No latency issues at all - until............ please help!
Discussion in 'cakewalk.audio' started by walter, Apr 19, 2010.
  1. walter Guest
    Message Count:
    Producer 8.5. When I load ANY soft synth - all is well.... no latency
    issues...... until
    All I have to do is hit play..... and soft synths produce at least 250ms or
    more latency.
    Have to reload synth, but then same thing happens. I cannot record or
    anything.
    Anyone know what's going on?
    Thanks, Walter
      • Advertising
  2. Sue Morton Guest
    Message Count:
    Just for experimentation, can you keep increasing latency until the
    synths will play without any problems, or does the problem keep
    happening no matter how high you increase it? Can you freeze all but
    one synth to one track and will it work at some latency?
    Questions:
    1. Did this used to work before with this/these synths or has it never
    worked (e.g. this is first time trying
    2. Same problem with all synths you've tried (list them)? Or just
    these (list them)? -- Found any that work?
    3. How many tracks in your project? How many with synths? Buses?
    How do you have the routing configured into and out of the synths?
    4. What is the source of the MIDI data for your synths? E.g. typed in
    by hand, recorded via external keyboard and saved, imported from
    external midi (downloaded from web, purchased, generated by Finale,
    etc.)
    5. What changed since it used to work (if it did)? m$ updates, running
    simultaneous programs you didn't used to run, install a new program,
    installed Sonar patch, etc. etc. etc.
    6. Specs -- what OS patch level and addressing (e.g. XP Pro SP3 32-bit
    fully current via m$ update), machine (CPU, memory, disks, soundcard)?
    Any external equipment involved in this problem (mixers, audio or midi
    keyboard, etc.)
    7. Rebooted the box lately? If not, try that.
    Sue Morton
    "walter" <> wrote in message
    news:...
    > latency issues...... until
    > 250ms or more latency.
    > anything.
    > Thanks, Walter
  3. walter Guest
    Message Count:
    Hey Sue - thanks for the response........
    I looked at my original post and it couldn't be any less clear. My mistake
    for posting 4am after hours of recording/mixing.
    The latency I'm speaking of is NOT during playback. It's the latency from
    the time I hit a note on my external keyboard until it sounds out of any of
    my softsynths. They play back fine.
    If I'm recording what I'm playing - it comes out fine in SONAR - everything
    where it should be - except what I'm hearing as I'm playing it.
    Now if I load a soft synth into a project - no latency - until I hit play,
    record, etc..... then the latency. If I unload the synth and load it
    again - no latency until after I hit play, or record, etc.........
    Otherwise, I have no latency issues at all........ very happy with my gear.
    Never had this issue before, and I'm thinking it started after I went from
    SPE 8 to 8.5 - though I'm not sure.
    Problems with EZ drummer, Pentagon, PSYN, - all SONAR stuff (Z3ta)
    except for the EZ drummer.
    We're talking 15 tracks, a couple of busses - but I disabled and unload all
    soft synths once I've bounced down.
    But then, I'll open any given soft synth to add a new part, whatever, and
    all is good until I just hit play or record - and from then on - major
    latency from the time I play a note on external keyboard - even though if
    I look at piano roll all my stuff is right on - the delay is only
    audio....... the MIDI info is getting into Sonar just fine.
    Never had this problem before and no gear has changed for years other than
    upgrading to 8.5
    Thanks for your help, Sue......... I appreciated it........... Walter
    "Sue Morton" <> wrote in message
    news:hqhhrp$cbe$-september.org...
    > Just for experimentation, can you keep increasing latency until the synths
    > will play without any problems, or does the problem keep happening no
    > matter how high you increase it? Can you freeze all but one synth to one
    > Questions:
    > 2. Same problem with all synths you've tried (list them)? Or just these
    > 3. How many tracks in your project? How many with synths? Buses? How
    > 4. What is the source of the MIDI data for your synths? E.g. typed in by
    > hand, recorded via external keyboard and saved, imported from external
    > midi (downloaded from web, purchased, generated by Finale, etc.)
    > fully current via m$ update), machine (CPU, memory, disks, soundcard)? Any
    > keyboard, etc.)
    > Sue Morton
    > news:...
    >> issues...... until
    >> or more latency.
