Keyboard to PC using MIDI to USB
Discussion in 'General Keyboard Discussion' started by jeam97, Feb 20, 2010.
  1. jeam97 New Member
    Nov 7, 2009
    Message Count:
    Salt Lake City, UT
    Hello,
    I have a Yamaha YPT-310. I have a Mac and I can run XP on it using Parallel's Desktop.
    I purchased the following MIDI to USB cable from Amazon.com:
    http://www.amazon.com/gp/product/B0017H4EBG/ref=oss_product
    I installed the recommended Yamaha Musicsoft Downloader 5 software.
    I plugged the MIDI cables into the back of the keyboard (yes - the "In" and "Out" are plugged into the correct ones) and the other end of the cable into a USB port.
    XP recognized a new piece of hardware and installed the drivers successfully.
    When I run the Musicsoft Downloader software, it says it can't communicate a musical instrument.
    I'm not sure what I'm doing wrong. I tried turning the "Local" setting on the keyboard "Off" and that didn't work. I tried setting the keyboard to "PC1" mode, and then "PC2" mode and that didn't work either.
    Any suggestions? Thanks! - Jeff
      • Advertising
  2. ypelletier New Member
    Nov 7, 2008
    Message Count:
    52
    Canada
    I use Musicsoft Downloader with my YPT-300. What you described seems correct. Did you try with another piece of software (Midi-Ox maybe?).
    When you say the "In" and "Out" are plugged into the correct ones: did you try to invert them, just in case?
      • Advertising
Share This Page
