Ideas wanted (S5P) to eliminate repeatitive routing changes
Discussion in 'cakewalk.audio' started by Sue Morton, Nov 6, 2005.
  1. Sue Morton Guest
    Message Count:
    I am working on my annual creation of vocal practice CDs for my community
    Christmas choir, using Sonar with MIDI into DXi synths, and/or audio tracks.
    My target objective is creation of stereo recordings for CD, in which a
    specific vocal part (DXi synth track, or audio source track) is panned full
    left, and the remainder of tracks are panned full right. For example, if a
    project is SATB plus accompaniment, I will create four output recordings: a)
    Soprano is panned left and all other tracks right, b) Alto is the one panned
    left, while Soprano and all other tracks are panned right, c) Tenor panned
    left and others right, d) Bass panned left and others right. If there are
    solos that will be additional recordings for the soloists.
    My other objective is to keep the original tracks (specifically MIDI)
    feeding the end product (e.g. no bounce) so if I want to make any changes to
    the midi data I don't have to change anything else.
    I have been able to make this fairly easy to achieve, but it is repetitive.
    I have busses for solo (panned left), left (panned left), right (panned
    right), accomp (panned right), and main (panned center, all other busses
    come here). There are various plugs attached to each of these busses.
    To create an output stereo recording, I'll change the part's DXi or audio
    track to point to either "solo" or "left" buss as appropriate, point the
    rest to "right" buss (accomp always pointed to "accomp" buss), and export
    the audio. Then swap the part that points to the "left" buss, others going
    to "right", and repeat. Four times for SATB (more if there are solos).
    Then repeat the entire process for each song the choir is doing. :-(
    Since I have to go through the above steps once, it is of course not an
    issue as long as I only have to do it once. But usually I want to change
    something global to all recordings (plugs on busses, change a MIDI track,
    etc.) and then the above steps must all be repeated for the song.
    Is there a way to save 'presets' of routings? Would a CAL be useful for
    this? I think I'm stuck with the work, but thought I'd ask.
    I'm also open to ideas on how to acheive my target results by approaching
    this problem in a completely different way.
    Sorry for (typical) long post. And thanks as always for ideas,
    Sue Morton
      • Advertising
  2. BobF Guest
    Message Count:
    Sue - You aren't being ignored. I'm thinking this one through to see if I
    can come up with some good ideas for you.
  3. Glennbo Guest
    Message Count:
    In news:U_nbf.13625$ the killer robot
    "Sue Morton" <> grabbed the controls of the
    spaceship cakewalk.audio and pressed these buttons...
    > for this? I think I'm stuck with the work, but thought I'd ask.
    > approaching this problem in a completely different way.
    Are the tracks always laid out the same? I've taken whole songs and dumped
    them into another song's emptied skeleton before, to get things routed and
    assigned the way they were in the other song. IIRC, I loaded up the song I
    wanted to move to a different layout, selected all and then cut. Then I
    loaded up the song I wanted to use as a model, selected all and hit delete
    (which keeps from re-writing the paste buffer), then slected track one and
    did a paste.
    Remove YourHeadFromYourAss to Reply by email
    ________ ____
    / ____/ /__ ____ ____ / __ )____
    / / __/ / _ \/ __ \/ __ \/ __ / __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_____/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  4. Ricky Hunt Guest
    Message Count:
    "BobF" <> wrote in message
    news:32i9bfwt3v06$.15ukdohizuv4l$...
    >> tracks.
    Yeah, I was wanting to help too but my brain is just way too foggy this
    morning. I'll try to check back later.
      • Advertising
  5. Greg McGuirk Guest
    Message Count:
    Hi Sue-
    If I'm understanding what you're after (big if), would this help........?
    Setup a template with 4 buses and 20 tracks, like this:
    Make 3 Clone copies of the accompaniment track (less the SATB parts). Route
    the 4 accompaniment tracks to Bus 1, 2, 3, & 4. (Below I'm calling these
    trax 1 - 4). Make 3 Clone copies of each of the SATB parts, panning one
    Left (to its dedicated bus) & three Right, each routed to the remaining four
    buses. Your routing will look like this:
    Bus 1: Left = Sop1; Right = Alto1, Tenor1, Bass1 + trax 1
    Bus 2: Left = Alto2; Right = Sop2, Tenor2, Bass2 + trax 2
    Bus 3: Left = Tenor3; Right = Sop3, Alto3, Bass3 + trax 3
    Bus 4: Left = Bass4; Right = Sop4, Alto4, Tenor4 + trax 4
    Once you have the SATB parts ready, you clone them, drop them into the
    template. Highlight ALL tracks and you should be able to execute 1 export
    command (exporting from buses) to get the 4 stereo mixes. Use the same
    template for each song!
    I'm at home, so I'm not in front of Sonar to check my accuracy. I hope it
    helps & makes sense! :)
    regards,
    greg
    "Sue Morton" <> wrote in message
    news:U_nbf.13625$...
    >tracks.
