I was trying to download a midi file after I edited it with Cakewalk. After I loaded it onto my K2vx, the keyboard froze. So now, everytime I try to turn the unit on, it's stuck in this infinite loop on the main splash screen. I think it says V.A.S.T v3.18 with the sine wave. I tried performing a soft reset... nothing. Removed the batteries.... nothing. Removed the memory SIMMS, same thing. Any recommendations. Thanks in advance, Alex
You might try removing power and the batteries for a really long time - say overnight. Don't know if you've tried it but it's worth a shot... On Tue, 21 Oct 2003 23:43:02 -0400, "Alex Cusenza" <> wrote: >I was trying to download a midi file after I edited it with Cakewalk. After >I loaded it onto my K2vx, the keyboard froze. So now, everytime I try to >turn the unit on, it's stuck in this infinite loop on the main splash >screen. I think it says V.A.S.T v3.18 with the sine wave. > >I tried performing a soft reset... nothing. Removed the batteries.... >nothing. Removed the memory SIMMS, same thing. > >Any recommendations. > > >Thanks in advance, >Alex > > > Michael Houston musicianmike at cox dott net (you know what to do)
I will try removing the batteries for a longer period. thanks "Michael Houston" <> wrote in message news:... > You might try removing power and the batteries for a really long time > - say overnight. > > Don't know if you've tried it but it's worth a shot... > > On Tue, 21 Oct 2003 23:43:02 -0400, "Alex Cusenza" > <> wrote: > > >I was trying to download a midi file after I edited it with Cakewalk. After > >I loaded it onto my K2vx, the keyboard froze. So now, everytime I try to > >turn the unit on, it's stuck in this infinite loop on the main splash > >screen. I think it says V.A.S.T v3.18 with the sine wave. > > > >I tried performing a soft reset... nothing. Removed the batteries.... > >nothing. Removed the memory SIMMS, same thing. > > > >Any recommendations. > > > > > >Thanks in advance, > >Alex > > > > > > > > Michael Houston > musicianmike at cox dott net (you know what to do)
Alex Cusenza wrote: > I was trying to download a midi file after I edited it with Cakewalk. After > I loaded it onto my K2vx, the keyboard froze. So now, everytime I try to > turn the unit on, it's stuck in this infinite loop on the main splash > screen. I think it says V.A.S.T v3.18 with the sine wave. > > I tried performing a soft reset... nothing. Removed the batteries.... > nothing. Removed the memory SIMMS, same thing. > > Any recommendations. > > > Thanks in advance, > Alex > > > test
Alex Cusenza wrote: > I will try removing the batteries for a longer period. > > thanks > > "Michael Houston" <> wrote in message > news:... > >>You might try removing power and the batteries for a really long time >>- say overnight. >> >>Don't know if you've tried it but it's worth a shot... >> >>On Tue, 21 Oct 2003 23:43:02 -0400, "Alex Cusenza" >><> wrote: >> >> >>>I was trying to download a midi file after I edited it with Cakewalk. > > After > >>>I loaded it onto my K2vx, the keyboard froze. So now, everytime I try to >>>turn the unit on, it's stuck in this infinite loop on the main splash >>>screen. I think it says V.A.S.T v3.18 with the sine wave. >>> >>>I tried performing a soft reset... nothing. Removed the batteries.... >>>nothing. Removed the memory SIMMS, same thing. >>> >>>Any recommendations. >>> >>> >>>Thanks in advance, >>>Alex >>> >>> >>> >> >>Michael Houston >>musicianmike at cox dott net (you know what to do) > > > test
lAzZaro wrote: > Alex Cusenza wrote: > >> I will try removing the batteries for a longer period. >> >> thanks >> >> "Michael Houston" <> wrote in message >> news:... >> >>> You might try removing power and the batteries for a really long time >>> - say overnight. >>> >>> Don't know if you've tried it but it's worth a shot... >>> >>> On Tue, 21 Oct 2003 23:43:02 -0400, "Alex Cusenza" >>> <> wrote: >>> >>> >>>> I was trying to download a midi file after I edited it with Cakewalk. >> >> >> After >> >>>> I loaded it onto my K2vx, the keyboard froze. So now, everytime I >>>> try to >>>> turn the unit on, it's stuck in this infinite loop on the main splash >>>> screen. I think it says V.A.S.T v3.18 with the sine wave. >>>> >>>> I tried performing a soft reset... nothing. Removed the batteries.... >>>> nothing. Removed the memory SIMMS, same thing. >>>> >>>> Any recommendations. >>>> >>>> >>>> Thanks in advance, >>>> Alex >>>> >>>> >>>> >>> >>> Michael Houston >>> musicianmike at cox dott net (you know what to do) >> >> >> >> > test > test3
