    I did the same thing successfully purely on instinct (no research) on
    a cheaper Fatar. Scary but effective!
  3. Malachi Guest
    Message Count:
    <Orangefreak> wrote in message
    news:...
    >>else.
    What's kinda cool is that the thing seems to be engineered to allow easy
    access to the insides for routine maintenance. This could also be evidence
    of a vote of no-confidence by the designers, though.
    m
  4. Andre Lefebvre Guest
    Message Count:
    pray?? so prayer DOES work, if you work at it, uh...
    :0)
    andre
    "Malachi" <> wrote in message
    news:L7G8h.8790$...
    > else.
    > really weak and quiet (the unit wasn't transmitting sufficient velocity to
    > sound the note properly), while other notes would only sound if you played
    > the key very gently. If you hit the note too hard, no data was
    > transmitted.
    > a car, you find that this unit is basically a small motherboard, a couple
    > of pots for the pitch and modulation wheels and a big honkin key unit.
    > There are relatively few connections.
    > close the circuit on the surface contacts on the pc board. Crude, but
    > effective.
    > Pray.
    > Play.
    > It worked!
    > remove from the pc board than they are to reinstall.
    > malachi
      • Advertising
  5. Malachi Guest
    Message Count:
    "Andre Lefebvre" <> wrote in message
    news:R2H8h.344662$5R2.270608@pd7urf3no...
    > :0)
    > andre
    > news:L7G8h.8790$...
    I learned about the power of prayer when I was trying to get my first DAW to
    work right.
    Later I was informed that it's considered rude and impious to swear while
    praying.
    It worked, though.
    malachi
  6. Max Arwood Guest
    Message Count:
    Glad you got it fixed. I was installing some RPG ceiling stuff earlier this
    year and POW. One fell on my K2500. It has the same velocity sensors as
    the Fatar. I had to replace 1 section of the silicon boots. One of the
    sensors was damaged. Kurzweil was out of the part (they said it would be on
    backorder for about 4 months). Got one from Fatar. Seems to be working so
    far.
    Max Arwood
    news:NhG8h.8794$...
    > news:...
    >>>else.
    > evidence of a vote of no-confidence by the designers, though.
    > m
  7. Malachi Guest
    Message Count:
    "Max Arwood" <> wrote in message
    news:elH8h.8811$...
    > this year and POW. One fell on my K2500.
    I'll bet that was a four-letter moment.
    m
  8. Nil Guest
    Message Count:
    On 21 Nov 2006, "Malachi" <> wrote
    in cakewalk.audio:
    > allow easy access to the insides for routine maintenance. This
    > could also be evidence of a vote of no-confidence by the
    > designers, though.
    This last summer, a mic stand tipped over and fell on my Roand JV-30
    keyboard, snapping one of the keys in half. I opened the unit up
    discovered it came apart in about 3 units, and that the keys were
    fairly easy to remove. Looked easy to fix, so I called Roland, and they
    said they'd sell me a key for only, like 5 dollars (plus $10 shipping,
    of course.) The key arrived in a couple of weeks, but it about a month
    before I had time to install it. Putting the new key was pretty
    simple... but then I found I could not for the life of me remember how
    the 3 big assemblies fit together! They had come apart very easily,
    without force, but now nothing seemed to want to come together without
    major gnashing of plasic and metal. I didn't want to force it, and I
    finally got discouraged and left the parts sitting in the closet for
    several more weeks. It reminded me that I had neglected to do what I
    already know I should... draw a diagram or take some pictures.
    I eventually needed to use it, and gave it another crack. I finally
    managed to get them together and now it works, mostly, except that the
    modulation stick only works to one side now. Only a few screws left
    over. I probably should have taken it to a dealer and paid the 30 or 40
    bucks and saved myself a heap of aggravation.
    If it breaks again, I expect I'll try to fix it myself again.
  9. Dave (Mod Bod) Modisette Guest
    Message Count:
    > else.
    > Pray.
    > Play.
    > It worked!
    > malachi
    Malachi,
    When you had it open, did you notice if there was anything like an
    internal battery that kept a bit of current to the memory? I've got a
    Studiologic that will reset itself back to the 00 preset even when the
    power supply is on. I've wondered if it could be a bad battery inside.
    Dave Modisette
    http://web.tampabay.rr.com/cmodiset/webpage/dave_modisette.htm
  10. Malachi Guest
    Message Count:
    "Dave (Mod Bod) Modisette" <> wrote in message
    news:EiL8h.8163$...
    > Malachi,
    > Dave Modisette
    Dave,
    Now that you mention it, no I didn't see any coin batteries on the mobo or
    anywhere else inside the case.
    Maybe some kind of flash/static memory in there, or maybe we just have to,
    in prehistoric fashion, reenter your favorite settings each time you turn
    the beastie on.
    m
      • Advertising
Share This Page
