Kurzweil PC88 "scanner is dead"
Discussion in 'alt.music.synth.kurzweil' started by Matzon, Jan 29, 2006.
  1. Matzon Guest
    Message Count:
    Hi!
    Sometime ago some person emailed a question about PC88 error "scanner is
    dead". I have had this error on my PC88 for several years and had not
    enough time to check it by myself. I got this keyboard on the service
    once, but they did not find anything to repair. The memory battery has
    been changed but that is not the point. I assume there may be some cold
    contacts on the circuit boards, may be on power supply or something. Does
    any one have experiencies about this kind of issue? Br. Matti / Finland
      • Advertising
  2. jochen Guest
    Message Count:
    Re: Kurzweil PC88
    i have had the same problem and coud fix it
    press the buttons 1,2and 3 during power on and leave them within 2 seconds
    than you see in the lcd
    "Press <<< to reset
    Press >>> to diag"
    Press >>> to diagnose
    and you see
    Debug cpu test
    press the zone 3 button and the test will start
    on the right side of the display you see fail or
    pass if pass it is all right to step to the next test press a key for the
    midi uart test you need
    a midicable from out to in at least there will be a test of vgm port if
    you have none its fail otherwise 5 sinus tones will be performt and after
    every tone you have to qit with a key the same is for the sound test.
    in the diagnose program the scanner is testet
    if its pass its all right after the sound test
    the program ends and you have to switch out and on
    again after that it should work if the scanner test dont fails
    jochen
    ps please report your experience
  3. Matzon Guest
    Message Count:
    Re: Kurzweil PC88
    Hi Jochen! Thanks for your advice. In fact in the very beginning, when this
    problem appeared I did those steps you mentioned, those are in the manual
    also. Anyway, those did not help. But what is quite curious thing, the
    piano has been working now quite well. I tried again those steps, and
    every test goes through successfully. So, don't know what is the final
    reason. The piano has not been in very heavy use at all, only occasional
    playing when I have had suitable time. Will those errors come back if used
    more, transport it etc. One new thing I noticed, one of the keys seem to
    give full volume when pressing it. I noticed someone here adviced how to
    repair this kind of issue, I try to check it. Br. Matti
      • Advertising
Share This Page
