Import midi into Sup 2.0
Discussion in 'cakewalk.audio' started by jeffl, Nov 30, 2010.
  1. jeffl Guest
    Message Count:
    I have been recording each midi file from my (don't laugh) dr. rhythm dr-770
    into the "my midifiles" in the EZPlayer within Sup 2.0 to have more midi
    grooves to work from
    I painstakingly record the midi data into a CW file-name each clip (16 beat,
    16 beatfill-etc) and then drag that entire track into the folder which gives
    me all of the separate clips. I have gotten somewhere around 140 clips now
    (there are 400+ in the 770)-can anyone think of a faster way to do it?
    (looked for a midi dump command-didn't seem to do anything)
    Also-about a third of the clips I have recorded/imported seem to have a
    bunch of space in front of them when trying to listen to the sample within
    EzPlayer but when I drag the file into CW there is just the immediate clip
    (ex: a one measure fill will not sound right away-almost have to wait 10
    seconds while it plays until I hear it but, again, when I drag it into the
    grid I can see only 1 measure of fill).
    Any recommendations where I could purchase a decent library of midi drum
    grooves/fills to add to my player?
    Thanks again for any help
    Jeff Loven
      • Advertising
  2. Glennbo Guest
    Message Count:
    In news:id2fn9$7cs$-september.org the killer robot "jeffl"
    <> grabbed the controls of the spaceship cakewalk.audio
    and pressed these buttons...
    I dunno where you'd go to get midi clips, but I made a few basic ones
    myself and simply copied them into this folder.
    C:\Program Files\Toontrack\EZDrummer\Midi\MY MIDIFILES
    You can download my few basic clips from here.
    http://members.cox.net/glennbo/SessionDrummerFiles.html
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  3. jeffl Guest
    Message Count:
    Thanks Glennbo. When I get done with my midi drum groove library (several
    days work) I will send the whole thing to ya if you want--just for all the
    times you helped out. If ya get time--ping me with your email and I will
    send ya the whole thing. (Some very useable grooves/fills/etc--may-or may
    not be useful for a drummer guy like you) I'm at:
    there are song samples at my website in the top right corner--you can get an
    idea what I do (all recorded in CW)
    www.jeffloven.com
    Regards,
    Jeff
    "Glennbo" <> wrote in message
    news:Xns9E40B32DA820BBrownShoesDontMakeIt@81.169.183.62...
    > ________ __
  4. Glennbo Guest
    Message Count:
    The killer robot "jeffl" <> grabbed the controls of the
    spaceship cakewalk.audio and pressed these buttons...
    > (several days work) I will send the whole thing to ya if you
    > want--just for all the times you helped out. If ya get time--ping me
    > with your email and I will send ya the whole thing. (Some very
    > useable grooves/fills/etc--may-or may not be useful for a drummer guy
    > like you) I'm at:
    > get an idea what I do (all recorded in CW)
    I do use grooves to get songs off the ground. Usually, I'll toss a single
    repeating groove on the drum track, and once the song has some bass and
    guitar, I'll go back and play the real drums to it. My email address is in
    all of my messages, but you have to remove the sekret werds as it says
    below in my sig! ;)
    ________ __
      • Advertising
  5. jeffl Guest
    Message Count:
    Got it--I will send the file when I get done.
    Thanks again!
    news:Xns9E42576BBB494BrownShoesDontMakeIt@188.40.43.230...
    >> like you) I'm at:
    > in
    > below in my sig! ;)
    > ________ __
  6. Glennbo Guest
    Message Count:
    Cool! :)
    ________ __
      • Advertising
Share This Page
