New System Problems
Discussion in 'cakewalk.audio' started by Peter Roussy, Apr 6, 2010.
  1. Peter Roussy Guest
    Message Count:
    So I took the plunge and bought a new system from Mwave.
    Basic Ark case and P/S
    Gigabyte GA-P55-USB motherboard
    Intel i5 750 chip
    2x2gig Kingston DDR3 1600 ram
    (2) WD 750 gig caviar black drives
    GForce 220 1 gig video card (Msi)
    22" Hannspree monitor
    LG DVD RW drive
    I got everything up and running alright. I'm using winxp sp3 and I am using
    a M-Audio audiophile 2496 card. I also have a Delta 1010 I plan on
    installing as well.
    With all this new speed and power I am still getting pops in my audio using
    reaper. So I viewed my IRQ table in control panel and found that the 2496
    card was sharing with all kinds of things. This MB has 3 pci slots and no
    matter which one I use it only gives me choices of either IRQ 16, 17 or 18
    and all of these have multiple things on them. I have attached a pic showing
    the delta card currently on IRQ16 (3rd Pci slot). (Actually, this post
    wouldn't allow me to attach a pic)
    Of the research I have done so far, it doesn't seem like I can even force an
    IRQ in the BIOS because win xp will just over look it and load it where it
    wants to using ACPI.
    Does anyone know a solution or workaround for this problem. I feel like I
    just wasted a lot of money for nothin.
    Thanks
    Pete
      • Advertising
  2. Steve_Karl Guest
    Message Count:
    How many processes running in the background?
    Also run DPC checker
    http://www.thesycon.de/deu/latency_check.shtml
    .... and report the findings.
    sk
    "Peter Roussy" <> wrote in message news:inwun.911$z%6.769@edtnps83...
    > Intel i5 750 chip
    > LG DVD RW drive
    > installing as well.
    > the delta card currently on IRQ16 (3rd Pci slot). (Actually, this post wouldn't allow me to attach a pic)
    > Thanks
    > Pete
  3. Glennbo Guest
    Message Count:
    In news:inwun.911$z%6.769@edtnps83 the killer robot "Peter Roussy"
    <> grabbed the controls of the spaceship cakewalk.audio
    and pressed these buttons...
    > Intel i5 750 chip
    > LG DVD RW drive
    Some of this list is what I'm using in my new machine, (i5 2gig Kingston
    RAM) but my mobo is an Asus P7P55D, and my vid card is an Asus/nVidia
    9800GT. My audio card is an AP2496, and I'm running it in Reaper ASIO
    mode, set to 64 samples latency. Driver version 5.10.0.5074 in WinXP SP3.
    Most of my tracks are audio, with the exception of my drums which are a
    half a gig of softsynth samples, I do use a lot of FX on my tracks
    though. Are you running Reaper un-tweaked? I am. The only thing I've
    changed in the audio settings was to select M-Audio ASIO. I do run 16
    bit audio depth too, as I've never really seen an advantage to go higher
    then have to dither down. The audio rocket scientists might say you
    gotta be 24 bit or higher, but I think my mixes speak for themselves.
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  4. Peter Roussy Guest
    Message Count:
    I'm running reaper in 16 bit with asio 64 samples latency as well and I
    didn't tweak reaper at all. I'm also using the same AP2496 driver as you.
    I'm not loading this thing up at all but it still pops and clicks. I had
    this same problem in previous systems until I could get the card on it's own
    IRQ. The thing I notice about this new system is that there are a cajillion
    things using up all the IRQ's and yet some numbers are not even listed (like
    2,4,5,7,10,11,12,14,15 & 20). I tried to attach a picture of this but OE
    won't let me post an attachement to this group and I can't seem to imbed it
    in this message.
    I'm wondering what your IRQ table looks like? Is your AP2496 sharing with
    anything?
    Peter
    "Glennbo" <> wrote in message
    news:Xns9D51E7624422BBrownShoesDontMakeIt@69.16.185.250...
    >> Intel i5 750 chip
    >> LG DVD RW drive
    > ________ __
      • Advertising
  5. Peter Roussy Guest
    Message Count:
    Quite a few actually. 40, to be exact, but they aren't using hardly any
    memory or CPU. I hear other talking about doing audio while emailing,
    browsing and running video, all the while with anti virus going. I would
    like to see how many proccesses are going on in those systems.
    I D/Led the checker and found that I had no more than 1000us latency.
    "Steve_Karl" <> wrote in message
    news:hpe7d4$s8m$-september.org...
    > sk
    >> Intel i5 750 chip
    >> LG DVD RW drive
    >> using
    >> installing as well.
