OS 32/64 bit for Cubase 4 or 5?
Discussion in 'alt.steinberg.cubase' started by DM, Apr 19, 2009.
  1. DM Guest
    Message Count:
    Hello Group!!
    Building a i7 PC soon.. Novice qustion here, Which OS is best to Run
    Cubase 4 or 5. Right now I have XP Pro SP3 and I will upgrade to Vista
    32/64(?) bit, if only XP could read above 4 Gig of Ram I'd stayed with
    it. what's the pro's and cons between 32 and 64 bit? thanks!!
    Ka-eL
      • Advertising
  2. Rayn Guest
    Message Count:
    Same question here. Just switched to C5 and I'm now wondering which OS
    to choose...
  3. Phil W Guest
    Message Count:
    > to choose...
    For now, I´d say - if you already have a XP 32, which is very likely - stay
    with XP32 and wait for Windows7, which may hopefully come out this year.
    Vista 64 is available, but not really a good option. Win7 is looking like an
    improved version of Vista - and the beta runs even faster (on kind of "old"
    hardware) compared to Vista...
    One point is the compatibility of OS and DAW software, but just as important
    is the availability of good and stable drivers for your audio interface(s)
    of choice!
    As experience has shown, it took quite a while, until most manufacturers
    even provided Vista32 drivers.
    XP32 has been around for long enough and is proven and stable. Drivers are
    available for pretty much "anything, you can think of"... so, that´s the
    safest route to choose by now.
    Yes, there´s the 3,5 GB limit with XP32, but do you REALLY need more at the
    moment? I mean, a few years ago, even 4 GB were practically "impossible" on
    normal mainboards and people still got professional audio work done with the
    machines back then... I understand, that you want to use all RAM, you have
    installed on your mainboard and it feels stupid to limit it by using an old
    OS, but what do YOU really do, that you really *need* more than 3,5 GB of
    RAM???
    If I were to build a new computer by now, I´d install XP32 on it for now,
    wait for Win7 and get that installed, when it comes out (hopefully by the
    end of this year) - and simply "skip" Vista.
    Just my thoughts,
    Phil
  4. jtougas Guest
    Message Count:
    On Sun, 19 Apr 2009 03:19:11 +0200, "Phil W" <> trained 100
    monkeys to jump on the keyboard and write:
    >> to choose...
    I agree with Phil - Win7 is (relatively speaking) right around the
    corner, and from what I've heard, it's worth the wait.
    Also, C5 is the only one that can really take advantage of 64 bit, if
    you're gonna head that way.
    jtougas
    "listen- there's a hell of a good universe next door
    let's go" - e.e. cummings
      • Advertising
  5. Phil W Guest
    Message Count:
    jtougas wrote:
    > "Phil W" trained 100
    >>> OS to choose...
    >> - stay with XP32 and wait for Windows7, which may hopefully come out
    >> this year. Vista 64 is available, but not really a good option. Win7
    >> is looking like an improved version of Vista - and the beta runs
    >> even faster (on kind of "old" hardware) compared to Vista...
    Well, since 64 bit CPUs have been around for a while now, it´s actually
    reasonable to consider using a 64 bit OS with 64 bit software. It feels a
    bit "limiting" to use a 32 bit OS and 32 bit software on a 64 bit system, of
    course...
    In practice, the main problem is, that software manufacturers also have to
    adapt to 64 bit, to take full advantage of a 64 bit system running a 64 bit
    OS. This may take some time, until the majority of software manufacturers
    make this switch.
    As I already said, experiences with Vista has shown, that it even took a lot
    of (even "mainstream") hardware manufacturers quite a while (up to a few
    months after Vista´s official release date!) to provide new drivers for
    Vista. And this applies mainly to the 32 bit version of Vista - the 64 bit
    Vista drivers may even have come later. :-\
    I´d assume, it will be relatively the same way with most software
    applications for 32 to 64 bit. Until everything necessary is available in
    the new "format", it won´t make much sense to go for a "real" 64 bit system.
    So, the better choice will be to use 32 bit XP and apps, until this time has
    come - I hope, it will be sooner than later. Of course, you can also use
    Vista32 instead of XP, but generally said, Vista itself takes up "more
    power" on the same hardware than XP does, just to run. In other words, a
    machine running on XP32 will be "faster" than running on Vista32.
    Especially, if you´re going to use resource-demanding work, as you obviously
    are, with XP there will be more "power" or "resources" left for the actual
    applications.
