Larger Projects - how managing?
Discussion in 'alt.steinberg.cubase' started by Gerd-Ulrich Meyer, Nov 4, 2009.
  1. Gerd-Ulrich Meyer Guest
    Message Count:
    Hallo,
    is there a good way to manage larger projects containing for example
    more than one song?
    Example: I want to compose the soundtrack for a small (not more then 30
    minutes) video. This soundtrack should consist of some different songs
    so that the songs can be adapted to the "mood" (is this the right word?)
    of the specific scene.
    I don't want to start a discussion about video-soundtracks or scoring.
    In older versions of cubase a "Song" could contain one or more
    "Arrangements", so that i took a "Song" to structure such larger
    projects. But when i look around in Cubase, i only find a "Project".
    Does that mean i have to create a project for each of my wanted songs?
    Or does that mean that i have to compose the whole score in one project
    and to adapt the lengthes and starttimes exactly to the imported
    video-track?
    Or does that mean....?
    Please give me some advice.
    Many thanks in advance.
    Greetings
    Gerd-Ulrich Meyer
      • Advertising
  2. Hueyduck Guest
    Message Count:
    This is my way of working when I have several music I have to deliver
    for the same film. But it might not be the moste effective.
    Since I never work on two different musics at the same time, I just
    have to import bounces of the musics before and after the currently
    opened song.
    Two things are helping me when I do this:
    There is a time code printed in each frame of the video.
    This way, I can continue working in a bar-beat scale *and* know where I
    put things in the film.
    Your vision of a big project with several music is more a vison of
    post-production, to me.
    Cubase is more of a pre-poduction/production stage software , I think.
    Huey
  3. Gerd-Ulrich Meyer Guest
    Message Count:
    Hallo,
    I thought so. So i decided to ask here :)
    > opened song.
    That would be possible to realize.
    Well, i have a "mixture" of both. As i'm both "Video-producer/composer"
    and "Songcreator" i can switch between both workflows.
    At the moment my complete plan for this project looks like:
    1. Creating and cutting a raw version of the video (without transitions
    and without correct scene-lengths).
    2. Creating the songs and mix them down with a separate mixing desk on a
    Minidisc.
    3. Importing the songs as *.wav and adding them in the correct order to
    the video-track (this step has to be done in the Video-editing-software).
    But my problem is between step 1 and 2: I can export the raw video and
    import it in Cubase as a video track, so that i can determine the
    lengths of each song. Now, when i use separate projects for each song i
    have to import the video in each project.
    So that was my question: Does anybody know a way to have more than one
    song in a Cubase-project?
    Thank you though.
    > Huey
    Greetings,
    Gerd-Ulrich Meyer
  4. Swanny Guest
    Message Count:
    Gerd-Ulrich Meyer wrote:
    > Hallo,
    > more than one song?
    > video-track?
    > Greetings
    > Gerd-Ulrich Meyer
    Whilst this does not relate specifically to video soundtrack production,
    the workflow I have used for complete CD production (tracking, mixing,
    mastering and manufacture) may be a similar situation in some respects.
    Firstly I create a single directory to hold the entire album project.
    Then I track each song as a separate tracking project in a tracking
    directory. Each of these tracking projects has inputs configured for
    tracking and several takes per song plus overdubs etc.
    Following tracking, the appropriate parts and takes are selected and
    inserted into a mixing project for each song, in a mixing directory.
    Thes projects have inserts and sends, eq etc to mix the song down to 2
    tracks. Each song is mixed and rendered to a 2-track audio file (32 bit).
    Once all the songs are mixed I will create a mastering project (in a
    mastering directory), with one stereo track per song and import the
    songs into each track at their appropriate positions in the album
    context. Each track can have additional mastering processing applied to
    it and final 2-track bus processing. This allows the complete CD to be
    listened to all the way through to check for sequencing and continuity.
    Once the mastering is complete the tracks are then rendered individually
    as 16-bit dithered 44.1K files ready to be burnt to an audio CD to go to
    the manufacturers.
      • Advertising
  5. Jos Geluk Guest
    Message Count:
    Gerd-Ulrich Meyer schreef:
    > Hallo,
    As an addition to Huey's good advice: I don't believe it is necessary to
    re-import the video, i.e. creating a new copy of the video file, for
    each project. You can use "Back up project" without copying the video
    file. So you would make one "template" project with the video, and then
    use Backup for each song.
    For the rest I agree with the statement that you should create a new
    folder for each song. Rearranging the finished songs to the complete
    video for mastering and editing is a different job, which deserves its
    own folder, again created from the template.
    HTH
    Jos.
    Ardis Park Music
    www.ardispark.nl
  6. Gerd-Ulrich Meyer Guest
    Message Count:
    Hallo,
    >> Hallo,
    >> i have to import the video in each project.
    Ahh, that sounds good. I didn't recognize this function as a way to
    solve my problem.
    With this "background-knowledge" the separation in different folders for
    each song makes sense.
    > HTH
    Again, it seems, that you all have helped me a big step forward (i hope
    this is a possible wording?! :) )
    > Jos.
    Greetings,
    Gerd-Ulrich Meyer
  7. Hueyduck Guest
    Message Count:
    Yes and no.
    Yes you have to import the video in each song. But It can be the same
    file called by 10 different cubase project.
    You don't have to have the whole video in each project. You have to
    import it all, but you can cut only the part you need for each song.
    Since you can always read the time code of the film, you don't have to
    bother where you cut : it just have to serve the image well.
    When you are done with each song, you can write down the time code of
    the movie your song is starting so that you can put you wave in you
    video project.
    And btw, I forgot to tell you the last step I take, sometimes:
    I simlply create a "mother song" in cubase, where there is no production
    tracks but only the bounces of the different piece of music previously
    preproduce.
    I hope somebody will help more. But, out of curiosity: how can you need
    to work on several songs at a time?
    For instance, If I'm working on a song and find that the crossfade with
    the precefent song is not happening how I want it, I just bounce one of
    the twio songs and import it into the song that has to change in order
    to hava nice crossfade.
    That gives me the luxury of always having my whole CPU power for each song.
    But you might not consider this advantage if you are working with a lot
    of external stuff too.
    Huey
      • Advertising
Share This Page
