Kurzweil Mark 12 Key Stick
Discussion in 'alt.music.synth.kurzweil' started by Rick N Pam, May 28, 2008.
  1. Rick N Pam Guest
    Message Count:
    I'm working on a Mark 12 for my church. One key will stick (not
    mechanically) with permanent sustain until it gets pressed again. It is most
    sensitive to quick attack presses & releases. I've cleaned the PCB contacts
    and the contact in the rubber membrane, but without any luck. The only other
    information I can provide is: 1) when I removed the console and tipped it
    over, a small piece of plastic fell out from the same area as the affected
    key, 2) I noticed a very, very slight difference in the feel of the key,
    especially when it is released which may be causing contact bounce and
    latching up some logic in the keyboard scanner?? 3) when pressing the key,
    there is a very slight, almost indistinguishable "tick".
    I've taken the key out and inspected the counter weight, but can't see
    anywhere where the plastic piece may have come from. I'm not quite sure how
    to completely remove the counter weight yet.
    Any clues or suggestions for the next time I go inside this thing?
    Please respond to newsgroup only. I can't take the flurry of spam every time
    I post my email address.
    Thanks!
      • Advertising
  2. me Guest
    Message Count:
    > most sensitive to quick attack presses & releases. I've cleaned the PCB
    > contacts and the contact in the rubber membrane, but without any luck. The
    > only other information I can provide is: 1) when I removed the console and
    > tipped it over, a small piece of plastic fell out from the same area as
    > the affected key, 2) I noticed a very, very slight difference in the feel
    > of the key, especially when it is released which may be causing contact
    > bounce and latching up some logic in the keyboard scanner?? 3) when
    > pressing the key, there is a very slight, almost indistinguishable "tick".
    > how to completely remove the counter weight yet.
    > time I post my email address.
    > Thanks!
    I wonder if it is feasible to swap the key and the rubber part with
    some other key that isn't played often such as
    the far left or right key.
    Another idea is to remove a neighboring key to see the action on the
    rubber thing.
    I wonder if the small plastic part was inside
    the rubber part? Just a guess.
    I have a Mark 10 I just spent a few weeks fixing. I notice the middle
    group of keys squeak a little in case you know about squeaks.
    Good luck
  3. Rick N Pam Guest
    Message Count:
    I just spent an hour working on the keyboard before I came home and found
    your reply this evening. Oddly enough, I had thought to swap sections of the
    rubber membrane and that is why I went there tonight. The problem did move
    with the membrane. Now, I need to find a source for Kurzweil parts! any
    suggestions?
    "me" <> wrote in message
    news:BtI2k.211$...
    >> The
    >> and
    >> "tick".
    >> Thanks!
    > rubber thing.
    > Good luck
  4. Ballroom Dancer Guest
    Message Count:
    "Rick N Pam" <> wrote in message
    news:...
    >the rubber membrane and that is why I went there tonight. The problem did
    >move with the membrane. Now, I need to find a source for Kurzweil parts!
    >any suggestions?
    Contact Duane Garvin through www.dgaudiorepair.com is one suggestion.
    Otherwise, www.kurzweilmusicsystems.com has links for authorized service,
    and a request form to contact them directly.
    Jim
  5. me Guest
    Message Count:
    > any suggestions?
    > news:BtI2k.211$...
    >>> The
    >>> and
    >>> feel of the key, especially when it is released which may be causing
    >>> contact bounce and latching up some logic in the keyboard scanner?? 3)
    >>> when pressing the key, there is a very slight, almost indistinguishable
    >>> "tick".
    >>> Thanks!
    >> some other key that isn't played often such as the far left or right
    >> key.
    >> rubber thing.
    >> group of keys squeak a little in case you know about squeaks. Good luck
    This may not help much but I made a couple of parts for
    the Kurzweil I fixed. There were a couple of push buttons
    missing from the control board and I made them by grinding
    down small pieces of wood with a bench grinder to get the
    sizes I needed. One of them was originally lit by an LED in the
    bottom of the push button well and I drilled a hole in the new
    wooden button to let the
    light through to the top of the button and then I put a small
    amount of epoxy in the hole to make it look like a clear lens.
    On one of the buttons I had to make a small L shaped flat
    piece of metal to glue onto the side and bottom of the wooden
    button to be an offset as the actual push button switch on the
    circuit board was off to the side a bit in the hole for
    the push button. I also
    drilled small holes in the bottom of the two switches and
    fished some fishing line from one to the other underneath
    the control board to make
    them captive so they won't fall out. I painted them
    black with a black marks a lot felt tip pen.
    The foot pedals were broken as someone pushed
    on them so hard they broke out of the plastic box they were
    mounted in. I keep a cache of plastic parts that can be melted
    with a wood burning tipped solder gun that solidify into
    a strong piece of plastic
    when cold and used this to melt a new plastic box into place.
    It wasn't strong enough so I reinforced it with one of those
    metal repair strips with pre drilled holes from Ace Hardware.
    Two of the springs had fallen out but Ace Hardware had the exact
    springs for some reason.
    This may have been more than you wanted to know but
    might serve as an inspiration of some sort. What is broken
    on your Kurzweil?
      • Advertising
Share This Page