    And, when you also consider to buy a new Cubase version, make sure, you get
    Cubase 5.
    If I got the Steinberg guy right, who did a C5 presentation here some days
    ago, C5 is shipping with both a 32bit AND a 64bit version in the same
    package. Therefore, you only have to buy it once and get both versions for
    one price. Then you can install the 32bit C5 on XP now and, when you upgrade
    to 64bit Win7 someday, install the 64bit C5 - without having to spend money
    on the C5 software again.
    From what I saw in the presentation, C5 has some new features, that are more
    interesting than what I saw in C4. I´m still using SX3 and still haven´t
    used all features in this version.
    Anyway, what I personally found very cool in C5, is the new "batch export"
    function for *all* kinds of tracks. That means, all (selected!) tracks
    (audio and VSTi) can be exported to individual "track mixdown" audio files
    in a single "batch" process. This makes it a lot easier - and saves a good
    amount of time, too - to make your projects audio and VSTi tracks ready for
    exchange with other folks, who use a different DAW program than C5. Just
    consider the situation, that you record a session with Cubase5, apply some
    fx, edits and automation and have to export all this (not just raw audio
    files) to individual files, which you (or your client) take to another
    studio using ProTools, Logic, DP or whatever for a mix session...
    If you have ever done this on a track-by-track procedure, you will know, how
    time-consuming it is. ;-)
    Besides that, there are some other features, that may come in handy.
    BTW: before anyone asks about using Cubase on XP64 - Steinberg does *not*
    officially support it! According to the Steinberg C5 presenter, it works,
    but if you experience problems, Steinberg won´t help you about it.
    XP64 was rather a kind of "experiment" and is generally not widely supported
    by software and hardware manufacturers. There are only very few drivers and
    apps, that were really "designed" to work properly with XP64.
    Hope that helps,
    Phil
  6. jtougas Guest
    Message Count:
    On Sun, 19 Apr 2009 05:56:02 +0200, "Phil W" <> trained 100
    >course...
    Yeah, but between the OP's choices of C4 and C5, C4 isn't running at
    true 64-bit - C5 is.
    I honestly don't know how well C4 will run as 32-bit on top of a
    64-bit system with more than the 3Gb RAM that a 32-bit OS is limited
    to. I'm sure it'd do fine, just don't know how much performance
    advantage you'd get.
    jtougas
  7. Laurence Payne Guest
    Message Count:
    On Sat, 18 Apr 2009 16:17:46 -0700 (PDT), DM <>
    wrote:
    >Hello Group!!
    >Ka-eL
    64 bit will address more memory. Do you need to? Have you got
    applications that can do anything useful with more?
    Can you transfer your existing XP pro licence to the new machine? If
    so I'd do that for now. See what happens next year when the new
    Windows has settled down.
    Actually, unless your present computer is restricting you seriously, I
    wouldn't build now. You'll be buying power that I suspect you won't
    be able to use until the next generation of software. Build then, by
    which time even more power will be even cheaper.
    CubaseFAQ page: http://www.laurencepayne.co.uk/CubaseFAQ.htm
  8. nickm Guest
    Message Count:
    "DM" <> wrote in message
    news:...
    > Hello Group!!
    > Ka-eL
    I mostly agree with Phil. Vista 64 is your only current choice if you want
    the benefits of extra RAM on the PC platform. I've had a system running
    Vista 64 Ultimate 64 bit since 30 Jan 2007, and have found it to be very
    stable and a great performer when customised by turning off a lot of the
    stuff that appeared as the diversionary 'gloss' or WOW factor, BUT there is
    the driver issue, which can be very frustrating if you have something in
    terms of an audio device that's still current, yet the manufacturer of said
    device(s) hasn't yet bothered after two and a half years nearly to provide
    64bit support for Vista despite there being a lot of demand (are you
    listening Yamaha?). I wasn't WOW'ed by User Account Control, Windows
    SideBar or the Aero interface in particular, and I was less than impressed
    that Microsoft still seem to be chasing the dream of making Windows into
    some kind of Mac OS clone. Neither was I happy that things like Add and
    Remove Programs in the Control Panel has had its name changed for no
    apparent good reason or that the Control panel itself cannot be listed in
    'Computer' (used to be called My Computer) and if you want it anywhere other
    than on the Start menu the only easy place to show it is stuck on the
    desktop. Irritations, irritations. Once most of those irritations have
    been dealt with or accepted however, 'under the hood' I think Vista has had
    a lot of work done in preparation for Windows 7 and in 64 bit format
    particularly.
