mastering
Discussion in 'alt.steinberg.cubase' started by lancelightning, Apr 18, 2009.
  1. lancelightning Guest
    Message Count:
    I've just finished a 4th song which I'll put on my website later this
    weekend ...these will eventually go onto a cd which I'll give away at
    gigs and stuff.
    This last song was completed, though not started, on Cubase 5. I
    havn't done anything much different from the other tracks..but the
    first thing I've noticed, even from a rough mix, is that I seem to
    have a lot more headroom with C5. Which has turned my thoughts to the
    job of remixing and mastering my current project...and possibly some
    of my older stuff too.
    In the past I've simply let the process roll...mix itself as I've gone
    along if you know what I mean...probably why my last 4 song cd of a
    couple of years back suffered from what I call one-man-band syndrome.
    It was all there but it always sounded a bit home-grown.
    I even wondered about letting someone else have a stab at mastering my
    stuff, but then I'd be getting away from the whole idea...besides, I
    can't really afford it...Steinberg had all my recent pocket-money!!
    I guess I just have to be patient...open each song up again from
    scratch and build the mixes up gradually. I do have a reasonable
    collection of plugins to do the job...its all a bit daunting though. I
    think I've come up with some decent songs this time so I want to get
    it right.
    Suggestions??.....LL
      • Advertising
  2. S.O.D.D.I. Guest
    Message Count:
    "lancelightning" <> wrote in message
    news:...
    > gigs and stuff.
    > it right.
    I've been coming to the conclusion that channel EQ is my best mixing weapon.
  3. Laurence Payne Guest
    Message Count:
    >it right.
    The big problem with building up songs as a one-man-band is making the
    parts "listen" to each other - something that you hope will happen
    naturally when live musicians play together.
    Maybe your present tracks should be seen as the completion of the
    composing process. Now you know how the song goes, re-record playing
    each part using sounds, dynamics (and notes) that fit in with what you
    now know to be the whole. If all these are chosen well you'll have
    very little mixing to do.
    This doesn't take as long as you might imagine.
    CubaseFAQ page: http://www.laurencepayne.co.uk/CubaseFAQ.htm
  4. Laurence Payne Guest
    Message Count:
    On Fri, 17 Apr 2009 20:12:45 -0400, "S.O.D.D.I." <>
    A thought.
    For hundreds of years live, unamplified ensembles have balanced
    perfectly without e.q.
    Why do we see it as standard practice to record tracks that require
    correction?
  5. Bas Guest
    Message Count:
    On Sat, 18 Apr 2009 11:10:13 +0100, Laurence Payne
    >A thought.
    >correction?
    I think it's because we can 'improve' upon the natural sounds.
    Each sound has in it something very beautiful and very ugly.
    By enhancing beauty and/or diminishing ugliness we can position it
    better in the whole, thereby creating room for other sounds, or making
    the sum sound more 'open'. Take a female voice, for example.
    By cutting everything under, say, 125 hZ, you eliminate nothing but
    noise, which allows you to make it more legible and thus creating a
    better mix.
  6. Swanny Guest
    Message Count:
    > A thought.
    > correction?
    Because microphones and ears are not the same.
  7. Jos Geluk Guest
    Message Count:
    > A thought.
    > correction?
    Classical orchestras have been around for long enough to adjust and
    fine-tune their playing, to the point that it most often sounds good.
    Rock bands have only been around for a few decades, have known vastly
    different instruments and a much wider range of dynamics. Would it be
    fair to say we're still only learning how they should sound?
    Regards,
    Jos.
    www.ardispark.nl
  8. S.O.D.D.I. Guest
    Message Count:
    "Laurence Payne" <> wrote in message
    news:eek:...
    >>weapon.
    > A thought.
    > correction?
    Because of digital. I rarely use heavy EQ on any synth stuff coming out of
    my analog mixer, but at this point I work almost exclusively in the VST
    realm.
    I know that the VST synth tracks, samples and cut n pastes that I use tend
    to individually soak up a lot of the audio spectrum - or
    everything-all-at-once. Great solo'ed - mushy in the mix. It's simply the
    nature of the beast.
    I don't so much correct them as beat them into submission. With EQ.
    For instance, I have hundreds of cymbal samples that I can use in
    Directwave. I have found that many of them (most of them) tend to sound
    shrill and brittle if I don't cut the high end. Even my kick drum samples
    seem to have a lot of high end.
    And the resonant peak of a VST synth bass may occupy the exact frequency
    spectrum that those cymbal samples occupy. The bass sounds less punchy. Pull
    down the highs, punch up the bass.
    If I generate a complex loop out of a lot of elements in another program and
    bring it into Cubase, I will need to make the decision where I want it to
    sit in the mix. The everything-all-at-once rule really applies here because
    many of the loops consist of multiple disparate elements.
    VST distortion plug-ins tend to add a lot of high frequency grzzz to the
    track.
    In the end, it all depends on how I think it sounds. My ears are pretty
    good - better than my equipment. I want space and air in my mixes now.
    I consider EQ to be the very last part of the the synthesis chain.
    But I am a barbarian and I am using Cubase exactly wrong - sometimes on
    purpose.
  9. Laurence Payne Guest
    Message Count:
    On Sat, 18 Apr 2009 13:35:33 -0400, "S.O.D.D.I." <>
    Could you be choosing the wrong sounds? Along with the "impressive"
    solo voices, many sampled instruments have sounds designed for
    ensemble use too. Though they ALL need the reverb turned off :)
  10. S.O.D.D.I. Guest
    Message Count:
    news:...
