my Audiophile 2496
Discussion in 'alt.steinberg.cubase' started by Gill Smith, Feb 18, 2010.
  1. Gill Smith Guest
    Message Count:
    all checks, including Dr. Norton's Checkit Diagnostics insist that the card
    is working properly
    and it does, except no recording abilities, even with Windows
    I'm puzzled by rave reviews for this card, as it can't play MIDI
    and VST/Soundforge sounds exactly the same as with my ancient SBlaster,
    which I've now reinstalled
    I think I'll re-sell the Audiophile but do I first accuse the guy of selling
    me a dud????......
    http://www.gillsmith999.plus.com/
      • Advertising
  2. XODDI Guest
    Message Count:
    "Gill Smith" <> wrote in message
    news:...
    > card is working properly
    > selling me a dud????......
    No. The Audiophile is a decent prosumer entry-level sound recording card and
    the SoundBlaster is a gaming-oriented card.
    It sounds like it wasn't what you expected.
    As far as "sounds the same" - how can you tell? What is your monitoring set
    up?
  3. Laurence Payne Guest
    Message Count:
    On Thu, 18 Feb 2010 12:54:03 -0000, "Gill Smith"
    >is working properly
    >me a dud????......
    If it really won't record, maybe you've got a dud. But I bet it will,
    if you feed some audio in :)
    Have you got round to telling us what version of Cubase you own? Maybe
    there are virtual instruments available - which the Audiophile will
    handle much better than the SB.
    If you were led to believe that the Audiophile had onboard sounds, you
    might have grounds for returning it.
    CubaseFAQ page: http://www.laurencepayne.co.uk/CubaseFAQ.htm
  4. Gill Smith Guest
    Message Count:
    "Laurence Payne" <> wrote in message
    news:...
    >>card
    >>is working properly
    >>selling
    >>me a dud????......
    tried that too, still nothing
    as I said, even Windows doesn't recognise any recording abilities (i.e. the
    microphone test)
    SX3
    but I don't want to start buying any sware for Audiophile, seeing its
    existing shortcomings
      • Advertising
  5. John Bleichert Guest
    Message Count:
    On 2010-02-19, Gill Smith <> wrote:
    <snip>>
    > SX3
    You *did* install the m-audio driver, right? Does the m-audio
    software/driver set have a control panel to display card status?
    The heat from below can burn your eyes out!!
  6. Laurence Payne Guest
    Message Count:
    On Fri, 19 Feb 2010 13:16:59 -0000, "Gill Smith"
    >SX3
    OK. Well, if you made extensive use of the SB's onboard MIDI synth
    and those sounds met your requirements, there seems little reason to
    change from it.
  7. Laurence Payne Guest
    Message Count:
    >microphone test)
    What microphone? There's no microphone input on the Audiophile.
    What you have is a low-cost, good quality sound card that does a
    simple job very well. It gets audio in and out of a computer. The
    connections are designed for Line level signals. If you want to use a
    microphone you'll need an external preamp or mixer. The sort of cheap
    microphone that plugs into a SB has no place in this sort of setup.
  8. Gill Smith Guest
    Message Count:
    "XODDI" <> wrote in message
    news:...
    > news:...
    but that's the problem: it doesn't record
    the card should register an audio input when connected to a microphone, no
    matter how crummy
  9. Gill Smith Guest
    Message Count:
    "John Bleichert" <> wrote in message
    news:...
    > <snip>>
    >> SX3
    it plays everything, even records MIDI
    and Windows and Checkit say that the device is working properly
  10. Gill Smith Guest
    Message Count:
    news:...
    >>the
    >>microphone test)
    but no matter how crummy, its audio output surely has to be recognised by
    Audiophile's audio input
  11. Laurence Payne Guest
    Message Count:
    On Sat, 20 Feb 2010 15:22:23 -0000, "Gill Smith"
    Have a look about a quarter of the way down this page
    http://www.epanorama.net/circuits/microphone_powering.html
    The cheap microphones that work with SoundBlasters use a 3-contact
    mini-jack plug. Tip is signal, sleeve is ground. But ring is for 5v,
    delivered by the SB to power the microphone. If this voltage is not
    supplied (and whatever adapters you put between the mic and the
    Audiophile's Line In, you won't get it) the mic won't deliver any
    sound.
    If you can find a dynamic mic (which requires no power) or an eletret
    condenser mic with its own battery, you might get SOME response if you
    shout loudly, though the Line In is designed for signals of a
    considerably higher level.
    The best way to test your card would be to take Line Out (maybe called
    Tape Out or Aux Out) from a hi-fi amplifier as your source. The fact
    that this signal is typically supplied on a pair of phono sockets,
    matching the input sockets of your Audiophile, are a strong clue that
    they might match :)
    You can turn two ways now. Back to the SB and its onboard MIDI synth.
    Or on to a much wider range of MIDI-controlled sounds, better quality
    microphones... If you want to record "live" you'll need to add a
    mixer or preamp plus a microphone. Both remarkably cheap these days.
    If you want to expand into software synthesis and sampling, probably
    your best move would be to upgrade to the full version of Cubase 5
    which includes several "instruments".
    Any reasonably new computer will cope. But it might be an idea to
    post the spec. here, in case yours isn't up to it.
    You don't HAVE to go onward and upward :) There's plenty of good
    music can still be made on the SB.