    I work with computers in general for a living and needed to get a grip on
    Vista right at the start of the final release in Jan 2007 which is why I
    dived in straight away primarily, but of course I installed all my audio
    software like Cubase just to see what worked and what didn't. Very little
    software didn't work. Wavelab was a bit fussy and quite a lot of audio
    interface manufacturers hadn't even got off the starting blocks, but some
    like MOTU and Edirol had good 64bit drivers ready to roll from day one which
    shows a bit of a different attitude to some other manufacturers, and one
    which I believe has held back the move to 64bit computing for many..
    Vista 64 does not allow end users to install unsigned hardware drivers by
    default and this is responsible for a great deal of its heightened stability
    in my opinion. You can of course force Vista 64 to start with an unsigned
    hardware driver, but this can give unexpected results, and is clearly
    Microsoft's way of saying'we don't take any responsibility if you mess up
    your system, you chose to do this, and you are very much on your own'
    However having got Cubase 5 running on a recently built i7 (early Feb this
    year) with Vista Ultimate 64bit, I don't think you'd regret the move
    provided your devices are supported with drivers if you were to go down the
    64 bit road and you are prepared to turn off all the normal Vista 'out of
    the box' bloated nonsense. Within a week of me, a friend bought a ready
    built i7 system (cost his emoloyer twice as much as my system which is 95%
    identical) with 3GB RAM and XP Pro 32 bit - his system flies as does mine,
    and there's not a lot to choose between them in terms of performance. 32
    Vista has some annoying frippery, most of which you can turn off, and I
    think personally was a lot of wasted effort on Microsoft's part, and once
    that's done, Vista can be set up almost exactly like XP in terms of working
    with it. As Phil says though - unless you really need the luxury of extra
    RAM right now, I'd hold off and see what benefits Windows 7 has to offer.
    Not regretting the move to Vista 64 bit is not necessarily entirely the same
    thing as being totally happy with it either :) As it happens, for now, for
    me it does offer the best flexibility that's available, but it could be
    better, and hopefully will be when Windows 7 arrives. I am as happy as I'll
    ever be considering, that there's always part of me and people like me who
    are always curious and somewhat expectant of the capabilities of the next
    new thing. It's a weakness :) I'd say that I'm about 90% happy with Vista
    64 bit and audio work, which is pretty good.
    The reports from those who are beta testing Windows 7 are encouraging, but
    we may have to wait some time after its initial release for audio
    manufacturers to realise that users want 64 bit support. That said,
    Microsoft are stating that what runs in Vista will run in Windows 7 and that
    machines compatible with Vista will remain compatible with Windows 7.
    Whilst that may be totally true, I'll wait until Windows 7 is available
    before believing it. I haven't bothered playing with the beta yet, although
    I have downloaded it.
    Bottom line: as other have said, if you don't need 64bit right now, Vista
    won't offer you anything fundamental that XP doesn't already offer you in a
    time served, proven and familiar package. Three and a bit GB of available
    RAM should be plenty enough memory for most projects.
  9. Phil W Guest
    Message Count:
    >> actually reasonable to consider using a 64 bit OS with 64 bit
    >> software. It feels a bit "limiting" to use a 32 bit OS and 32 bit
    >> software on a 64 bit system, of course...
    It sounds like the OP would have to buy a C4 or C5 anyway for his "new"
    machine. If you read the later part of my posting, you´ll see, that I
    strongly suggest getting C5 instead of C4! ;-)
    Not only because of the 32bit vs. 64bit aspect, but other functions and
    features. Anyway, if one takes builds a completely new machine, it´s only
    consequent to equip it with the latest software available. C5 has been out
    for a few months now and is technically advanced, compared to C4.
    In many cases, it´s okay to save some money by getting the latest previous
    version of a software, but in this case definitely not! The step between a
    32bit and 64 bit version is more important, than just deciding if you really
    need a few extra functions or not...
    Phil
  10. jtougas Guest
    Message Count:
    On Sun, 19 Apr 2009 17:44:06 +0200, "Phil W" <> trained 100
    *snippage*
    Agreed. :)
    jtougas
  11. DM Guest
    Message Count:
    > *snippage*
    > Agreed. :)
    > jtougas
    Wow!! Thanks for all the informative inputs Guys!!! I do have Cubase
    Studio 4 and will upgrade soon C5 :D
    I'll stick with my XP Pro32 for now and will wait for Win 7 by the end
    of the year! Thanks again!!
      • Advertising
Share This Page