    >> using
    >> 18
    >> showing
    >> an
    >> it
    >> Thanks
    >> Pete
  6. Steve_Karl Guest
    Message Count:
    1000us is way high
    .... and 40 processes ... that's reduculous sloppy for any home built XP machine ... even if it's an internet box.
    Just my opinion :)
    My weakest audio PC: ( an other os partition on this machine )
    .... no more than 12us on DPC latency checker and 17 processes running.
    It's an AMD 3000+ Single core Barton core, with 2GB of ram running XP SP-1.
    ABIT NF7-s mother board.
    I never get any audio glitches that can't be addressed by just upping my latency slider
    or freezing tracks.
    Generally I can run the SP-1 OS of this pc at 1.5ms latency when cutting tracks
    and have finished projects with 80+ audio tracks, mixing at about 11 oe 12MS.
    It's a tripple boot machine.
    On "this" OS partition ( same machine ) as I write 26 processes running
    on XP SP-3 and 49us max. Over here my audio is only hobby level.
    Sure, I can have email open and record a few guitar tracks, but I'd never attempt anything
    serious.
    If I had your problem I'd:
    Reinstall the OS and do a bare bones clean install ( no windows updates and earliest
    SP you can use.) No AV nothing internet oriented and no browser newer than IE6. ... just audio software.
    Nothing but bare bones and audio software. Nothing but bare bones and audio software.
    GO into the bios and disable anything not needed for audio including any on board audio,
    wireless, ports etc. Firewire ... all OFF in the bios.
    Then retest.
    If your DPC is still up near 1000 then you've got something (hardware) begging for too much attention.
    Just my opinion.
    Check with the pros over at the real forum.
    Jim Roseberry and Scott from ADK.
    SK
    "Peter Roussy" <> wrote in message news:fZzun.1024$Z6.520@edtnps82...
    > Quite a few actually. 40, to be exact, but they aren't using hardly any memory or CPU. I hear other talking about doing audio
    > while emailing, browsing and running video, all the while with anti virus going. I would like to see how many proccesses are going
    > "Steve_Karl" <> wrote in message news:hpe7d4$s8m$-september.org...
    >> sk
    >>> Intel i5 750 chip
    >>> LG DVD RW drive
    >>> installing as well.
    >>> Thanks
    >>> Pete
  7. Glennbo Guest
    Message Count:
    The killer robot "Peter Roussy" <> grabbed the controls
    of the spaceship cakewalk.audio and pressed these buttons...
    > I didn't tweak reaper at all. I'm also using the same AP2496 driver as
    > you. I'm not loading this thing up at all but it still pops and
    > clicks. I had this same problem in previous systems until I could get
    > the card on it's own IRQ. The thing I notice about this new system is
    > that there are a cajillion things using up all the IRQ's and yet some
    > numbers are not even listed (like 2,4,5,7,10,11,12,14,15 & 20). I
    > tried to attach a picture of this but OE won't let me post an
    > attachement to this group and I can't seem to imbed it in this
    > message. I'm wondering what your IRQ table looks like? Is your AP2496
    > sharing with anything?
    My AP2496 is on an IRQ that is shared. I'm not at my DAW right now, but
    I'll check it when I get home. If I were you, I'd try disabling *every* on
    board peripheral, like USB, sound, parallel and serial ports. Then boot
    up, at which point both the BIOS and Windows will re-shuffle the deck of
    who gets what IRQ. If that gets rid of the pops, then I'd one at a time,
    re-enable the on board stuff.
    ________ __
  8. Sue Morton Guest
    Message Count:
    Late to the party, sorry if I missed the answers to these questions:
    Peter are you runing XP, Vista, or Win7? 32-bit or 64-bit? service
    packs? etc.
    Also, are those WD's, SATA drives? Is your BIOS set to use them as SATA
    or IDE? If your I/O is as SATA devices, look for jumpers on those
    drives that hold them to SATA I specs and remove the jumpers if so. Not
    likely to be the issue for your pops/crackles, but will help with
    overall performance if they're being held back. Lots of drives are
    still being shipped jumpered to SATA I.
    Sue Morton
    news:hpep1l$mle$-september.org...
    > 1000us is way high
    > Just my opinion :)
    > SP-1.
    > my latency slider
    > or freezing tracks.
    > cutting tracks
    > oe 12MS.
    > running
    > serious.
    > audio software.
    > any on board audio,
    > Then retest.
    > Just my opinion.
    > SK
    >> any memory or CPU. I hear other talking about doing audio while
    >> going. I would like to see how many proccesses are going on in those
    >> systems.