    Aside from "hard" sampled drums and the occasional bass line, I program
    everything. And nothing gets put down untweaked, I like programming, it's
    part of my process. My best VST instruments are those with lots and lots of
    tweakable parameters.
    Yours is a very good tip. I will think ahead when programming.
    You know what's another ubiquitous effect that needs to be turned off?
    Chorus.
  11. lancelightning Guest
    Message Count:
    On Sat, 18 Apr 2009 10:54:13 +0100, Laurence Payne
    >>it right.
    Laurence,
    I do know what you mean about 'parts listening to each other' and yes,
    'completion of the composing process' sums it all up very well at this
    stage. In some ways, it might be better to get the guys in our live
    band to go into a studio to get some real interaction. However I can't
    justify the time or the money to go down that route...and, to be
    honest, I am rather enjoying the process as it is. I reckon I can make
    a decent enough job of it with a bit of patience.
    I don't know that re-recording the songs again from the ground up is
    the right way to go. After all, it would still be one man performing
    all the parts. I am generally quite happy with the overall feel and,
    given that it is rock orientated, I don't want my songs to sound too
    perfect if you know what I mean. There is an element of spontaneity in
    there which I definitely want to keep. To my ears its more about
    polishing the whole thing up - eq'ing and balancing the songs so that
    they sound right one after the other.
    Hindsight being what it is though, I do intend to revisit some of the
    parts and rework/enhance them before attempting any kind of final mix.
    Its just a matter of how far to take it I guess...There is always the
    danger of working the songs to death.........LL
  12. Laurence Payne Guest
    Message Count:
    What I was suggesting was that you leave the notes and feel alone,
    just replay the parts with more attention to dynamics (softer-played
    notes have different transients and tone, they aren't just loud ones
    with the fader down) . And maybe modify some sounds so that remedial
    eq isn't necessary.
  13. lancelightning Guest
    Message Count:
    On Sun, 19 Apr 2009 22:31:18 +0100, Laurence Payne
    >eq isn't necessary.
    What you say makes good sense...a more relaxed approach to some of the
    guitar parts in particular would probably help. Some of the solos
    happen by accident and are a bit frantic! So, yes, I'll keep working
    at it. I could probably enhance and sweeten up some of the vocals too.
    Its very hard to hear things objectively when you're working alone so
    I do appreciate your suggestions. At the end of the day my project is
    a fun thing...my quest for record deals and the likes ended 25 years
    ago...but the creative juices are still flowing. Its great going out
    playing covers as I do...give em what they want and all that...but I
    really do enjoy putting a few original songs together now and then.
    Cheers..........LL
  14. Terry Cano Guest
    Message Count:
    "when you are working alone"
    Actually that is a big problem these days for all of us.
    In BC (before computers) you had a composer, arranger, producer , engineers,
    musicians, copyist....
    there were lots of ears and eyes and suggestions. These days usually one
    person wears all the hats.
    For me, I keep a few people around that I hire to work on projects and also
    use as a sounding board
    from time to time. I'm always amazed and sometimes embarassed when I hear
    "Gee I'm surprised you missed
    the Guitar out of tune...or did you hear that "click..sounds like a bad
    edit"
    Here in LA every working composer/producer I know has several people they
    relie on.
    Later
    Terry
  15. lancelightning Guest
    Message Count:
    On Tue, 21 Apr 2009 23:44:23 -0700, "Terry Cano" <>
    >edit"
    >relie on.
    >Later
    >Terry
    Terry...That is indeed the problem. I do have a couple of people I can
    run things by...trouble is they aren't alaways around when I need
    them. I thinks its a matter of being patient and maybe leaving things
    a while to rest my ears. Like you say, when working alone, its so easy
    to miss something really stupid. When I listen back to my older stuff
    I think..yep its all there, its ok, but why the hell did I do this or
    that...or not change the sound of that guitar or whatever!!...All part
    of the fun I guess..........LL
  16. Terry Cano Guest
    Message Count:
    The "rest my ears" is important also. I try to put two days between the
    first rough mix and coming back to finish it.
    I like what you said "all part of the fun" it is still fun to me and you
    also.
    That is why we do it.
    Musically
    Terry
  17. S.O.D.D.I. Guest
    Message Count:
    news:eek:...
    >>engineers,
    >>also
    >>edit"
    >>relie on.
    >>Later
    >>Terry
    "Honor your mistakes as hidden intentions." An Oblique Strategies card.
  18. lancelightning Guest
    Message Count:
    On Mon, 27 Apr 2009 12:50:00 -0400, "S.O.D.D.I." <>
    >news:eek:...
    >>>engineers,
    >>>also
    >>>edit"
    >>>relie on.
    >>>Later
    >>>Terry
    Ah yes, but to quote an old chestnut..'you can coat it in gold, but a
    turd is still a turd'
    I think I'll go with your OS card!!
    LL
  19. lancelightning Guest
    Message Count:
    It is fun. We all moan sometimes, but Cubase has, for me, been the
    best thing ever. Back in the days when I was writing and recording
    with an ambitious band, it would have cost a small fortune to be able
    to achieve what we all take for granted now. After the band broke up
    at the end of the 80's, I'd more or less given up on doing any more
    recording and was getting by playing covers. A friend got me clued up
    with pc's around '99 and then I discovered Cubase. These days its just
    for fun, but its still really satisfying when something comes together
    as it should......LL
    >also.
    >Musically
    >Terry
  20. Terry Cano Guest
    Message Count:
    Where can I find those cards ; )
    I like that thinking.
    Terry
      • Advertising
Share This Page
