micro ensmble / K2000 question
Discussion in 'alt.music.synth.kurzweil' started by Yuval, Dec 22, 2003.
  1. Yuval Guest
    Message Count:
    I'm thinking of buying either a K2000 or a Micro Ensemble. Does anyony
    have any experience and can tell me how they compare?
    Thanks,
    Yuval
      • Advertising
  2. Michael Houston Guest
    Message Count:
    K2000 (no longer in production, as I'm sure you are aware) is a
    workstation. Sounds by today's standards are so-so, but are editable.
    Also you can load (& edit if you like) new sounds if you have sample
    RAM installed. Also (if you have the latest OS) you can install
    sounds designed for the K2500/K2600. Also you can sample if you have
    the sampling option. Also you can sequence. It's a workstation.
    KME61 has fresh new samples built in, but it's essentially a
    sample-playback machine. Can't really edit sounds, can't use samples,
    can't sequence. Sounds pretty nice, though.
    Hope that helps.
    >Thanks,
    >Yuval
    Michael Houston
    musicianmike at cox dott net (you know what to do)
  3. Ralf Wittert Guest
    Message Count:
    > workstation.
    So, if you are sequencing on an external computer, it is in a way more
    useful to buy the cheeper machine, but think: If you are working seriously,
    you m u s t have the ability of sound post-pro. The preset sounds are
    never 100% satisfying.
    The K2 (or K25/26) ist a real synth, and with a sampling option you've got
    a complete system. You can always optimize your sounds and develop a
    personal sound style. On a KME61 you will always sound like your machine
    wants you to.
    Little Problem: The 24 voices of the K2000 are too few. The k25 or 26 will
    be better.
    Have a nice Xmas time and a good new year.
  4. Yuval Guest
    Message Count:
    Thanks for your replies. I wasn't very clear - the two are quite
    different, but a used K2000 costs about the same as the KME-1. I have
    just bought a used K2000, and I'm sure I will enjoy it.
    Yuval
    Ralf Wittert <> wrote in message news:<>...
    > > workstation.
    > wants you to.
    > be better.
      • Advertising
Share This Page