  12. Laurence Payne Guest
    Message Count:
  13. John Bleichert Guest
    Message Count:
    <snip>
    You do realize you didn't answer my question, right? I don't give a
    f*ck what any non-m-audio utility says about it, and neither would
    m-audio if you wisely asked them for support.. "It's working fine as
    some silly sound card" is not equal to "it's working fine as a 2496".
    Also LP's points about line-level mics vs. that crap you buy for
    speaking into Skyp are critical.
  14. John Bleichert Guest
    Message Count:
    ><snip>
    Oops - hit send to early - good luck sorting it out, harware probs
    suck. Remember that the 2496 is more than a standard sound card so w/o
    the manufacturer's drivers you may not get all of it.
    JB
  15. Gill Smith Guest
    Message Count:
    news:...
    > sound.
    > they might match :)
    whoa, you've been doing more work than me!
    I'll have to re-install the Audiophile card, prolly Tuesday and see what I
    can see
    the spec below is extracted from the Belarc programme
    many thanks for your help
    I'll remember you when I make it big in the music
    biz......................................................................................
    Operating System System Model
    Windows XP Home Edition Service Pack 3 (build 2600)
    Processor a Main Circuit Board b
    2.20 gigahertz AMD Athlon 64
    64 kilobyte primary memory cache
    512 kilobyte secondary memory cache
    64-bit ready
    Not hyper-threaded Board: ASUSTeK Computer Inc. K8V-MX Rev 1.05
    Bus Clock: 200 megahertz
    BIOS: American Megatrends Inc. 1006.003. 07/09/2004
    Drives Memory Modules c,d
    80.02 Gigabytes Usable Hard Drive Capacity
    47.02 Gigabytes Hard Drive Free Space
    SONY DVD RW DW-D22A [CD-ROM drive]
    WDC WD800BB-55JKC0 [Hard drive] (80.03 GB) -- drive 0, s/n WD-WCAMDA442913,
    rev 05.01C05, SMART Status: Healthy 448 Megabytes Usable Installed
    Memory
    Slot 'DIMM0' has 256 MB
    Slot 'DIMM1' has 256 MB
    Local Drive Volumes
    c: (NTFS on drive 0) 80.02 GB 47.02 GB free
    Network Drives
    None detected
    Users (mouse over user name for details) Printers
    Lexmark 510 Series on USB001
    Controllers Display
    Standard floppy disk controller
    Primary IDE Channel [Controller]
    Secondary IDE Channel [Controller]
    VIA Bus Master IDE Controller None detected
    Bus Adapters Multimedia
    VIA Serial ATA RAID Controller
    VIA Rev 5 or later USB Universal Host Controller (4x)
    VIA USB Enhanced Host Controller Creative Sound Blaster AudioPCI (WDM)
    Game Port for Creative
    Virus Protection [Back to Top] new Group Policies
    avast! antivirus 4.8.1335 [VPS 090810-0] Version 4.8.1335
    Virus Definitions Version Up To Date
    Realtime File Scanning On
    None discovered
    Communications Other Devices
    SoftV92 Data Fax Modem
    Networking Dns Server: 192.168.1.1
    VIA OHCI Compliant IEEE 1394 Host Controller
    USB Human Interface Device
    Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
    HID-compliant mouse
    USB Root Hub (5x)
  16. Gill Smith Guest
    Message Count:
    news:...
    > Just listened to "Winterlude" on your web page. Nice ideas, but I
    > think you WOULD enjoy using more subtle sounds than those provided on
    > the SB.
    that track is due for major musical surgery - indeed if I hadn't been so
    busy recently, it would already be history!
    > "Southern Waters" - well, you sing much the way I do. Luckily there's
    > an instrument playing so we know what the tune is :)
    and that is what all this is about: I must get a singer
    and for that I need a card that does justice to a half-decent singer and mic
  17. Gill Smith Guest
    Message Count:
    news:...
    >><snip>
    that's why I spent over the odds buying card PLUS original disks
    interesting to note that the (generic) drivers SB supplies have changed
    AGAIN, so they're now Roland MPU-40 (or something!) anyway, they no longer
    support any MIDI spec, not even a much degraded one) - luckily I was able to
    locate the original drivers
  18. Laurence Payne Guest
    Message Count:
    On Sun, 21 Feb 2010 22:04:10 -0000, "Gill Smith"
    But don't use whatever's on the CD. There's bound to be a later
    driver at:
    http://www.maudio.co.uk/index.php?do=support&tab=driver
  19. Gill Smith Guest
    Message Count:
    news:...
    > driver at:
    I kid you not, I already tried their later drivers - and they didn't install
    properly!
    I'll have another go Tuesday and see if MAudio fixed the problem........
  20. Phil W Guest
    Message Count:
    Gill Smith:
    >> driver at:
    > install properly!
    > problem........
    On my PC, I haven´t encountered installation problems with the Delta
    drivers - several versions since 2005 on several instances of WinXP and
    Win7.
    The audio part of my Delta 2496 works just fine with line-level in and out.
    As Laurence wrote: if you want/need to record a mic with it, you need a mic
    preamp (either stand-alone or in a mixer) to raise the mic level to line
    level, which is what the card´s input "expects". Small preamps/mixers start
    at about 50 EUR/$ - there are even cheaper ones.
    Anyway, M-Audio does offer older driver versions for download as well!
    Just find the checkbox next to "Show older releases" and there you go... ;-)
    It´s hidden well, but it´s there!
    Phil
      • Advertising
Share This Page
