How to deal with a "sustain" cc that records 128 different values?
Discussion in 'alt.steinberg.cubase' started by Hueyduck, Jul 10, 2009.
  1. Hueyduck Guest
    Message Count:
    Hi,
    Something strange is happenning.
    I record a piano part in cabase SX1 using a Yamaha electronic piano
    (CP33) along with the sustain pedal that was given with it.
    CC64 (sustain)messages should be sent as "on" or "off" (zero or 127, I
    guess).
    I just discovered that my pedal was actually sending 128 different
    values according to the position of my foot. It means that it acts like
    an expression pedal. The consequence is that cubase records several
    messages each time I move my foot.
    This is not usefull at all.
    How would you deal with this?
    There is no switch on my pedal (like sustain/expression) and it is
    plugged in the right hole of my CP33.
    Thx for your help.
    Huey
      • Advertising
  2. SODDI Guest
    Message Count:
    "Hueyduck" <> wrote in message
    news:4a57741b$0$3584$...
    > Hi,
    > I record a piano part in cabase SX1 using a Yamaha electronic piano (CP33)
    > guess).
    > I just discovered that my pedal was actually sending 128 different values
    > according to the position of my foot. It means that it acts like an
    > expression pedal. The consequence is that cubase records several messages
    > There is no switch on my pedal (like sustain/expression) and it is plugged
    > Thx for your help.
    Check your assigned CC numbers. One of them may have been changed.
    Find that big MIDI CC chart, I've posted a link to it somewhere in this
    group.
  3. Hueyduck Guest
    Message Count:
    >> Hi,
    >> guess).
    >> like an expression pedal. The consequence is that cubase records
    >> several messages each time I move my foot.
    >> Thx for your help.
    Thx for your answer.
    I have to be more precise , I think.
    When I press my "sustain pedal", connected to my e-piano,
    Cubase clearly receives 128 different values according to the position
    of my foot. I can see it in the event list. First question: how could a
    sustain pedal transmit more than two values? Maybe it is normal in "high
    quality looking" pedals (those who actually look like piano pedals).
    Let's says I just pressed the pedal , and the event list shows that I
    recorded values as follow: 0-16-40-72-104-127.
    *but*, cubase records and plays this signal as "CC 64" ("sustain", so
    that's normal), so when I open the piano roll, I can see that "cc64"
    shows only "0" or "127" drawn values , but more often than necessary. As
    if I had pressed the pedal several times in a fraction of a second.
    > group.
    I googled the group, but haven't found it yet.
    Is this chart something I have to find within cubase settings?
    After I have explained more correctly my problem, do you feel that this
    chart could still be any help?
    Thx again.
    Huey
  4. Swanny Guest
    Message Count:
    >>> Hi,
    >>> I guess).
    >>> Thx for your help.
    >> group.
    > Thx again.
    > Huey
    You could use the logical editor to set the values to either 0 or 127
    depending on a threshold value. Then you can use 'remove duplicates' to
    eliminate the extra CC's.
    Otherwise, for recording, you could use the Input Transformer to modify
    the incoming CC's to be one of two values (0 or 127).
      • Advertising
  5. SODDI Guest
    Message Count:
    news:4a59abd4$0$27782$...
    >>> Hi,
    >>> guess).
    >>> Thx for your help.
    > Cubase clearly receives 128 different values according to the position of
    > that's normal), so when I open the piano roll, I can see that "cc64" shows
    > only "0" or "127" drawn values , but more often than necessary. As if I
    > > group.
    Here:
    http://www.midi.org/techspecs/gm.php
    and here (table 3):
    http://www.midi.org/techspecs/midimessages.php
  6. SODDI Guest
    Message Count:
    >>> Hi,
    >>> guess).
    >>> Thx for your help.
    > > group.
    > Thx again.
    > Huey
    According to the MIDI CC spec, CC 64 is Damper Pedal, with a (value) 63 off,
    64 on.
    Try controller 66.
  7. Hueyduck Guest
    Message Count:
    > off, 64 on.
    > Try controller 66.
    Thank you for the links to the charts.
    As for the CC number , I have no doubt about the fact that #64 is the
    goosd number.
    What I call, maybe improperly, the "sustain pedal" is what the chart
    calls "hold pedal".
    Huey
  8. Jos Geluk Guest
    Message Count:
    Hueyduck schreef:
    > Hi,
    > guess).