    > full left, and the remainder of tracks are panned full right. For
    > example, if a project is SATB plus accompaniment, I will create four
    > output recordings: a) Soprano is panned left and all other tracks right,
    > b) Alto is the one panned left, while Soprano and all other tracks are
    > panned right, c) Tenor panned left and others right, d) Bass panned left
    > and others right. If there are solos that will be additional recordings
    > for the soloists.
    > to the midi data I don't have to change anything else.
    > repetitive. I have busses for solo (panned left), left (panned left),
    > right (panned right), accomp (panned right), and main (panned center, all
    > other busses come here). There are various plugs attached to each of
    > these busses.
    > going to "right", and repeat. Four times for SATB (more if there are
    > solos).
    > Sue Morton
  6. Sue Morton Guest
    Message Count:
    I have a template I set up, that has everything ready to go for the FIRST
    time through, so pasting in new MIDI tracks (yes, they are almost always the
    same layout - SATB) is a piece of cake.
    I think Greg has the (an) answer, better than what I'm doing... see that leg
    of this thread.
    Thanks for the reply,
    Sue Morton
    "Glennbo" <> wrote in message
    news:Xns9706839CB538CBrownShoesDontMakeIt@70.168.83.30...
    > dumped
    > I
    > did a paste.
    > ________ ____
  7. Sue Morton Guest
    Message Count:
    I'm fuzzy these days myself, I'm way way overcomitted right now (can someone
    arrange for 32 hours in a day, please?).
    Greg has got a good answer to my inquiry. Thanks Ricky,
    Sue Morton
    "Ricky Hunt" <> wrote in message
    news:smtbf.526149$_o.482701@attbi_s71...
    >>> community
    >>> tracks.
    >> I
  8. Sue Morton Guest
    Message Count:
    Yes, you understand me, thanks! I already have a template set up for the
    initial routing I'm using, it's a piece of cake to drop the midi tracks into
    that template. Changing to this kind of template should be fine.
    I'm trying it out right now. I see I have to clone all the DXi tracks as
    well as the MIDI tracks, each MIDI is routed to a DXi then the DXi is sent
    to the buss. (Too bad a DXi isn't just a characteristic of a MIDI track,
    instead of being a track in its own right.)
    Still, a template with this setup could prove to be better than what I'm
    doing. I'll continue to check it out. Thanks Greg!
    Sue Morton
    "Greg McGuirk" <> wrote in message
    news:...
    > Hi Sue-
    > Route the 4 accompaniment tracks to Bus 1, 2, 3, & 4. (Below I'm calling
    > these trax 1 - 4). Make 3 Clone copies of each of the SATB parts, panning
    > one Left (to its dedicated bus) & three Right, each routed to the
    > remaining four buses. Your routing will look like this:
    > regards,
    > greg
    >>tracks.
    >> for the soloists.
    >> these busses.
    >> solos).
    >> Sue Morton
  9. Greg McGuirk Guest
    Message Count:
    Is your DXi a multi-timbral / multi out instrument or do you have to use
    mulitple instances? the latter would be a bit of a bummer. Either way,
    I'll be anxious to hear how it works.
    greg
    news:MJybf.25094$...
    > into that template. Changing to this kind of template should be fine.
    > Sue Morton
    > news:...
    >> Hi Sue-
    >> panning one Left (to its dedicated bus) & three Right, each routed to the
    >> export command (exporting from buses) to get the 4 stereo mixes. Use the
    >> same template for each song!
    >> it helps & makes sense! :)
    >> regards,
    >> greg
    >>>tracks.
    >>> for the soloists.
    >>> changes to the midi data I don't have to change anything else.
    >>> all other busses come here). There are various plugs attached to each
    >>> of these busses.
    >>> audio track to point to either "solo" or "left" buss as appropriate,
    >>> point the rest to "right" buss (accomp always pointed to "accomp" buss),
    >>> and export the audio. Then swap the part that points to the "left"
    >>> buss, others going to "right", and repeat. Four times for SATB (more if
    >>> there are solos).
    >>> change something global to all recordings (plugs on busses, change a
    >>> MIDI track, etc.) and then the above steps must all be repeated for the
    >>> song.
    >>> Sue Morton
  10. Sue Morton Guest
    Message Count:
    I played a bit with the multiple-out feature of the DXi's a while back, at
    the time I didn't like it because of restrictions in how I could manipulate
    the output. But that was probably before the flexible buss routing was
    available. So my template currently has a single instance of a DXi to each
    MIDI track. But now I'm thinking I can use the multiple outs, so I will
    look at that!
    Thanks very much for the ideas.
    Sue Morton
    news:...
    > greg
  11. Sue Morton Guest
    Message Count:
    Thanks BobF! Greg posted a good idea, I have to work with it a little bit
    due to the way I use DXi's, but I might still end up better off than my
    current way of doing this.
    Ideas still welcome, though! Thanks much.
    Sue Morton
    >> tracks.
  12. BobF Guest
    Message Count:
    Sue,
    I've only done basic testing with this, but here's an idea ...
    Copy the .cwp file via explorer. For example, I used a basic project with
    a coupla' tracks and copied project.cwp to project_alt.cwp.
    I opened project_alt.cwp, added a bus, changed panning around and changed
    routing for one of the tracks to the new bus. I opened the original and
    all is as it was prior to making changes in the 'alt' version.
