I will never buy another product from Yellow Tools.
Discussion in 'cakewalk.audio' started by kitekrazy, May 3, 2010.
  1. kitekrazy Guest
    Message Count:
    Their C/R is very half assed. Worst I have ever seen. You get 3 codes.
    Here is what I've found that is flawed. If you enter the same Product
    code twice that means 2 authorizations are used up. That's messed up.
    Also once you add your response code, there is no record on their site
    in case you need to reinstall on the same system due to a crash or
    something. IK, NI have this for you and they also email your codes.
    Also you have to be careful because entering your codes a zero and an O
    are different characters where most authorizations either letter or
    number works.
    Their support is a web page where you have no clue or confirmation. Once
    again no reply from them. Even an automated response would be nice.
    This is my first and last experience with anything from Yellow Tools. I
    can't even post in their forums for help.
    I urge and recommend anyone to stay away from Yellow Tools for these
    reasons.
    1. No email response including product code and response code.
    2. E-license flawed. Same product code multiple times means
    authorizations used up. So if your same system crashed 4 times and had
    to reinstall your OS, then you have to contact them.
    3. You can only view your serial #s in your account. IK, NI, Cakewalk
    allow users to view serial # and response codes.
    Buyer be warned.
      • Advertising
  2. Glennbo Guest
    Message Count:
    In news:hrnh4d$br$-september.org the killer robot kitekrazy
    <> grabbed the controls of the spaceship
    cakewalk.audio and pressed these buttons...
    I have their demo installed, and never ever use it. It's just sucking up a
    gig or more of HD space. The free Proteus VX on the other hand, I use
    frequently, and it takes up way less space.
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  3. Ted Perlman Guest
    Message Count:
    <I urge and recommend anyone to stay away from Yellow Tools>
    Ditto!!!!! 1000x's Ditto.
    The WIBU key that they use is the CRAPPIEST protection device ever invented.
    It took my entire system down so bad I had to restore from an image file.
    The authorization process is STOOOOPID and unreliable.
    They have nice sounds and programs, but the hassle of installing and using
    is just not worth it. I was given an NFR (thank you Tom Sailor) of all the
    Yellow Tools programs, but after trying to install them I threw all the CD's
    in the trash.
    At some point in the future when Yelow Tools goes to either the iLok or
    eLicenser I will reconsider. But WIBU? Never again!
    Regards,
    Ted Perlman
    www.tedperlman.com
    www.myspace.com/tedperlman
    www.facebook.com/ted.perlman
  4. kitekrazy Guest
    Message Count:
    > in the trash.
    It was their elicenser I was bitching about. It generates a new code
    every time you open it up. The won't help for offline authorization.
    A dongle would be better than their eLicenser. I would welcome the iLok
    instead of their proprietary dongle.
    Some of their products still install the WIBU (Will it bust up my system)
    After all of my bitch I am thinking of buying YT Culture.
      • Advertising
Share This Page