    In addition to what others have said, the solution may actually be very
    simple. The pedal SHOULD only send values 0 and 127. On my pedal, there
    is a hardware switch that can be set to "Continuous" and "Switch". For
    sustain, I set it to "Switch". For volume etc. you would want it set to
    "Continuous". It is a Roland pedal, I can't find a model number.
    HTH
    Jos.
  9. Laurence Payne Guest
    Message Count:
    On Fri, 17 Jul 2009 09:56:05 +0200, Jos Geluk <>
    >> guess).
    A glance at the online manual reveals that the CP33 is supplied with a
    FC3 pedal which produces continuous data. This enables
    "half-pedaling" effects. Good for realistic piano playing with the
    internal sounds, less useful as a MIDI sustain controller.
    We are also told a FC4 or FC5 pedal may be used instead. These are
    simple on/off switches. Presumably they would trigger the simple
    Controller 64 data most instruments expect. You don't have to buy
    the Yamaha model - any normally-closed footswitch will do.
    The OP says the continuous data is "not useful at all". Is there a
    particular instrument that is responding badly to the continuous data?
    I think it is fairly standard that response to Controller 64 will be
    Off for values 0-64, On for 65-127. This may not be a practical
    problem at all.
    CubaseFAQ page: http://www.laurencepayne.co.uk/CubaseFAQ.htm
  10. Hueyduck Guest
    Message Count:
    Thanks JPs. Like I said , there is no switch on my pedal, unluckily.
    But your are right saying that my problem comes from the pedal.
  11. Hueyduck Guest
    Message Count:
    Of course, there are never any info about the accessories in the
    manuals, usually. I did'nt bother look at the CP33 manual. So I'm a bit
    ashamed :)
    You know why I did'nt bother?
    because when I bought this e-piano, I spent over 1500 euros thought I
    clearly stated that I was aiming at something like 1000 euro max.
    When I was about to make up my mind, the seller told me he could throw
    a little bonus with the keyboard. I asked for an expression pedal and
    (read carefully): the boss of the shop refused! I could have anyhting
    that would not be useful to me, anyhting but an expression pedal.
    I said " alright, then, deal with your kharma the way you want ..."
    But the one thing I was sure of is that I hadn't got an expression pedal.
    That will teach me not to believe humans but to... read my manuals.
    Do you know Murphy's law?
    I had been having a simple switch for 7 years until I gave it a few
    weeks ago to a friend of mine who is learning chords on his small keyboard.
    I showed him some chords on my piano and gave him my old switch pedal
    so that he could train at his home.
    sh...
    > problem at all.
    It is too when you have to edit the controller in a piano take :)
    Erasing a simple on-off signal is easy, but when there are dozens of
    messages , it gets difficult to be precise enough when erasing cc64.
    Anyway, thanks for finding this piece of info.
    Huey
  12. Laurence Payne Guest
    Message Count:
    On Fri, 17 Jul 2009 12:52:28 +0200, Hueyduck <>
    >> problem at all.
    I'm thinking of a Logical Edit preset to delete all values of
    Controller 64 other than 64 and 65 ? Or maybe an input filter to do
    the same?
    But probably a new footswitch is the real answer.
  13. Hueyduck Guest
    Message Count:
    > the same?
    I think I'm going to work on an inpuit filter (I don't know yet how to
    do this, but I will read my manual, this time ;-)
    Exactly. I wanted an expression pedal: I already have it. So, why
    bother: I'll just get a nice sustain pedal and then I'lll have the best
    of 2 world.
    All for the best, then :)
    Huey
    PS: main thing to extract from this whole thread: the Yamaha CP33
    stage piano is delivered with an *expresssion* pedal, not a simple
    on/off sustain pedal. Don't ask for an expression pedal as bonus gift:
    you already have it ;-)
  14. Laurence Payne Guest
    Message Count:
    On Sat, 18 Jul 2009 11:32:26 +0200, Hueyduck <>
    Well, sort of. An expression pedal would have a longer throw, and
    wouldn't be spring loaded. This one would be most inconvenient as a
    volume control.
  15. Jos Geluk Guest
    Message Count:
    > volume control.
    Not always - I have played imitation-accordion on a keyboard using the
    pedal as a volume control. It takes some practicing, but you can emulate
    the swelling of the tone that way pretty well, the typical ebb and flow
    of the accordion. And for that it needs to be in the zero position after
    release.
    Jos.
    Ardis Park Music
    www.ardispark.nl
      • Advertising
Share This Page
