Hello, i have recently got the PRAM and the Piano board for my K2500RS with KDFX (was running 5.01) now i am sure that both are installed properly i can see them when i run the diag from the boot manager (v103b) however when i try to install the 3 object i want (500 prestes + 403 piano + 403 LiveMode) the k2500 goes banana ! either i get only the preset piano and LM and not being able to hear a single sound ! ( or i get the 500 presets alone but at least they work ! is it impossible to get all 3 of them to work toghter ? not enough space in the EEPROM ? 501 and 403 obj don't co exist toghetr ? i can not find on the kurz ftp site OBJ newer then 403 for Piano board and LiveMode, is that really the case ? i even try to downgraded to 404 OS but i get the same results what is the correct order procedure to have 500 prestes + 403 piano + 403 LiveMode objs running properly ? Tnx in advance for any hints and help Regards -----------------------------------Env1-----Env2--Env3 Andrea TONI Vco1 \ | | \ Science Operation and Data Vco2-->--Vcf-->Vca-->Ducati996 Systems Division (SCI-SD) Vco3 / | | / -----------------------------------Lfo1-----Lfo2--Lfo3 http://www.rssd.esa.int
