I need a super cheap sound modual - Ideas??
Discussion in 'alt.steinberg.cubase' started by Danny T, Sep 2, 2009.
  1. Danny T Guest
    Message Count:
    OK here's the deal. I need something sacrificial to leave on my
    sailboat. I want to run it with my maudio controller and it needs to
    be a low power consumption thing too. I'm taking some time off to go
    sailing and just need sounds. My latency on the computer makes it near
    impossible to play with any accuracy.
    Thanks for the ideas. ........... Oh, all I really need is one piano
    sound but other stuff would be fine too.
      • Advertising
  2. Jos Geluk Guest
    Message Count:
    I suppose you could pick up a used Roland JV-1010 for a song somewhere.
    Excuse the bad pun.
    Happy sailing,
    Jos.
    Ardis Park Music
    www.ardispark.nl
  3. Cyberserf Guest
    Message Count:
    You can pick up a used Roland U220 for under $100...perhaps with some
    extra pcm cards. Despite it's age, the onboard timbers are all very
    useable. Not the friendliest to edit, but once you get the logic, it
    does get easier.
    Cheers, CS
  4. Danny T Guest
    Message Count:
    > does get easier.
    > Cheers, CS
    WOW, both of those names are ancient memories. I had forgotten about
    both - thanks Jos and Cyber.
    I'll just look on ebay for one of those.
  5. Hueyduck Guest
    Message Count:
    If I might add: the U-220 had buttons that would age very poorly (as
    far as my experience with my U20 taught me).
    It might not be your first choice when buying a second hand expander.
    This said, the sounds were very usable, truly.
    huey
  6. Danny T Guest
    Message Count:
    > huey
    Any decent sound will do and I will likely through it away when the
    trip is over. I just need something small to put on a boat. Thanks
    again for the heads up
  7. Cyberserf Guest
    Message Count:
    > It might not be your first choice when buying a second hand  expander.ttery after a few years
    > huey
    I've heard that of the U20 (though IIRC, it was the keys not the
    control buttons that would go south), but my rackmount 220 is rock
    solid...resetting to factory was a chore (had to replace the battery),
    but everything works perfectly...picked it up for $65 Canadian with 2
    PCM cards (Woodwinds (6) and Latin Perc (2))...A couple of dials would
    have made cruising the menus easier than cycling with up and down
    arrow buttons, but once you get used to it, it isn't too bad. First
    choice...naw...but cheap as dirt..yeah!
    Cheers, CS
  8. Swanny Guest
    Message Count:
    > Excuse the bad pun.
    > Happy sailing,
    > Jos.
    Or an old Yamaha MU-80. 32 midi channels can be quite handy.
  9. Bas Guest
    Message Count:
    On Tue, 1 Sep 2009 16:03:24 -0700 (PDT), Danny T
    I have an old Roland MT-32 somewhere :)
    Or is that an antique by now?
  10. Danny T Guest
    Message Count:
    That would do fine if you want a chance to pawn it off on someone.
    They sucked but are perfect for what I want. Hell, and FB01 would work
    for my needs.....
  11. Bas Guest
    Message Count:
    On Thu, 3 Sep 2009 16:36:41 -0700 (PDT), Danny T
    >for my needs.....
    I am afraid the cost of mailing it would far exceed its worth :))))
  12. Danny T Guest
    Message Count:
    > >for my needs.....
    Where are you? What do you want for it?? If you do want to sell it,
    reply to me back channel and I'll give you a call. I have a fedex
    shipping account so I'd bet it would only cost me between 7-10 bucks.
  13. Bas Guest
    Message Count:
    On Fri, 4 Sep 2009 05:28:26 -0700 (PDT), Danny T
    >> >for my needs.....
    Holland here
  14. Danny T Guest
    Message Count:
    > >> >for my needs.....
    > Holland here
    How far can you throw?
    Thanks, you're right.
  15. stevel Guest
    Message Count:
    Have you tries ASIO4ALL as a cure for your latency issues? May not
    need the expander then.
    Steve
  16. Danny T Guest
    Message Count:
    > Steve
    I don't know what that is..... I'm good at the music but God forbid I
    ever have to reinstall anything :)
    As for the issue, I fixed it with buying a Yamaha p80 keyboard
    yesterday! Got it from a guy on CL for $200 so I'm happier then a
    tornado in a trailer park.
    Thanks
  17. Cyberserf Guest
    Message Count:
    > > Steve
    > Thanks
    Good show...the p80 (and p200) is a nice keyboard if, as you
    indicated, you primarily want the piano sounds...the harpsichord is
    nice too, but the bass sucks (IMHO).
    Happy sailing, CS
  18. Jos Geluk Guest
    Message Count:
    Well, congrats. But to be fair, I didn't realize you needed a keyboard
    as well on board, or I wouldn't have suggested a sound module.
    Have fun,
    Jos.
    Ardis Park Music
    www.ardispark.nl
  19. Danny T Guest
    Message Count:
    > > > Steve
    > > Thanks
    > Happy sailing, CS
    I have 3 bass guitars when I want a good bass sound so I'm good on
    that one :)
    YEs, I think I scored well on this acquisition. All I wanted was a
    practice piano and something small to take on the sailboat. Truth is,
    after having it out and playing it, I like it I don't mean it will
    replace my piano but I think I'll start dragging it off to gigs
    instead of my Roland RD300. I pretty much need a crane these days to
    lift the sucker and I like the action on this better. I have a Yamaha
    S08 too and that is light but driving it is a bit like driving a space
    shuttle. I don't know why companies have to cram so much stuff into
    one box that you need a PHD to make it work. I'm a musician for crying
    out loud. That means I don't like to study too much :)
  20. Danny T Guest
    Message Count:
    > Have fun,
    > Jos.
    > Ardis Park Musicwww.ardispark.nl
    You were right to suggest boxes because I suggested I use the
    controller. I was planning on using a M-Audio controller. The thing
    feels like crap so I'm much better off this way. I just got lucky when
    I found this.
    I appreciate your input just the same
      • Advertising
Share This Page
