Bought an extra used synth and board. Been years (and chemo+radiation) since I installed the one in my first synth. Memory is a bit fuzzy. (chemo will do that). TIA, mes.
Don't know, but if it is like the expansion boards that the JV's use, then it should be a case of removing the expansion board plate, fitting the board, ensuring the clips are rotated 90 degrees to hold the board in place. Not forgetting to replace the expansion cover plate. Here is a link to the manual for the GR-09, but it tells you to refer to the expansion board manual for fitting the expansion board. I've not found a link for that manual. ftp://ftp.roland.co.uk/ProductSupport/Manuals/GR-09_OM.pdf On 24/12/2009 17:21, MES Jones wrote: > Bought an extra used synth and board. Been years (and chemo+radiation) > since I installed the one in my first synth. Memory is a bit fuzzy. > (chemo will do that). > TIA, mes. >