    >> anything.
    >> Thanks, Walter
  4. Peter Roussy Guest
    Message Count:
    Could it possibly be some kind of MIDI loop-back thing going on.
    news:...
    > mistake for posting 4am after hours of recording/mixing.
    > of my softsynths. They play back fine.
    > everything where it should be - except what I'm hearing as I'm playing
    > it.
    > play, record, etc..... then the latency. If I unload the synth and load
    > it again - no latency until after I hit play, or record, etc.........
    > gear.
    > from SPE 8 to 8.5 - though I'm not sure.
    > all soft synths once I've bounced down.
    > if I look at piano roll all my stuff is right on - the delay is only
    > upgrading to 8.5
    >> synths will play without any problems, or does the problem keep happening
    >> no matter how high you increase it? Can you freeze all but one synth to
    >> Questions:
    >> by hand, recorded via external keyboard and saved, imported from external
    >> keyboard, etc.)
    >> Sue Morton
    >> news:...
    >>> issues...... until
    >>> or more latency.
    >>> anything.
    >>> Thanks, Walter
      • Advertising
  5. Rick Paul Guest
    Message Count:
    Any chance you have a high latency plug-in on one of the tracks or buses
    that isn't in the signal path for the synth you're playing? (I'm thinking
    it may not affect latency for that synth when playing it without playback
    engaged, but would still have to be accounted for when the rest of the
    signal chain is going to get to the full mix during playback.) For example,
    some high latency plug-ins I can think of off the top of my head include
    PerfectSpace and PSP VintageWarmer 2.
    Rick
    Rick Paul
    Closet Cowboy Music (ASCAP)
    Web: www.RickPaul.info
    MySpace: www.myspace.com/rickpaulmusic
    news:...
    > it.
    > gear.
    > upgrading to 8.5
    >> Questions:
    >> keyboard, etc.)
    >> Sue Morton
    >> news:...
    >>> issues...... until
    >>> or more latency.
    >>> anything.
    >>> Thanks, Walter
  6. walter Guest
    Message Count:
    Guys - thanks for your help...... I figured it out, sorta
    I opened up some past projects, loaded some soft synths, and all worked
    perfect.
    Turns out this issue is only on three projects - three of which I did some
    stupid things with EZ Drummer, which caused crashes - hence can't add any
    more soft synths - for whatever reason. (Actually, I can - as long as I
    turn down the volume of said synth during recording - 'cause it records data
    correctly - just HEAR it with huge delay. Being a keyboardist for many
    years I can do this easily - don't need to hear it while I playing the
    part). So......
    No more stupid dog tricks with EZ Drummer, and I'll be fine.......
    Thanks to all of you for your help. Appreciate it.
    Walter
    > Questions:
    > keyboard, etc.)
    > Sue Morton
    > news:...
    >> issues...... until
    >> or more latency.
    >> anything.
    >> Thanks, Walter
  7. Glennbo Guest
    Message Count:
    The killer robot "Rick Paul" <> grabbed the
    controls of the spaceship cakewalk.audio and pressed these buttons...
    > buses that isn't in the signal path for the synth you're playing?
    > (I'm thinking it may not affect latency for that synth when playing it
    > without playback engaged, but would still have to be accounted for
    > when the rest of the signal chain is going to get to the full mix
    > during playback.) For example, some high latency plug-ins I can think
    > of off the top of my head include PerfectSpace and PSP VintageWarmer
    > 2.
    That's kinda what it sounds like to me. So PSP Vintage Warmer 2 is high
    latency? I'm glad I never bought it then, coz I play through Vintage
    Warmer 1 in real time, when I'm tracking guitar, bass, vocals, etc., and
    I would hate not being able to do that.
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  8. polymod Guest
    Message Count:
    "Glennbo" <> wrote in message
    news:Xns9D6057D743D8FBrownShoesDontMakeIt@188.40.43.213...
    > > 2.
    So that's your secret!
    Poly
  9. Glennbo Guest
    Message Count:
    The killer robot "polymod" <> grabbed the controls of
    >> > 2.
    Hehe, yep!
    I've gotten so used to recording while monitoring through effects, that I
    literally mix as I record. By the time I'm laying down the last track, the
    song usually has tons of effects, and is ready to export to wave and MP3.
