Newbie needs advice about buffer settings (Cubase LE)
Discussion in 'alt.steinberg.cubase' started by spampup, Apr 16, 2007.
  1. spampup Guest
    Message Count:
    I am just getting started with computer-based recording, and I need
    help with a problem I'm having. (Buffer settings?!)
    I've messed around with cassette multitrackers in the past, but I'm a
    total newbie when it comes to digital recording, so try to bear with
    me, and PLEASE, go easy on me!
    I will be recording mainly acoustic instruments (fiddle, dulcimer,
    banjo, guitar, etc.) using a condenser mic, one track recorded at a
    time, and minimal (if any) processing. Probably four or five audio
    tracks maximum per "song". And no MIDI! (Sounds like a tough job,
    right?)
    I just installed my Focusrite Saffire interface and the Cubase LE
    v1.0.8 software on my (dedicated) laptop 3 days ago. I've managed to
    get the system up and running, to the point where I can record a track
    and then record an accompanying second track.
    I've also set up and "tuned" the laptop as advised on the MusicXP,
    Cubase "Newbie Zone" and Sweetwater sites. Seems to work fine!
    I guess I figured that given the relatively low demand my recording
    needs would place on my system, I wouldn't need to mess around much
    with changing the default program settings. But Noooo!
    Here is my problem:
    I can record, play back and overdub tracks with no problems at all, as
    long as I select sample rates of 48, 88.2 or 96KHz.
    BUT If I try to record (or simply monitor the input signal) at 44.1KHz
    I hear a buzzy, metallic distortion overlaying the signal, which
    varies with signal level.
    There seems to be no difference whether I use 16-bit or 24-bit format,
    the distortion is there as long as I am set to 44.1KHz. There is no
    noise if no signal is present.
    I have a hunch my problem is related to "buffer settings" and
    "latency", but I am TOTALLY stumped about how to proceed with making
    the proper adjustments!
    I am not usually timid about experimenting with computer and software
    settings, but I am so unfamilliar with this area that I really need
    advice before proceeding, so I don't really screw something up! I Know
    this should be really simple, but I'm so frustrated and I really need
    basic guidance!
    I've read the Saffire setup and users guides (absolutely no mention of
    buffer settings). I've read the Cubase LE Getting Started guide, and
    It does mention where to change the settings, but isn't specific
    enough, and I'm still confused and intimidated! I've also checked the
    Focusrite website and the Steinberg Knowledge Base, and both were
    shockingly unhelpful! Read on...
    HERE is why I am confused:
    If I open the Cubase LE Device Setup/VST Multitrack panel here is what
    I see:
    http://i54.photobucket.com/albums/g104/timepup/CubaseDefaultBufferSettings.jpg
    Basically, I see three possible places to change buffer settings or
    adjust various settings (the main Device Setup window, the Focusrite
    ASIO Control Panel, and the "Expert settings" window). But all three
    appear to allow adjustment of completely different parameters!
    The main window gives me a choice of "Number of Disk Buffers" (ranging
    from 3-12) and "Disk Buffer Size" (six choices, 32KB to 256KB).
    The Focusrite ASIO Control Panel allows selection of "FireWire Buffer
    size" (ranging from .5ms to 20.0ms) and "ASIO buffer size" (4.0ms to
    40.0ms).
    (The Expert Settings window also allows various settings to be
    changed, but I don't think I need to mess with those.)
    The Focusrite ASIO Control Panel is the ONLY place I see any
    "indication" or display of an actual latency figure.
    (It shows "Input Latency" of 11.6ms and "Output Latency" of 15.5ms
    with my current, "default as installed" program settings.)
    Now...the various tutorials I've seen on the web all discuss changing
    "buffer size" to achieve lowest latency, but THEY ALL DEFINE BUFFER
    SIZE IN TERMS OF "SAMPLES"! (As in 256 samples, 512 samples, and so
    on.)
    I don't see anywhere in the Cubase control settings to select a buffer
    size in "samples"! I only see units of "KB" and "ms"!
    So ANYWAY, how should I proceed to solve the "buzzy distortion at
    44.1KHz" problem?
    Which "buffer settings" do I need to change to "lower my latency"?
    Looking at my default program settings (and the various possible
    adjustments shown above), any advice as to what YOU would change to
    optimize my setup?
    Also... When folks discuss lowering latency, they generally advise
    shooting for a figure around 5ms or lower. Are they talking about the
    "input latency", "output latency" (see above) or both added together,
    or even some other value? How does one generally "find" what the
    latency of a system is?
    I am really sorry about the length of this post! I probably sound a
    bit desperate, but I KNOW that the concept of latency should be simple
    (even if optimizing latency in a given system might not be) and I hope
    I'll look back on this next week and laugh.
    And I don't even know for sure yet if improper buffer settings are the
    cause of my problem!
    Thanks so much for any advice or wisdom (or wit!).
    Ken
    _________________
    Dell Inspiron 5150 laptop
    Intel Pentium 4 @ 3.02GHz (Hyperthreading)
    1.25 GB RAM
    60GB HD (4200RPM, 80MB cache)
    Windows XP Professional
    Focusrite Saffire FireWire interface
    Cubase LE 1.0.8
    Audio-Technica AT4050 microphones (pair)
      • Advertising
  2. Aphelion Guest
    Message Count:
    On 15 Apr 2007 17:36:55 -0700, "spampup" <> wrote:
    Hey Ken, nice detailed post.
