Looking for new sounds, for Sonar
Discussion in 'cakewalk.audio' started by Botticeli, Jun 4, 2010.
  1. Botticeli Guest
    Message Count:
    I am using Native instruments, that are good, but too electronic. Also
    Dimension and some other players that came embedded in my low grade
    Sonar.
    I am doing background music for narrative recordings, so I am looking
    for sounds related to strings and choirs, ethereal stuff. Something
    that works with Sonar 6LE and is not terrible expensive.
    Thanks
    Botticelli
      • Advertising
  2. Bob Donald Guest
    Message Count:
    I havent delved too far into it, and dont know how well it will fit into the
    scope of your project, but have you checked out proteus VX? It's free, and
    has some pretty cool sounds.
    Bob
    "Botticeli" <> wrote in message
    news:...
    > Sonar.
    > Thanks
    > Botticelli
  3. Phoenix Guest
    Message Count:
    On Fri, 4 Jun 2010 08:43:49 -0700 (PDT), Botticeli
    Also
    > Sonar.
    looking
    > Thanks
    > Botticelli
    Check out the Sampletank group buy over at esoundz or IK Multimedia's
    own site. You can get a whole lot of sounds for just $50 USD.
  4. Glennbo Guest
    Message Count:
    The killer robot "Bob Donald" <> grabbed the controls of
    the spaceship cakewalk.audio and pressed these buttons...
    > into the scope of your project, but have you checked out proteus VX?
    > It's free, and has some pretty cool sounds.
    Proteus VX is one of the few free instruments that have a lot of usable
    sounds IMO. I've used sounds from it in many recordings, including my
    recent 5 drum sets plus percussion song, "Drum Corpse".
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
      • Advertising
  5. kitekrazy Guest
    Message Count:
    > Also
    >> Sonar.
    > looking
    >> Thanks
    >> Botticelli
    But purchase thru ezounds since you will get 10 total.
  6. Botticeli Guest
    Message Count:
    > > Also
    > >> Sonar.
    > > looking
    > >> Thanks
    > >> Botticelli
    > But purchase thru ezounds since you will get 10 total.- Hide quoted text -
    > - Show quoted text -
    I got the Proteus VX... for free is great!
    Now how can I make SONAR to recognize it? When I open the Synth Rack
    is not there...
    Thanks
    Boticelli.
  7. Bob Donald Guest
    Message Count:
    I agree, at least in my case. I remember getting it when I got my emu 0404
    working, and you posted a few days afterwards that you were using it. I
    figured if it was "Glennbo approved" it cant be all bad LOL
    "Glennbo" <> wrote in message
    news:Xns9D8D725675191BrownShoesDontMakeIt@85.214.73.210...
    > ________ __
  8. Glennbo Guest
    Message Count:
    > emu 0404 working, and you posted a few days afterwards that you were
    > using it. I figured if it was "Glennbo approved" it cant be all bad
    > LOL
    Just last week someone in the Toontrack forum asked me to tell them where I
    got the great gong sample in Drum Corpse. I loaded up the song, and traced
    it back to . . . you guessed it, the Protus VX. I have so many different
    drum softsynths on that piece that I wasn't sure without looking. ;)
    ________ __
  9. Phoenix Guest
    Message Count:
    On Fri, 4 Jun 2010 12:32:32 -0700 (PDT), Botticeli
    Rack
    > is not there...
    Did you re-scan your VST folders after install?
  10. Botticeli Guest
    Message Count:
    > Rack
    > > is not there...
    Yeah Phoenix, you were right, I scanned the VST folders and now the
    player appears. Very useful sounds, Bob!
    If I use the player in "stand alone" mode, everything works perfect.
    But from inside Sonar the controls don't have presets (if i click on
    "type" shows just an empty little window). Native Instruments and the
    players from Sonar are easier to use, or maybe I should keep on
    reading the manual.
    Now, the more players I add, the more CPU the computer uses, and...
    the more risk of a crash?
    Thanks a lot for your advise!
    Boticelli
  11. Botticeli Guest
    Message Count:
    > > Rack
    > > > is not there...
    > reading the manual.
    > Boticelli
    The Proteus VX is now fully working. I really like the sounds and
    specially that you have some editing choices.
    It works quite different from the other players, but I went to youtube
    and got a visual clinic and things are working.
    Thanks again!
    Botticelli
  12. Bob Donald Guest
    Message Count:
    Great! Yeah, I was pretty impressed with it, but I have simple needs for
    keyboards. I never thought of looking for a tutorial or clinic on youtube,
    great thinking! I'll have to check that out.
    Bob
    Thanks again!
    Botticelli
      • Advertising
Share This Page