    >>> sk
    >>>> Intel i5 750 chip
    >>>> LG DVD RW drive
    >>>> am using
    >>>> installing as well.
    >>>> audio using
    >>>> the 2496
    >>>> and no
    >>>> 17 or 18
    >>>> pic showing
    >>>> force an
    >>>> where it
    >>>> like I
    >>>> Thanks
    >>>> Pete
  9. Peter Roussy Guest
    Message Count:
    Hi Sue
    Running win xp sp3 32 bit. Reaper 32, 16bit, 44,100hz.
    The drives are WD7501AALS Black caviar 750 GB,32megs cache. I'm using the
    SATA cables that came with the MB and the HD say right on them that
    "Master/Slave jumper not reqired for SATA". Although the documentation says
    that as "OPT1", if you jumper pins 5 & 6, 1.5 Gb/s data transfer speed
    activated. I have not done that, I guess I could try it. I did format the
    second audio drive with larger (32k) clusters. But, ya, I don't think thats
    the problem.
    Peter
    "Sue Morton" <> wrote in message
    news:hpfeia$qcj$-september.org...
    > Late to the party, sorry if I missed the answers to these questions: Peter
    > are you runing XP, Vista, or Win7? 32-bit or 64-bit? service packs?
    > etc.
    > or IDE? If your I/O is as SATA devices, look for jumpers on those drives
    > that hold them to SATA I specs and remove the jumpers if so. Not likely
    > to be the issue for your pops/crackles, but will help with overall
    > performance if they're being held back. Lots of drives are still being
    > Sue Morton
    >> 1000us is way high
    >> Just my opinion :)
    >> SP-1.
    >> latency slider
    >> or freezing tracks.
    >> tracks
    >> 12MS.
    >> attempt anything
    >> serious.
    >> and earliest
    >> audio software.
    >> on board audio,
    >> Then retest.
    >> Just my opinion.
    >> SK
    >>>> sk
    >>>>> Intel i5 750 chip
    >>>>> LG DVD RW drive
    >>>>> using
    >>>>> installing as well.
    >>>>> using
    >>>>> 2496
    >>>>> no
    >>>>> or 18
    >>>>> showing
    >>>>> force an
    >>>>> where it
    >>>>> like I
    >>>>> Thanks
    >>>>> Pete
  10. Peter Roussy Guest
    Message Count:
    I think that's what I will have to do. This morning I took the AP2496 card
    out and put in the Delta1010 to see if there was a difference. It did
    exactly the same thing. If I move the latency to 128 it seems to cure it but
    I don't think I should have to. This machine should chew up what I am doing.
    Even running a single synth will cause it to pop with the power meters in
    Reaper showing 1/2 % CPU and ram or disc use.
    So I'm thinking it must be those backgroud services that are causing this to
    happen. I will have to start cleaning it up.
    Peter
    news:Xns9D5257845449EBrownShoesDontMakeIt@81.169.183.62...
    > on
    > ________ __
  11. Peter Roussy Guest
    Message Count:
    Yes, I will have to start cleaning up. I don't thing I will reload the
    operating system but I will have to shut down these extra services.
    Where is the "real" forum?
    Peter
    > 1000us is way high
    > Just my opinion :)
    > SP-1.
    > latency slider
    > or freezing tracks.
    > tracks
    > 12MS.
    > attempt anything
    > serious.
    > and earliest
    > audio software.
    > on board audio,
    > Then retest.
    > Just my opinion.
    > SK
    >>> sk
    >>>> Intel i5 750 chip
    >>>> LG DVD RW drive
    >>>> using
    >>>> installing as well.
    >>>> using
    >>>> 2496
    >>>> no
    >>>> 18
    >>>> showing
    >>>> force an
    >>>> it
    >>>> I
    >>>> Thanks
    >>>> Pete
  12. Glennbo Guest
    Message Count:
    The killer robot "Peter Roussy" <> grabbed the controls of
    He's referring to Cake's official web forum, found here.
    http://forum.cakewalk.com/tt.aspx?forumid=5
    If you were to go over there, be aware that if you mention "REAPER",
    you will instantly be attacked by a host of hardcore Sonar fanbois.
    ________ __
  13. Peter Roussy Guest
    Message Count:
    Oh My God!
    news:Xns9D527D22274A6BrownShoesDontMakeIt@188.40.43.245...
    > ________ __
  14. Peter Roussy Guest
    Message Count:
    Well, I went int the BOIS and shut off the audio and the Lan (I left all of
    the USB on for now) and then I ran msconfig and took out everything I could
    from the startup tab. I am left with Avast (I tried to turn it off but it
    comes back), ipiont and itype (MS wireless kb and mouse), the Delta panel,
    BCU and NvCpl (again, tried but they came back). That brought the system
    processes down from 40 to 30 and now I can run at 64 samples and no pops. I
    will continue to trim but at least its working. I want to get the Lan and
    sound back if I can.
