At my son's school, we have a Kurzweil Mark 10 (yes, I know it is a dinosaur) and the floppy is getting balky. If we get a cheap USB to MIDI cable, can we record out performances to a PC and then load them back in as neeeded? There seems to be a lot of noise about General MIDI vs. the Kurzweil format, and I can't quite sort it out. Minimally, we want save out and play back. That is the main need. We have Mac and PC laptops sitting around that we can use. Ideally, we could edit files we record, or load in other MIDI (General?) files from other sources. We'd also like to be able to take the current pile of floppies and catalog them on to a hard drive and push them in the MIDI port with a click rather than trying to find the floppy. The Piano is frequently used for music during the kids drama performances and we'd love to have the ability to quickly load in sequences that had been recorded by a skilled piano player earlier (which we currently do with floppies) Am I dreaming? How much of this is possible? What software do we need? I see the $40 M-Audio USB to MIDI cable, can we use that?
On Thu, 08 Feb 2007 21:08:15 -0800, remaker wrote: > At my son's school, we have a Kurzweil Mark 10 (yes, I know it is a > dinosaur) and the floppy is getting balky. > > If we get a cheap USB to MIDI cable, can we record out performances to a > PC and then load them back in as neeeded? > > There seems to be a lot of noise about General MIDI vs. the Kurzweil > format, and I can't quite sort it out. > > Minimally, we want save out and play back. That is the main need. We > have Mac and PC laptops sitting around that we can use. > > Ideally, we could edit files we record, or load in other MIDI (General?) > files from other sources. > > We'd also like to be able to take the current pile of floppies and catalog > them on to a hard drive and push them in the MIDI port with a click rather > than trying to find the floppy. > > The Piano is frequently used for music during the kids drama performances > and we'd love to have the ability to quickly load in sequences that had > been recorded by a skilled piano player earlier (which we currently do > with floppies) > > Am I dreaming? How much of this is possible? What software do we need? > > I see the $40 M-Audio USB to MIDI cable, can we use that? I have a Mark 10 Kurzweil and it works with the M-Audio UNO midisport. Band in a box 2006 will record what is played on the Kurzweil but for some reason won't play what is stored on the computer on the Kurzweil. However I downloaded a midifile off of the internet and when I play that using the built in midi player for Windows 2000 SP4 the Kurzweil plays the file okay. Not sure how much this helps though. MM
