korg m1 restore factory presets, help!??
Discussion in 'alt.music.synth' started by Kit Robinson, May 24, 2004.
  1. Kit Robinson Guest
    Message Count:
    I have changed the battery in the korg m1 and need to restore factory
    presets. I have downloaded the correct file and instructions for doing so
    from Korg.com. I also found some other instructions from other sites but
    none of them match. Something is missing.
    I have set all midi filtering to "enable", turned all memory protection
    "off", have midi channel set to "1", I have tried the procedure with all
    different "pages" showing on the m1 screen. I've tried it with the clock set
    to "int" and "ext". The computer shows the dta being sent but the M1 doesn't
    respond. Nothing changes when the m1 is powered off then back on.
    The cables and output settings are correct, I can dump data from the m1 to
    the computer wthout problems, so I think something is set incorrectly on the
    m1 itself.
    I've seen lots of posts asking for the same information but on good
    answers....Anybody?? Thanks, kr.
      • Advertising
Share This Page
