Midi recording while recording is off
Discussion in 'alt.steinberg.cubase' started by Jos Geluk, Nov 16, 2009.
  1. Jos Geluk Guest
    Message Count:
    Hi,
    I frequently record a few bars of MIDI, then play back what I recorded,
    then move on to the next bit. Let's say I have the locators 4 bars
    apart, in loop mode, and when I'm done, I set them to the next 4 bars. I
    notice that frequently Cubase records the notes that I play even when
    recording is off. That's right: the red recording light is off, yet the
    notes appear in the editor, and stay there as if recorded. And sometimes
    even when playback is stopped, notes that I play appear in the editor at
    random points in time (but between the locators).
    This is of course very annoying. What sometimes helps is to stop
    playback, rewind to before the left locator, and restart playback. But
    that doesn't always help, and it's a nuisance. I noticed this behaviour
    in Cubase 2SX, but I would imagine they had it sorted in Cubase 5.
    This is obviously a bug. Does anyone recognize it? Is there anything
    that helps?
    Thanks,
    Jos.
    Ardis Park Music
    www.ardispark.nl
      • Advertising
  2. Hueyduck Guest
    Message Count:
    Jos Geluk a écrit :
    >I
    I Jos
    Could it be the "retrospective record" function that you are mistaking
    for a bug?
    You might look up "retrospective record" in the manual.
    > that helps?
    I it is indeed this function that's annoying you,
    setting the Retrospective Record buffer to its minimum should help a lot ;-)
    (preference/record/midi)
    Tell us...
    Huey
  3. Hueyduck Guest
    Message Count:
    Hueyduck a écrit :
    This sentence sounds a bit aggressive. I did'nt mean to be so :)
    and... there, please read:
    [*If* it is indeed this function that's annoying you,]
    Huey
  4. Jos Geluk Guest
    Message Count:
    Hueyduck schreef:
    > Jos Geluk a écrit :
    >> I notice that frequently Cubase records the notes that I play even
    >> when recording is off. That's right: the red recording light is off,
    >> yet the notes appear in the editor, and stay there as if recorded. And
    >> sometimes even when playback is stopped, notes that I play appear in
    >> the editor at random points in time (but between the locators).
    > I Jos
    > for a bug?
    >> that helps?
    Thanks Huey. I know about retrospective record. I had it turned on,
    however, I was under the impression that you had to manually recall the
    notes played during playback, by pressing Shift+*. Instead the notes are
    appearing of themselves as I play them.
    Anyway I turned off retrospective record, and for now the notes no
    longer get recorded, but then it wouldn't always happen before. So we'll
    see. Thank you again. And no, I didn't take your advice as an act of
    aggression, and I saw through your typo as well. No problem there:)
    Jos.
    Ardis Park Music
    www.ardispark.nl
      • Advertising
Share This Page
