Hi folks, long time lurker and midi user but short time Cubase user. The problem, or solution, is most likely simple and is connected to project setup. I imported a .wav to add tracks to added an instrument track using Hyper-Canvas to record a keyboard track. If I start recording, for example at 8 bars in, the first note recorded jumps back to the beginning of the track instead of where I start recording...argg. I can of course slide the completed track but sometimes some of the first notes are truncated too, but not always..argg again. After stumbling through some setup snags with my computer and my lizard brain, CuBase is running smooth and I can't believe I waited all these years before I got serious with it. Thanks all, Leo Dean, St. Simons Island Georgia www.leodean.com
Op 6-2-2010 15:44, theLeo schreef: > Hi folks, long time lurker and midi user but short time Cubase user. > > The problem, or solution, is most likely simple and is connected to > project setup. I imported a .wav to add tracks to added an instrument > track using Hyper-Canvas to record a keyboard track. > If I start recording, for example at 8 bars in, the first note > recorded jumps back to the beginning of the track instead of where I > start recording...argg. I can of course slide the completed track but > sometimes some of the first notes are truncated too, but not > always..argg again. > > After stumbling through some setup snags with my computer and my > lizard brain, CuBase is running smooth and I can't believe I waited > all these years before I got serious with it. One or both of the following may work: 1. Is Auto-Quantize on? There is a button in the Transport bar. If there isn't, right-click on the transport bar and select "Record mode". 2. In Devices/Device Setup/Midi port setup, experiment with turning "System timestamp" on or off. Does this help? Jos. -- Ardis Park Music www.ardispark.nl
On Feb 6, 10:49 am, Jos Geluk <> wrote: > Op 6-2-2010 15:44, theLeo schreef: > > > Hi folks, long time lurker and midi user but short time Cubase user. > > > The problem, or solution, is most likely simple and is connected to > > project setup. I imported a .wav to add tracks to added an instrument > > track using Hyper-Canvas to record a keyboard track. > > If I start recording, for example at 8 bars in, the first note > > recorded jumps back to the beginning of the track instead of where I > > start recording...argg. I can of course slide the completed track but > > sometimes some of the first notes are truncated too, but not > > always..argg again. > > > After stumbling through some setup snags with my computer and my > > lizard brain, CuBase is running smooth and I can't believe I waited > > all these years before I got serious with it. > > One or both of the following may work: > 1. Is Auto-Quantize on? There is a button in the Transport bar. If there > isn't, right-click on the transport bar and select "Record mode". > 2. In Devices/Device Setup/Midi port setup, experiment with turning > "System timestamp" on or off. > > Does this help? > > Jos. > > -- > Ardis Park Musicwww.ardispark.nl Ahh so, It was the "Midi timestamp" that did it and Jos., I am grateful for your help! Leo (happy camper)
Op 6-2-2010 19:41, theLeo schreef: > On Feb 6, 10:49 am, Jos Geluk<> wrote: >> 2. In Devices/Device Setup/Midi port setup, experiment with turning >> "System timestamp" on or off. > > Ahh so, It was the "Midi timestamp" that did it and Jos., I am > grateful for your help! > > Leo (happy camper) Just curious, was it on and did you turn it off, or the other way around? I have it turned off at the moment. Good to see that it works, Jos. -- Ardis Park Music www.ardispark.nl
On Feb 6, 8:07 pm, Jos Geluk <> wrote: > Op 6-2-2010 19:41, theLeo schreef: > > > On Feb 6, 10:49 am, Jos Geluk<> wrote: > >> 2. In Devices/Device Setup/Midi port setup, experiment with turning > >> "System timestamp" on or off. > > > Ahh so, It was the "Midi timestamp" that did it and Jos., I am > > grateful for your help! > > > Leo (happy camper) > > Just curious, was it on and did you turn it off, or the other way > around? I have it turned off at the moment. > > Good to see that it works, > > Jos. > > -- > Ardis Park Musicwww.ardispark.nl It was un-checked Jos and I think the auto-quantize may have been on, because that is one thing I had tried and so I just left it on. thanks again--leo