    So the result is two different "snapshots" of the project.
    If you perform track data edits, you *should* be able to copy/paste the
    modified events/clips between them (I'm pretty sure MIDI is stored in the
    ..cwp). This *might* be less work than redoing all of your routing/panning.
    Especially if you do this -late- in the project.
    Or, this might be a really wack idea that you should completely ignore!
  13. Sue Morton Guest
    Message Count:
    Hi BobF,
    This is an interesting idea! I'll be working with Sonar5 later this
    evening, I'll check this out.
    LOL I'll let you know. :)
    Sue Morton
    news:7u6cqfav8s0f$.kske8y3h2qlr$...
    >> bit
    > Sue,
    > routing/panning.
  14. Max Arwood Guest
    Message Count:
    Wow sounds like Greg already got this one. Never used cloned tracks much,
    but in this instance it seems to be perfect. What are you guys doing this
    Christmas?
    Max Arwood
    news:ZmIbf.13981$...
    manipulate
    each
    > look at that!
    > Sue Morton
    > news:...
    > > greg
  15. Sue Morton Guest
    Message Count:
    Hi Max,
    This year we will do four numbers (not necessarily in this order)
    1) One Small Child (David Meece) - soft and gentle, has alto soloist
    2) Peace, Peace (1969 original melody with 'Silent Night' woven through
    it) - an "all skate now" upbeat cutesy tune, a charmer
    3) There's Somethin' Goin' on in Bethlehem (Joel Lindsay) - adorable
    soft rock/Jazz (tune won't leave your head for days!)
    4) 2000 Decembers Ago/What Child is This medley (arr. Russell Mauldin) -
    great contemporary medley with a big ending, this will almost certainly be
    the last number
    I have nearly everyone back from last year, I lost only a few people due to
    vacations or big committments at the time we will sing. It will be really
    great to have the same crew back this year. I hope we can pick up more than
    a few new participants, too. :)
    Sue Morton
    "Max Arwood" <> wrote in message
    news:wfPbf.14269$...
    > Christmas?
    > Max Arwood
    >> at
    > manipulate
    > each
    >> look at that!
    >> Sue Morton
    >> news:...
    >> > use
    >> > way,
    >> > greg
  16. Greg McGuirk Guest
    Message Count:
    ya know what's ironic about this whole thread is that I often have to do the
    same thing for my worship team - make work CDs of harmony parts, with parts
    on one side & the track on the other. I've never used the method I
    suggested to you, 'cause I never took the time to think through the
    workflow. Now that you posed the question & I thought through a possible
    solution, I may have saved myself some time next time I have to do this
    (which will probably be soon since I'm also preparing our Christmas
    program). :)
    greg
    >look at that!
    > Sue Morton
    > news:...
    >> greg
  17. Max Arwood Guest
    Message Count:
    Thanks,
    I'm also preparing our Christmas program. What are you doing?
    Max Arwood
    news:...
    the
    parts
    > program). :)
    > greg
    at
    manipulate
    each
    > >look at that!
    > > Sue Morton
    > > news:...
    use
    way,
    > >> greg
  18. Greg McGuirk Guest
    Message Count:
    I've got a few custom arrangements of some standard stuff - We Three Kings,
    O Come O Come Emmanuel & Do You Hear What I Hear. We're also going to do a
    few things with the iWorship Christmas stuff from Integrity - it'll be a
    full praise team and chancel choir playing along with video. Should be fun.
    greg
    news:2qYbf.9746$...
    > Thanks,
    > Max Arwood
    > news:...
    > the
    > parts
    >> program). :)
    >> greg
    > at
    > manipulate
    > each
    >> >look at that!
    >> > Sue Morton
    >> > message
    >> > news:...
    > use
    > way,
    >> >> greg
  19. Sue Morton Guest
    Message Count:
    Hi Greg,
    I've tried all the suggestions, it's the midi/DXi's that bung things up.
    The suggestions work... but my original setup is simpler and (for me anyway)
    still the easiest to manage. I can look at a project, and see only one copy
    of each midi/DXi pair, one of each of the busses (solo, left, right, etc.),
    and in a few mouse clicks switch the routings to output the left/right mix
    that I want. A few more mouse clicks and output the next left/right mix,
    and so on. Very repetitive, true. But I just opened a project from a
    couple of years ago to reuse again this year, and it was instantly obvious
    to me, what goes where and what to do. Without having to remember anything
    (e.g. did I remember to clone that midi after changing it????).
    What I really need is for Sonar to have multiple outputs from a track or
    buss, then it would be a piece o' cake!
    Have you started working on this, yet? If so, what are you finding with it?
    Sue Morton
    news:...
    > the same thing for my worship team - make work CDs of harmony parts, with
    > parts on one side & the track on the other. I've never used the method I
    > program). :)
    > greg
    >>manipulate the output. But that was probably before the flexible buss
    >>routing was available. So my template currently has a single instance of
    >>a DXi to each MIDI track. But now I'm thinking I can use the multiple
    >>outs, so I will look at that!
    >> Sue Morton
    >> news:...
    >>> greg
      • Advertising
Share This Page