    ________ __
  10. polymod Guest
    Message Count:
    news:Xns9D60655DA6A18BrownShoesDontMakeIt@188.40.43.213...
    it
    think
    > >> > 2.
    high
    and
    > Hehe, yep!
    the
    Interesting approach.
    Poly
  11. Glennbo Guest
    Message Count:
    >> that I literally mix as I record. By the time I'm laying down the
    >> last track, the song usually has tons of effects, and is ready to
    I find that it changes the way I play when I'm hearing the song sounding
    more produced. An extreme exaggeration of the effect would be to try
    and play a screaming feedback lead guitar solo, while playing it on a
    squeeky clean amp sound that will later be run through the screaming
    feedback amp simulator. IOW, if it doesn't sound like it's going to
    sound, then you might play or sing the part differently. Vocalists
    always want to hear their voice with some verb when singing, but why not
    just take it to the next level and produce the track to be final product
    while recording it? Provided that your computer and DAW software is up
    to the task that is.
    ________ __
  12. polymod Guest
    Message Count:
    news:Xns9D6068C49132EBrownShoesDontMakeIt@188.40.43.213...
    Very good points. I know when vocalists come over to record, they want to
    hear the effects.
    I don't care either way, but that's just personal taste. I find that I play
    much cleaner without them. If they pass the test with out the effects,
    they'll sound that much better with 'em!
    Poly
  13. Glennbo Guest
    Message Count:
    >> sounding more produced. An extreme exaggeration of the effect would
    >> be to try and play a screaming feedback lead guitar solo, while
    >> playing it on a squeeky clean amp sound that will later be run
    >> through the screaming feedback amp simulator. IOW, if it doesn't
    >> sound like it's going to sound, then you might play or sing the part
    >> differently. Vocalists always want to hear their voice with some
    >> verb when singing, but why not just take it to the next level and
    >> produce the track to be final product while recording it? Provided
    >> that your computer and DAW software is up to the task that is.
    > to hear the effects.
    > play much cleaner without them. If they pass the test with out the
    > effects, they'll sound that much better with 'em!
    I s'pose it depends on the effect. I generally am playing through
    compressors, which has an *effect* on how hard or light I pick on a guitar
    or bass, and without the effect, I tend to pick a lot harder to try and
    keep the volume more uniform, but that has a tendancy to make me play less
    clean when trying to pull off quicker segments. Playing through a
    compressor, I can bear down on less busy passages, and go with a lighter
    touch for quicker stuff.
    ________ __
  14. Sue Morton Guest
    Message Count:
    Not an approach I can take... I have too much 'fixing' to do first :-/
    Sue Morton
    "polymod" <> wrote in message
    news:4bcdc430$0$5019$...
    >> that I
    >> track,
    >> the song usually has tons of effects, and is ready to export to wave
    >> and MP3.
  15. Rick Paul Guest
    Message Count:
    PSP VintageWarmer 2 still includes the older, lower latency version of the
    plug-in. You get two plug-ins with the package so you can use the higher
    quality one when latency isn't an issue and the original one when it is (and
    for Pro Tools LE/M-Audio users since they don't have latency compensation --
    or at least didn't when VW2 was introduced).
    Rick
    Rick Paul
    >> 2.
    > ________ __
  16. Glennbo Guest
    Message Count:
    The killer robot "Sue Morton" <> grabbed the
    You could always try "Fixin' Mixin'". ;)
    ________ __
  17. Glennbo Guest
    Message Count:
    > the plug-in. You get two plug-ins with the package so you can use the
    > higher quality one when latency isn't an issue and the original one
    > when it is (and for Pro Tools LE/M-Audio users since they don't have
    > latency compensation -- or at least didn't when VW2 was introduced).
    So what's the real advantage to VW2? For me, higher latency is a
    disadvantage. The very reason I generally avoid convolution reverbs.
    ________ __
  18. Rick Paul Guest
    Message Count:
    news:Xns9D615A89B8E29BrownShoesDontMakeIt@188.40.43.213...
