OT: Why do I hear nasty audio artifacts in the high frequencies on.mp3 files? (the PHYSICS of it all
Discussion in 'alt.steinberg.cubase' started by XODDI, Jun 21, 2010.
  1. XODDI Guest
    Message Count:
    Mainly on material compressed at 128.
    I do not think that it's just my ears, as other people I know have
    mentioned it.
    A point to a good article would be as good as a detailed explanation.
      • Advertising
  2. Laurence Payne Guest
    Message Count:
    Re: OT: Why do I hear nasty audio artifacts in the high frequencies on .mp3 files? (the PHYSICS of it all)
    On Mon, 21 Jun 2010 13:06:02 -0700 (PDT), XODDI
    >mentioned it.
    Because mp3 is a highly compressed format and, although quality is
    surprisingly good, it isn't THAT good. Use a higher rate or, if you
    want to hear exactly what you recorded, use wav instead of
    compressing to MP3.
    CubaseFAQ page: http://www.laurencepayne.co.uk/CubaseFAQ.htm
  3. XODDI Guest
    Message Count:
    Re: OT: Why do I hear nasty audio artifacts in the high frequencieson .mp3 files? (the PHYSICS of it all)
    > >mentioned it.
    > compressing to MP3.
    Yeah, I do that.
    I was hoping to find out what happens - something like "the lower the
    bitrate, the less able the algorithm is to capture higher frequencies
    accurately because..." (I just made that up, BTW.)
    To me it sounds a lot like what happens when you use a bit reduction
    or waveshaping plug-in.
    Most folks just call it distortion, but inquiring minds got to know.
  4. Bogey Hempton Guest
    Message Count:
    I won't use anything but 320kbps on MP3's. Even those still sound like
    crap compared to the original wav or aif files.
    I don't know what the physics of it are or anything but I wish somebody
    would come up with an improvement over MP3 files.
    My heart just sinks when I finish a song in Cubase with all the
    dynamics on instruments like Omnisphere and Trillium, then you listen
    to the result after you've mastered it with T-Racks and converted it
    down to MP3.
    In article
    XODDI <> wrote:
    > Yeah, I do that.
      • Advertising
Share This Page
