Hi all. I'd like to create a personal jingle with sound effects like airplane-passing, thunderstorms and with my voice too. Cubase guide does not support me enough. Are someone available to help me? Thanks for thousands in adance. Chrstian
On Fri, 17 Apr 2009 16:28:50 +0200, "C. Riganò" <> wrote: >Hi all. >I'd like to create a personal jingle with sound effects like >airplane-passing, thunderstorms and with my voice too. >Cubase guide does not support me enough. Are someone available to help me? >Thanks for thousands in adance. >Chrstian > I'm not sure I understand the problem. What you need is just audio tracks, various samples, a mic and perhaps some hall/mastering plugins. What is the nature of the problem?
"Bas" <> ha scritto nel messaggio news:... > On Fri, 17 Apr 2009 16:28:50 +0200, "C. Riganò" > <> wrote: > > I'm not sure I understand the problem. > What you need is just audio tracks, various samples, a mic and perhaps > some hall/mastering plugins. > What is the nature of the problem? Well, yes. I've to do one audio track with my voice, recorded by mic and with some sound effects like thunderstorms, screams and so on. Is it easy? Is my Cubase version able to do that? Thank you.
On Fri, 17 Apr 2009 19:24:06 +0200, "C. Riganò" <> wrote: > >"Bas" <> ha scritto nel messaggio >news:... >> On Fri, 17 Apr 2009 16:28:50 +0200, "C. Riganò" >> <> wrote: >> >> I'm not sure I understand the problem. >> What you need is just audio tracks, various samples, a mic and perhaps >> some hall/mastering plugins. >> What is the nature of the problem? > >Well, yes. I've to do one audio track with my voice, recorded by mic and >with >some sound effects like thunderstorms, screams and so on. Is it easy? >Is my Cubase version able to do that? >Thank you. > You will have to get your hands on some sample cd's with those sound fx on them
On Fri, 17 Apr 2009 19:24:06 +0200, "C. Riganò" <> wrote: >Well, yes. I've to do one audio track with my voice, recorded by mic and >with >some sound effects like thunderstorms, screams and so on. Is it easy? >Is my Cubase version able to do that? Do you HAVE recordings of these sounds? If so yes, it's very easy. Read the program's manual then come back if you have any specific questions. CubaseFAQ page: http://www.laurencepayne.co.uk/CubaseFAQ.htm
"Laurence Payne" <> ha scritto nel messaggio news:... > On Fri, 17 Apr 2009 19:24:06 +0200, "C. Riganò" > <> wrote: > >>Well, yes. I've to do one audio track with my voice, recorded by mic and >>with >>some sound effects like thunderstorms, screams and so on. Is it easy? >>Is my Cubase version able to do that? > > Do you HAVE recordings of these sounds? If so yes, it's very easy. > Read the program's manual then come back if you have any specific > questions. > CubaseFAQ page: http://www.laurencepayne.co.uk/CubaseFAQ.htm Ok, thank you all. One more question: is it possible to download somewhere these sounds (like thunderstorm, scream...and so on)? If so, where? Thanks.
C. Riganò wrote: > Ok, thank you all. One more question: is it possible to download > somewhere these > sounds (like thunderstorm, scream...and so on)? If so, where? Do you know how to use a web search engine? A quick Google search for "sound effects free" turned out the following results (and I don´t know, how many more...): http://www.sounddogs.com/ http://www.freesound.org/ http://www.sound-effect.com/ http://www.freesoundeffectsandloops.com/ http://simplythebest.net/sounds/WAV/sound_effects_WAV/ http://www.a1freesoundeffects.com/ http://www.stonewashed.net/sfx.html Either you find something usable there or search yourself... as you know what to search for now. ;-) Use 1 track per sound effect, so you can independently apply insert fx, if necessary. Phil
"Phil W" <> ha scritto nel messaggio news:gsakec$aon$... > C. Riganò wrote: > >> Ok, thank you all. One more question: is it possible to download >> somewhere these >> sounds (like thunderstorm, scream...and so on)? If so, where? > > Do you know how to use a web search engine? A quick Google search for > "sound effects free" turned out the following results (and I don´t know, > how many more...): > http://www.sounddogs.com/ > http://www.freesound.org/ > http://www.sound-effect.com/ > http://www.freesoundeffectsandloops.com/ > http://simplythebest.net/sounds/WAV/sound_effects_WAV/ > http://www.a1freesoundeffects.com/ > http://www.stonewashed.net/sfx.html > > Either you find something usable there or search yourself... as you know > what to search for now. ;-) > > Use 1 track per sound effect, so you can independently apply insert fx, if > necessary. > > > Phil Hi Phil. I asked this question because obviuosly I did not know how web search engine works about sound effects. Anyway, thank you for this. I'll try to download some of theme and work with'em. Thanks again.
On Fri, 17 Apr 2009 21:32:44 +0200, "C. Riganò" <> wrote: > >Hi Phil. >I asked this question because obviuosly I did not know how web search engine >works about sound effects. Anyway, thank you for this. I'll try to download >some of theme and work with'em. >Thanks again. Funny, in a way. Not much internet experience, obviously no cubase experience and probably no experience whatsoever with any kind of DAW, but he does have Cubase 5
"Bas" <> ha scritto nel messaggio news:... > On Fri, 17 Apr 2009 21:32:44 +0200, "C. Riganò" > <> wrote: > >> >>Hi Phil. >>I asked this question because obviuosly I did not know how web search >>engine >>works about sound effects. Anyway, thank you for this. I'll try to >>download >>some of theme and work with'em. >>Thanks again. > > Funny, in a way. > Not much internet experience, obviously no cubase experience and > probably no experience whatsoever with any kind of DAW, but he does > have Cubase 5 I'm sorry, but it's exactly as you described. Thanks.
C. Riganò wrote: > I asked this question because obviuosly I did not know how web search > engine works about sound effects. Well, it works pretty much the same way, as it works for anything one might be looking for. Just think of some words, which describe as good as possible, what you´re looking for... If you´re looking for "free sound effects", simply type that in and hit the Enter key or click the "search" button. Then go through the results, that show up, until you find, what you´re looking really for. > Anyway, thank you for this. I'll > try to download some of theme and work with'em. Good luck then! ;-)
"Phil W" <> ha scritto nel messaggio news:gsbuo5$9ft$... > C. Riganò wrote: > >> I asked this question because obviuosly I did not know how web search >> engine works about sound effects. > > Well, it works pretty much the same way, as it works for anything one > might be looking for. Just think of some words, which describe as good as > possible, what you´re looking for... If you´re looking for "free sound > effects", simply type that in and hit the Enter key or click the "search" > button. Then go through the results, that show up, until you find, what > you´re looking really for. > >> Anyway, thank you for this. I'll >> try to download some of theme and work with'em. > > Good luck then! ;-) Ok, thank you very much for everything. ;-)
On Fri, 17 Apr 2009 22:12:25 +0200, "C. Riganò" <> wrote: > >"Bas" <> ha scritto nel messaggio >news:... >> On Fri, 17 Apr 2009 21:32:44 +0200, "C. Riganò" >> <> wrote: >> >>> >>>Hi Phil. >>>I asked this question because obviuosly I did not know how web search >>>engine >>>works about sound effects. Anyway, thank you for this. I'll try to >>>download >>>some of theme and work with'em. >>>Thanks again. >> >> Funny, in a way. >> Not much internet experience, obviously no cubase experience and >> probably no experience whatsoever with any kind of DAW, but he does >> have Cubase 5 > >I'm sorry, but it's exactly as you described. >Thanks. > Nothing to be sorry about. At least you're starting at the top ))