    There were two main things I'd originally noted as the reasons to upgrade
    from VW to VW2. One was the new 64-bit host/plug-in interface, which was
    important to me on the sound quality front given where VW was sitting in my
    mixes and that I'd gotten to the point in having other 64-bit plug-ins where
    having a 32-bit pipeline bottleneck at that point adversely affected sound
    quality. However, if you have VW2, that is not a difference between
    VintageWarmer 2 and VintageWarmer LE, which is the old, lower-latency
    version of the plug-in since VW LE also supports the 64-bit interface. The
    other is the availability of FAT on the full VW2. Here's the description of
    FAT I wrote for my PSP MasterPack review on CakewalkNet.com:
    All but one of the MasterPack family plug-ins have a button or switch
    labeled "FAT". Neon doesn't include the FAT capability, though Neon HR does.
    No, the FAT button isn't for turning on "phat" sound mode. Rather, it stands
    for "Frequency Authentication Technique", PSP's proprietary algorithm that
    uses double sampling techniques to make plug-ins using it sound even more
    analog-like. In the equalizer plug-ins, MasterQ and Neon HR, FAT reduces the
    frequency response errors introduced when digital filters are derived from
    analog prototypes. With the dynamics processors, VintageWarmer and
    Mastercomp, FAT primarily reduces aliasing artifacts in higher frequencies.
    While you will hear the difference between using FAT or not, especially at
    lower sample rates such as 44.1 kHz and 48 kHz, it should be noted that
    engaging FAT mode uses more than double the CPU resources compared to using
    the same plug-in with FAT mode turned off. As such, my general rule of thumb
    was to do most of my work with FAT disengaged, then engage it just prior to
    rendering. Whether this is necessary or not will depend on the sample rate
    and bit depth of your project, what else is going on in your project, and
    how powerful your computer's CPU is.
    In a nutshell, when you're working at 44.1 kHz or 48 kHz, it helps better
    approximate analog processing by reducing certain types of digital
    artifacts. It's pretty easy to hear the difference in sound quality with it
    on and off. PSP generally suggests it isn't needed when working at higher
    sample rates (i.e. 88.2 kHz, 96 kHz, 192 kHz).
    Rick
    Rick Paul
  19. Glennbo Guest
    Message Count:
    > upgrade from VW to VW2. One was the new 64-bit host/plug-in
    > interface, which was important to me on the sound quality front given
    > where VW was sitting in my mixes and that I'd gotten to the point in
    > having other 64-bit plug-ins where having a 32-bit pipeline bottleneck
    > at that point adversely affected sound quality. However, if you have
    > VW2, that is not a difference between VintageWarmer 2 and
    > VintageWarmer LE, which is the old, lower-latency version of the
    > plug-in since VW LE also supports the 64-bit interface. The other is
    > switch
    > does. No, the FAT button isn't for turning on "phat" sound mode.
    > Rather, it stands for "Frequency Authentication Technique", PSP's
    > proprietary algorithm that uses double sampling techniques to make
    > plug-ins using it sound even more analog-like. In the equalizer
    > plug-ins, MasterQ and Neon HR, FAT reduces the frequency response
    > errors introduced when digital filters are derived from analog
    > frequencies. While you will hear the difference between using FAT or
    > not, especially at lower sample rates such as 44.1 kHz and 48 kHz, it
    > should be noted that engaging FAT mode uses more than double the CPU
    > resources compared to using the same plug-in with FAT mode turned off.
    > As such, my general rule of thumb was to do most of my work with FAT
    > disengaged, then engage it just prior to rendering. Whether this is
    > necessary or not will depend on the sample rate and bit depth of your
    > project, what else is going on in your project, and how powerful your
    > computer's CPU is.
    > better approximate analog processing by reducing certain types of
    > digital artifacts. It's pretty easy to hear the difference in sound
    > quality with it on and off. PSP generally suggests it isn't needed
    > when working at higher sample rates (i.e. 88.2 kHz, 96 kHz, 192 kHz).
    Thanks for the rundown. Since I run Windows 32 bit, and my DAW 16 bit, and
    I primarily use PSP VW to add distortion and coloration that wasn't there
    in the digital signal, it doesn't sound like there would be any benefit for
    me to get the newer version of the Vintage Warmer. I still prefer the lean
    and mean with ultra low latency way of working.
    ________ __
      • Advertising
Share This Page
