The Juno G was recommended to me, and I like what I've read... but there's a specific thing I'm wondering about. On the Kurzweils I'm accustomed to (at a theatre gig), you could map it so you'd trigger an audio drum loop on the bottom note with your left-hand pinky, play bass with the rest of that bottom octave (with the other LH fingers), and piano with the right hand, on all octaves above that. Gave a cool trio effect. Can I: (a) import drum loops into the Juno G? It seems you can import sounds from the card slot or via USB, but can they then be looped? When I load SDII files into gear, the loop markers are still there, but the Juno G uses WAVs. Can you put loop markers on a WAV, or can you loop the WAV once it's inside the Juno? (b) ...map that keyboard layout I need, either as a patch or a combination? Any info would be appreciated. The Juno G is lightweight and affordable, and it's mostly just for accompanying improv and sketch comedy. I've already got digital pianos and a laptop for intricate stuff; I'd just like to have a lightweight keyboard with all the sounds built in, to throw in the trunk of the car for comedy gigs. cheers Jim
