How to upgrade SX 1.0.6 to record 8 tracks simultaneously
Discussion in 'alt.steinberg.cubase' started by Prospero Spooks, Jan 29, 2010.
  1. Prospero Spooks Guest
    Message Count:
    Greetings all!
    Long ago and far away I got Cubase SX 1.0.6, installed it on my
    Powerbook, and made a bunch of projects. I was really pretty happy with
    that version of Cubase, but I got away from music and the projects sat
    unused for years
    Now I'm in a new "band" and so dusted off Cubase and began recording
    our rehearsals, live, on 2 tracks (through the laptop's stereo Sound In
    port). I wanted to record more live tracks, like 8, so I got an Alesis
    Multimix12 firewire (for a great price, used, but WITHOUT the bundled
    LE disk) and hooked it up. SX 1.0.6 is working fine with it, but it
    only lets me record 4 tracks at once.
    I'd like to get another version of Cubase that'll record 8 tracks. With
    my pauper's budget I can afford "LE 1.something" from eBay, or
    "Essential 5". I can't seem to find SX 1 in any comparison charts, nor
    do I see any downloadable upgrades for it.
    Would I lose (or gain) a lot going from SX 1.0.6 to LE 1 (using
    1.0.10.110 upgrade) or Essential 5?
    (OR) Are there any free/cheap recording-only packages for MacOS X 10.4,
    like the good-looking but Windows-only Kristal
    (http://kreatives.org/kristal)?
    Thanks very much for any light you can shed on these matters!
    Prospero
    "Experience is a good teacher, but her fees are very high." -- W.R. Inge
      • Advertising
  2. Hueyduck Guest
    Message Count:
    Hi, Prospero.
    I have the same version as yours.
    First, you might check that this restriction really exists.
    I don't not think it does.
    Please describe to us the manipulations and results that lead you to
    think that Cubase 1.0.6 could not record more than 4 tracks at once.
    Huey
  3. Laurence Payne Guest
    Message Count:
    On Sat, 30 Jan 2010 12:30:19 +0100, Hueyduck <>
    >Hi, Prospero.
    >Huey
    Maybe you have only 4 input channels set up. I don't know the exact
    geography of Cubase 1.0.6. But can you find the page where you set up
    input and output busses?
    CubaseFAQ page: http://www.laurencepayne.co.uk/CubaseFAQ.htm
  4. Hueyduck Guest
    Message Count:
    Peripherals/VST inputs
    You should see 3 columns:
    Left column is "port". You should have listed all the physical inputs of
    your audio card.
    Center column is an on/off button column only (active/not active)
    And right column is the corresponding names you gave to your physical
    inputs. By defaults, they are "input 1", "Input 2" and so on.
    Propsero, can you tell us what you see in your panel?
    If you have only 4 channels activated here, you cannot record more than
    4 channels (since only 4 channels will be available in each new audio
    track setting).
    Activating more channels (if physically available, of course), should
    enable you to make what you want to do.
    Huey
  5. Prospero Spooks Guest
    Message Count:
    In article <4b6417a3$0$23887$>, Hueyduck
    > Hi, Prospero.
    > Huey
    Well thanks; what a revelation!
    I've set up a new project from scratch and do indeed have all 14 tracks
    recording simultaneously!
    Apparently like Chico Marx in Duck Soup "I didditt wrong" on my first
    attempt - I had Cubase seeing all the Multimix channels, and assigned
    them all to tracks, but when actually record-enabling the tracks, after
    I'd enabled 4, enabling a fifth would cause one of the first 4 to "go
    out". Cubase would only actually record-enable 4 at once.
    Somehow I was just ready to think this was a program limitiation,
    rather than my own incomptence I mean "unfamiliarity with the new
    setup".
    I followed a procedure like this: selected Devices / Device Setup / VST
    Multitrack and set ASIO Driver to my firewire mixer.
    Then I did Devices / VST Inputs and enabled all 7 pairs of inputs.
    Now when I create a project with 14 audio tracks and associate each
    track with one of the In's, I can record-enable all 14 at once. This is
    the same procedure I (thought I) followed before, so I guess I just
    screwed up somehow.
    Thanks so much for your responses, Huey and Laurence! If you have any
    further suggestions I'd be glad to hear them, but I (think I) have it
    (somewhat) together now.
    Prospero
    "Young man, in mathematics you don't understand things, you just get
    used to them." -- John von Neumann
      • Advertising
Share This Page
