There is an opton in midox to use "midi mapper" as an output. There isn't much info on it that I can find and what there is refers mostly to older os. Is it of any use and is it part of XP? Thanks
gray asphalt was gettin' jiggy wit' it on 9/26/2010 at 9:22:06 PM and now feels very oogly boogly: > There is an opton in midox to use "midi mapper" as an output. There > isn't much info on it that I can find and what there is refers mostly > to older os. Is it of any use and is it part of XP? Thanks > Yes, it is of use. Start; Control Panel; Sounds, Speech, and Audio Devices; Sounds and Audio Devices; Audio (tab); MIDI music playback This would be your system setting instead of MIDI-OX. I have MIDI-OX but don't know where that option is. Probably because I don't use it. If I need something like that I use a very small and simple app called MidiThru. HTH -- On the flipside, BennyG
