Lost audio output
Discussion in 'alt.steinberg.cubase' started by plewto@gmail.com, Nov 24, 2009.
  1. Guest
    Message Count:
    I have a fairly fresh cubase AI4 install on Dell laptop under Vista
    with a Yamaha Audiogram 6 USB "card". I am not too familiar with
    cubase (or vista for that matter) and trying to simply record about 2
    minutes of stereo. My initial attempts at recording worked with the
    exception of a few "stutters" during playback. While trying to solve
    that problem I somehow lost the ability to playback audio entirely.
    I know it is not a hardware issue since other programs (Audacity)
    playback fine. I'm am also sure the cubase audio track contains data;
    while playing back the software VU meters are active but not hardware
    lites on the Yamaha card.
    The ASIO audio device window in cubase shows output as "inactive" .
    Clicking "control panel" shows both "Speakers (High definition Audio
    Device)" and "Speakers (2-USB Audio CODEC)" devices as selected. Full
    duplex is on. Any suggestions?
      • Advertising
  2. Jos Geluk Guest
    Message Count:
    Just to get the full story:
    - Which output is the audio track set to?
    - During playback, press F3. Which output channel meter shows activity?
    Jos.
    Ardis Park Music
    www.ardispark.nl
  3. Guest
    Message Count:
    > Jos.
    > Ardis Park Musicwww.ardispark.nl
    While investigating I inadvertently hit F4 brining up the VST panel
    and noticed the output port was not connected. I made the propper
    selection and resolved the problem. Seams like you should be able to
    access this from the device setup dialog. Thanks for your help jos.
      • Advertising
Share This Page
