If there is one thing I could change in Sonar
Discussion in 'cakewalk.audio' started by kitekrazy, Sep 2, 2010.
  1. kitekrazy Guest
    Message Count:
    Get rid of 90% of the clutter in the GUI.
    After spending more time in FL Studio and Ableton, I fail to see how
    putting every button imaginable promotes better workflow.
    It still has one of the best piano roll views.
      • Advertising
  2. Glennbo Guest
    Message Count:
    In news:i5onq0$kgj$-september.org the killer robot kitekrazy
    <> grabbed the controls of the spaceship
    cakewalk.audio and pressed these buttons...
    I want 5 rows of buttons and a console view that isn't resizable! <g>
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  3. Gerry Peters Guest
    Message Count:
    On Thu, 02 Sep 2010 10:44:28 -0700, kitekrazy
    You're right. You should only see what you use.
    I've gotten rid of a lot of the clutter by customizing these views.
    You can get rid of all those buttons. I've even used key bindings to
    disable certain hot keys, so I don't accidently graze one and do
    something unintended. You can also customize the upper menus (File,
    Edit, View, etc) and save your own trimmed down version. Also in the
    track pane you can customize those tab views at the bottom, so you
    only see what you want to see.
    Gerry Peters
  4. kitekrazy Guest
    Message Count:
    So what did you remove?
  5. Ted Perlman Guest
    Message Count:
  6. Glennbo Guest
    Message Count:
    In news:i5q0n8$p5l$-september.org the killer robot "Ted
    Perlman" <> grabbed the controls of the spaceship
    > ...it would be....Sonar :)
    You should try Ranos!
    It's the reverse engineered version of Sonar where
    everything good is bad and everything bad is good! <g>
    ________ __
  7. D.J.B Guest
    Message Count:
    Isn't that the new thing made by Klawekac?
    DJB
    "Glennbo" <> wrote in message
    news:Xns9DE8C05F7AE81BrownShoesDontMakeIt@85.214.73.210...
    > ________ __
  8. polymod Guest
    Message Count:
    "D.J.B" <djb_at_12ST.com> wrote in message
    news:37e9e$4c820b37$5356050a$1.nb.home.nl...
    Close....it's: "dnaloR yb Klawekac"
    Oikt
  9. Glennbo Guest
    Message Count:
    In news:4c825703$0$20172$ the killer robot "polymod"
    Dnalor has the marketing genius to come up with catch phrases like:
    "Looks like real drums" and "Photorealistic drum kit page" for the features
    of Session Drummer 2. And that's what you want with a drum plugin, is for
    it to *look* like real drums. <g>
    ________ __
  10. Sue Morton Guest
    Message Count:
    Shoot... you telling me I've been focusing on the wrong feature all this
    time?!?!?
    Sue Morton
    > features
    > for
  11. Glennbo Guest
    Message Count:
    In news:i5tqkd$gvi$-september.org the killer robot "Sue
    Morton" <> grabbed the controls of the spaceship
    > time?!?!?
    Yes, how a drum plugin sounds is inconsequential. How it looks is what
    really matters, and the more it looks like real drums the better!!!
    >> features
    >> for
    ________ __
  12. Sue Morton Guest
    Message Count:
    Well then I still haven't found my perfect drum plugin... The ones in
    Sonar look terrible to me :-/
    Sue Morton
    > what
  13. Glennbo Guest
    Message Count:
    In news:i5trfq$km1$-september.org the killer robot "Sue
    I'm working on this new drum plugin. So far, all I have is the
    photorealistic picture. http://members.cox.net/glennbo/LiveDrums.jpg
    >> what
    ________ __
  14. Sue Morton Guest
    Message Count:
    Now THAT is the best plugin I've seen so far! Can I get on the list to
    beta test?
    Sue Morton
  15. Glennbo Guest
    Message Count:
    In news:i5tsr9$qil$-september.org the killer robot "Sue
    > beta test?
    Sure, I just need to figger out how to get my photo into a .dll file.
    ________ __
  16. kitekrazy Guest
    Message Count:
    > Morton"<> grabbed the controls of the spaceship
    >> time?!?!?
    There is some truth to that. Eye candy has a lot do with what people
    will buy. I liked the 8 bit graphic look of Ableton.
    I bought Reason for it's eye candy.
    Battery and Drumcore don't have a pretty GUI like the other drummer apps.
  17. kitekrazy Guest
    Message Count:
    You'll need two of everything for Death Metal.
  18. Glennbo Guest
    Message Count:
    In news:i5u7si$qmm$-september.org the killer robot kitekrazy
    Well, I can just mirror image the photo for that!
    ________ __
  19. Dave \Mod Bod\ Modisette Guest
    Message Count:
    > it to *look* like real drums.<g>
    It doesn't look like real drums. Heck, it doesn't even look like
    EZdrummer although they obviously tried reeeaaaalllll hard to do that.
    Dave "Mod Bod" Modisette
    http://www.gatortraks.com/forum
  20. Dave \Mod Bod\ Modisette Guest
    Message Count:
    It sounds worse than it looks. And the drag and drop implementation is
    the worst in the genre.
      • Advertising
Share This Page
