Moving tracks (slightly)
Discussion in 'alt.steinberg.cubase' started by djaames, Nov 6, 2010.
  1. djaames Guest
    Message Count:
    How do you move tracks over just a bit. Cubase only allows you to move
    them by interval, and the closest I get is when changing the top meter
    to 60fps, but even then I can't move it fluidly. When I'm trying to do
    precision editing, this becomes a real problem. Does anybody know how
    to move tracks without Cubase dictating where they go?
      • Advertising
  2. Mr.Will Guest
    Message Count:
    "djaames" <> wrote in message
    news:...
    You can turn off the "snap to" option completely, for the last few years the
    various versions have this function as a switch on/off button on your
    panel.....
    Mr.Will
  3. Jos Geluk Guest
    Message Count:
    Events on a track have a "start" and "end" time measured by default in
    bars/beats. If you set the time unit to "samples", you can move events
    by 1 sample at a time, by adjusting the start sample number.
    If you want to move all events on a track by specified amount, there is
    a "delay" parameter in the Inspector column on the left, which claims to
    be in milliseconds (but allows for two decimals, which I find hard to
    believe).
    Jos.
    Ardis Park Music
    www.ardispark.nl
      • Advertising
Share This Page
