How to convert WMA to MP3 http://www.softe.net/eufony_help/convert-wma-mp3.php Windows Media series includes formats like WMA (Windows Media Audio), WMV (Windows Media Video) and ASF (Advanced Systems Format). What's the difference between the ASF, WMV and WMA? ASF could contain audio only or both audio and video stream. It could be encoded by a variety of different codecs just like an AVI file. WMV contains both audio and video compressed with the Windows Media Audio and Video codecs. WMA contains audio compressed with one of the Windows Media Audio codecs. If you have lots of music in WMA (Windows Media Audio) format (e.g. a ton of CDs that you've ripped with Windows Media Player, they are always saved as WMA) but your MP3 player works with MP3 only, or certain corrupted WMA files causes seeking problem, you will need to convert WMA files to MP3. Eufony supports WMA files with sampling rates as below: 8000hz, 11025hz, 16000hz, 22025hz, 32000hz, 44100hz, 48000hz Follow the steps below to convert WMA files to MP3. Please be aware Eufony cannot convert DRM protected WMA files. Converting WMA to MP3 using Eufony WMA MP3 Converter http://www.softe.net/audio_converter.php After launch Eufony, In the folders pane, click on the folder contains WMA files you want to convert to MP3. WMA files should be highlighted in violet, if not, they could be probably be DRM protected ones. In the file list pane, select one or more WMA files. Right click on the selected WMA files to bring up the context menu and select Convert. In the Audio Format Conversion window, select MP3 from the Output- >Format list. If you want to change the output quality, select the Custom radio button. (optional) If you want to change the destination folder for MP3, click on the Browse icon button to change. (optional) Click Convert to start converting.
"music-fan" <> wrote in message news:... > How to convert WMA to MP3 > http://www.softe.net/eufony_help/convert-wma-mp3.php I need a convertor program that will convert bad music into good music. Ya got one of those?
On Sun, 4 Oct 2009 16:31:03 -0400, "XODDI" <> wrote: > >"music-fan" <> wrote in message >news:... >> How to convert WMA to MP3 >> http://www.softe.net/eufony_help/convert-wma-mp3.php > >I need a convertor program that will convert bad music into good music. > >Ya got one of those? I'd buy a handful of those! Use one in every car radio.