    I'm replying after relevant sections of your message.
    >right?)
    >Here is my problem:
    Ok, this may or may not be latency related, some audio drivers are
    written so they only support certain rates at certain buffer settings,
    Truthfully, this shouldn't happen were the Focusrite audio drivers
    mature.
    M-Audio cards/drivers come to mind.
    >basic guidance!
    >I see:
    Don't need to mess with these.
    >40.0ms).
    Here's where you will change the buffer settings.
    I would try the Firewire buffer first, try it at it's next highest
    setting. If the result is the same set it back to the original value.
    Next, try the ASIO buffer, again, set it to it's next higher setting,
    see if that doesn't get rid of the distortion.
    There's one other setting that will could affect this.
    When changing sample rates, the Focusrite may be losing sync with
    it's internal clock. Do you have access to the Focusrite control panel
    outside of Cubase LE? First setup the Focustire panel at 44.1, locked
    to internal clock (should be default). Then boot into Cubase and see
    if the distortion is still there. If so... do the buffer setting dance
    above.
    No change here either.
    >on.)
    Same measurement... a 512sample buffer = 10.6ms at 48 and 11.6 at
    44.1.
    This problem is probably not caused by needing a higher or lower
    latency, but rather an incompatibility between some sample rates and
    buffer sizes.
    Either that or the clock problem mentioned above.
    >optimize my setup?
    That's if they're monitoring in "real time" through the software.
    I believe you're using the Focusrite's direct monitoring feature...
    Is that right?
    Ap
  3. spampup Guest
    Message Count:
    THANKS for the reply, Aphelion,
    This stuff is starting to make sense to me now. I wonder if you could
    clear something up for me (see quote below)...
    >http://i54.photobucket.com/albums/g104/timepup/CubaseDefaultBufferSet...
    What is the effect of changing the number and size of the Disk Buffers
    in the VST Multitrack panel? (They were set to 4 buffers of 128KB by
    default, and I haven't changed the settings).
    What do these buffers "do"?
    How would I know if I need to make any changes here?
    The Cubase manual states that allowing more and larger buffers here
    will "make the system run more smoothly", but at the expense of
    "higher latency". Is this "latency" the same as the latency affected
    by the FireWire buffer size and ASIO Buffer size in the Saffire
    control panel?
    Thanks again for any Info!
    Ken
  4. Aphelion Guest
    Message Count:
    The performance meter isn't showing continuous disk overloads is it?
    Often the disk meter will blip into the red if you're playing audio
    and scroll, or when the sequencer starts... that is NOT a problem.
    The Disk buffer settings are a hold-over from the earlier versions
    of Cubase, from a time when hard drives and processors were much
    slower and compensation had to be built into different parts of the
    software. The "Disk Buffer" settings were removed from later versions
    of Cubase SE,SL & SX. As far as I know LE is and will probably remain
    at the level of version 1.xx. Still, a very powerfull program to ship
    OEM with hardware.
    >control panel?
    I think this is a different kind of latency, and affects the overall
    feel of the program as the more and larger disk buffers that have to
    load data, the program may feel a little sluggish. (on a Pentium II
    at 350mhz) :) Don't worry about the disk buffers, default is fine.
    What about the distortion?
    Ap
      • Advertising
  5. spampup Guest
    Message Count:
    Thanks again, Aphelion,
    No, the upper (Processor Load ) section of the meter has been staying
    around 10% or less with the experimenting I've been doing (one or two
    microphone tracks at a time). Never even close to overload.
    I've never even seen the lower (Hard Disk Transfer Rate) meter turn on
    at all!
    By the way, I've added a LaCie 250GB FireWire HD to the system ("daisy-
    chained" to the jack on the back of the Saffire) since my original
    post.
    I've set the Firewire Buffer Size to .5 ms, and the ASIO Buffer Size
    to 1.0ms in the Focusrite ASIO Conrol Panel. The panel shows Input
    Latency of 2.6ms and Output Latency of 3.5ms. The distortion has
    disappeared. I am not hearing any distortion as long as I set the ASIO
    Buffer Size to 9.0ms or less.
    Is there a "down side" to setting the FireWire and ASIO buffer
    settings to thier lowest settings? Or as long as there is no audible
    distortion, no clicks or dropouts, and the Performance Meters stay out
    of overload should I assume everything is OK?
    Thanks so much for the help. I've learned a LOT over the past week!
    Ken
  6. Aphelion Guest
    Message Count:
    Well... you're working your PC harder than it needs to, the lower the
    ASIO buffer the more often the buffer has to be filled and emptied
    which is a processor task. Not really sure about the firewire buffer.
    I would definitely raise the buffer a bit higher, so that your
    Input/Output latency is doubled. It's not something you're going to
    notice unless you're a concert pianist playing a VSTi instrument.
    Enjoy
    Ap
  7. Laurence Payne Guest
    Message Count:
    If it sounds good, it's good.
      • Advertising
Share This Page