    I also ran the DPC Latency checker again. I am getting some wierd readings.
    If Reaper is running and I start it, I get readings just under 1000us but if
    I stop and restart the song in Reaper, the checker drops down to 8 or 9us
    with peaks up to maybe 50us. I know it still working because I inserted a
    synth while the song was running and noticed that the latency spiked to
    about 350us or so.
    Peter
    > on
    > ________ __
  15. Steve L. Guest
    Message Count:
    "Peter Roussy" <> wrote in news:QsLun.968$z%6.435@edtnps83:
    There's a program out there that logs what DPC does and you can possibly
    trace dowm what's causing the spikes ... I'll see if I can find it ... or
    maybe somebody can remember what it's called.
  16. polymod Guest
    Message Count:
    news:QsLun.968$z%6.435@edtnps83...
    > comes back
    Hey Pete...Poly the resident computer dummy here.
    I've always had problems with Avast and find Microsoft Security Essentials
    works just as well if not better and without the bloat.
    I think you may need to go into safe mode to uninstall Avast completely.
    Best,
    Poly
  17. Steve_Karl Guest
    Message Count:
    http://forum.cakewalk.com/tt.aspx?forumid=46
    Jim and Scott are usually very generous with their knowledge so post your questions there and someone
    ( hopefully one of them ) will grill you for more specific info.
    Jim owns and runs www.studiocat.com
    and Scott is involved with http://www.adkproaudio.com/
    Steve
    "Peter Roussy" <> wrote in message news:NBJun.957$z%6.775@edtnps83...
    > Yes, I will have to start cleaning up. I don't thing I will reload the operating system but I will have to shut down these extra
    > services.
    > Peter
    > "Steve_Karl" <> wrote in message news:hpep1l$mle$-september.org...
    >> 1000us is way high
    >> Just my opinion :)
    >> or freezing tracks.
    >> serious.
    >> Then retest.
    >> Just my opinion.
    >> SK
    >>>> sk
    >>>>> Intel i5 750 chip
    >>>>> LG DVD RW drive
    >>>>> installing as well.
    >>>>> Thanks
    >>>>> Pete
  18. Steve_Karl Guest
    Message Count:
    The LAN should be no problem.
    I'd leave the sound off as it's somewhat notorious for causing problems.
    Have you considered a dual boot?
    Have one OS for audio oly and the other for hobby audio and internet etc.
    That's the only way I can do it here and good great performance on a bare bones
    install of XP. 17 processes and that could be trimmed to 15 if the main function of this box wasn't being a GigaStudio
    farm animal.
    S
    "Peter Roussy" <> wrote in message news:QsLun.968$z%6.435@edtnps83...
    > Well, I went int the BOIS and shut off the audio and the Lan (I left all of the USB on for now) and then I ran msconfig and took
    > out everything I could from the startup tab. I am left with Avast (I tried to turn it off but it comes back), ipiont and itype (MS
    > wireless kb and mouse), the Delta panel, BCU and NvCpl (again, tried but they came back). That brought the system processes down
    > from 40 to 30 and now I can run at 64 samples and no pops. I will continue to trim but at least its working. I want to get the Lan
    > and sound back if I can.
    > I also ran the DPC Latency checker again. I am getting some wierd readings. If Reaper is running and I start it, I get readings
    > just under 1000us but if I stop and restart the song in Reaper, the checker drops down to 8 or 9us with peaks up to maybe 50us. I
    > know it still working because I inserted a synth while the song was running and noticed that the latency spiked to about 350us or
    > so.
    > Peter
    > Glennbo" <> wrote in message news:Xns9D5257845449EBrownShoesDontMakeIt@81.169.183.62...
    >> ________ __
  19. Steve L. Guest
    Message Count:
    "Steve L." <> wrote in
    news:Xns9D529C3311A8Eemailmemyemailaddy@69.16.185.247:
    > possibly trace dowm what's causing the spikes ... I'll see if I can
    > find it ... or maybe somebody can remember what it's called.
    I think this is it...
    http://www.microsoft.com/whdc/DevTools/tools/RATT.mspx
  20. Peter Roussy Guest
    Message Count:
    I may do that. I was able to cure the popping although I'm not sure exactly
    what was causing it. I will continue to configure.
    P
    "polymod" <> wrote in message
    news:4bbb97b6$0$31278$...
    >> comes back
    > Best,
    > Poly
      • Advertising
Share This Page
