Hyperthreading and Alesis Multimix Firewire
Discussion in 'cakewalk.audio' started by plantfinder@comcast.net, Jul 20, 2007.
  1. Guest
    Message Count:
    Alesis multimix firewire 8
    Pentium 4 3.4 ghz
    2 gig Ram
    After about 6 months of searching, I've finally found something that
    will allow my Alesis Multimix Firewire mixer to function (somewhat
    properly) as a sound card, which Alesis claims its be able to do.
    I was getting very frequent freezing of any application (Itunes)
    playing mp3 files during playback. It seemed any process that occurred
    in the foreground or background including Itunes simply shuffling to
    the next song would trigger a freeze. I also had some audio dropouts
    as well but the freezing issue was intolerable.
    I've tried every driver and tweak they recommended including buying a
    new firewire card and nothing worked. I was ready to junk it. I
    finally found out that disabling Hyperthreading greatly helps (but
    doesn't totally eliminate) this problem.
    I'm wondering how disabling the Hyperthreading might affect my pc
    performance? I think I might be noticing some slowing in some actions
    but I'm not sure. Also, is this an acceptable fix given the fact that
    I probably paid to have a processor with Hyperthreading capabilities?
    Finally, if anyone has any other suggestions I'd be grateful.
    Thanks
    Mike
    __________________
      • Advertising
  2. Sue Morton Guest
    Message Count:
    I'm not familiar with your particular card, so can't give you anything
    specific about it. Have you gotten back to the manufacturer regarding your
    improved but imperfect stability with hyperthreading off? Do they claim
    their drivers do not have problems with hyperthreading? If their drivers
    are not written for hyperthreaded systems you will have problems.
    Is it possible this has nothing to do with your soundcard... some pentiums
    had a problem with audio because of a flaw (I don't recall the issue now --
    normalization?) , some VST plugins were developed by a few folk to overcome
    this issue. Your pentium at 3.4ghz is probably newer than the flawed ones
    and wouldn't have this problem. Still can't hurt to verify that... Does
    your CPU 'peg out' when the 'freeze' happens with hyperthreading on?
    As far as turning hyperthreading off, whether that is good or bad depends on
    what programs you run and whether they really take advantage of
    hyperthreading. If this turns out to be a problem with the Alesis card, and
    you cannot afford to replace the card at this time, then although a PITA you
    can turn HT off for audio, and turn it back on for any programs that
    seriously take advantage of HT.
    My $0.02 USD, YMMV...
    Sue Morton
    <> wrote in message
    news:...
    > Pentium 4 3.4 ghz
    > 2 gig Ram
    > Thanks
    > Mike
    > __________________
  3. Glennbo Guest
    Message Count:
    In news:%M7oi.3252$ the killer robot
    "Sue Morton" <> grabbed the controls of the
    spaceship cakewalk.audio and pressed these buttons...
    > pentiums had a problem with audio because of a flaw (I don't recall
    > the issue now -- normalization?) ,
    De-normalization when P4s were new. That problem was due to the P4
    trying to do high precision floating point math as things got real quiet,
    like say a track with a guitar solo that only plays in the middle of the
    song. Any recorded parts of the track when the guitar wasn't playing
    could potentially put some plugins into a floating point frenzy, causing
    hiccups and sputtering.
    > a few folk to overcome this issue. Your pentium at 3.4ghz is probably
    > newer than the flawed ones and wouldn't have this problem. Still
    > can't hurt to verify that... Does your CPU 'peg out' when the
    Some older plugs can't deal or don't perform well with any multi-threaded
    environment. I ran my P4 with hyper threading disabled for most of it's
    life as my DAW, and it performed silky smooth. If I enabled HT, the CPU
    meter would swing back and forth wildly and some songs wouldn't even
    play. At the end of that machine's use as my DAW, I was running it with
    HT enabled, and actually getting a little bit better performance out of
    it that way, but I had either dumped or updated virtually all my plugins
    by then, and I am quite sure the problem was one of, or a combination of
    some of the old plugins I used to use.
    Remove YourHeadFromYourAss to Reply by email
    ________ ____
    / ____/ /__ ____ ____ / __ )____
    / / __/ / _ \/ __ \/ __ \/ __ / __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_____/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  4. Guest
    Message Count:
    The Alesis multimix is a mixer that functions as a soundcard (actually
    quite well when it works). via a firewire connection. The mixer is
    great, I have no problems recording multiple tracks in Sonar and the
    only issue I have with it is the freezing of mp3s during
    playback.Since it is suppose to function that way,I use it as a
    soundcard. I'm usually listening to Itunes while sitting at my pc
    I have been in constant contact with tech support since December to no
    avail. I was about to get rid of it when someone passed on the
    hyperthreading tip.
  5. kitekrazy Guest
    Message Count:
    > hyperthreading tip.
    HT is not that great for working with audio. My FW410 in ASIO would
    run at 7ms with HT. Without it it runs at 2.9ms.
    HT is great for working with video.
      • Advertising
Share This Page
