how to connect/route the midi out put to audio input (sx3)
Discussion in 'alt.steinberg.cubase' started by attaboy, Oct 2, 2009.
  1. attaboy Guest
    Message Count:
    thanks for the kind previous replies, but I still can't figure it out
    when I tried to route the midi output to the audio input. I am using
    a usb midi interface connects to a keyboard, so looks like there is no
    physical output that I can use to hook up the audio input. so I do it
    within the program's interface? such as using the mixer, device set
    up, vst connection? and on the midi output, its alread set to GM map
    in order to have the instrument patch, so where do I set the midi
    output, and how to hook up to the audio input? thanks in advance for
    your help
      • Advertising
  2. Gerd-Ulrich Meyer Guest
    Message Count:
    Hallo,
    it seems to me that you are still puzzled about the differences between
    MIDI and Audio. Is that the case?
    But regardless of wether or not...you have connected your MIDI-Keyboard
    with a USB-MIDI-Interface. So this connection is still MIDI-Data. Inside
    the Keyboard, the MIDI-Data are "translated" into audible sounds. So you
    have to find a port (for example a LINE-OUT or something like that) at
    your Keyboard where you can pick off these sounds. From there then you
    make a connection to your AUDIO-IN at the PC. So you can then record
    your played MIDI-Sounds.
    I hope i understood your problem correctly!
    Greetings
    Gerd-Ulrich Meyer
  3. Hueyduck Guest
    Message Count:
    Yes there is: the audio outputs of your keyboard.
    I'm sorry tro insist, but it still seems to me like you think that midi
    is sound. *It doesnot*.
    Please tell us exactly:
    - is it your keyboard that is playing the sounds that you want to record?
    - if it is: hook up you *keyboard audio output* to anything that ends up
    *in a physical audio input of your PC soundcard*. Then activate in
    cubase the audio channel corresponding to the latter physical audio
    input of the audiocard.
    Create an, audio track wich has this activated channel(s) as input.
    Record on this audio track while your midi tracks are sending their midi
    stuff to the keyboar. There your have your auydio recording of your midi
    tracks.
    If I want to record you shouting "Ouch!", I will have to put my
    microphone in front of your mouth, not in front of the foot of yours
    that I might stomp.
    The foot stomping is the midi message. It is made in order to produce a
    certain sound. But it doesn't produce the sound itself.
    Your mouth is the audio output of the keyboard.
    (sorry for the metaphore).
    Huey
  4. Guest
    Message Count:
    On Oct 2, 7:21 pm, Hueyduck <> wrote:
    > attaboy a écrit :> thanks for the kind previous replies, but I still can't figure it out
    > tracks.
    > that I might stomp.
    > Huey
    one of the nicest midi analogies I ever heard!!!..... so practical it
    should be made into a picture board...:)))))
  5. Hueyduck Guest
    Message Count:
    >> that I might stomp.
    >> Huey
    Yes, shouldn't it ;-)
    One could even unfold the metaphore to extend it to velocity.
    Or to understand that any controller can be assigned to any parameter,
    according tho how the midi device is programmed.
    For instance, if your midi device is a masochist person, it is
    programmed to eruct pleasure moans when his foot is stomped. Same midi
    message, but different result.
    There's a concept here.
      • Advertising
Share This Page
