padkontrol vrs nanopad input to Sonar
Discussion in 'cakewalk.audio' started by Dewittian, Jul 31, 2010.
  1. Dewittian Guest
    Message Count:
    Excuse my lack of general knowledge but I've never use MIDI in Sonar
    to play an external (since 1992). I'm thinking of getting a drum pad
    and they look like a better way to assign sounds and input them than
    my guitar synth pickup or my simi-weighted keyboard. Actually I hate
    trying to play drums from a keyboard. I remember the days of the
    first drum machine Roland put out and how happy I was when the RX9
    drum machine came out.
    The padkontrol is a lot more expensive than the nanopad and I don't
    need live I only record 1 track at a time. These pads have their own
    software so I'm wondering if I would have to sync them to Sonar while
    I input the MIDI or if I could put the MIDI data including controllers
    directly into a sonar MIDI track using one of my Kontakt 4 samples?
    Also, since I only have 1 MIDI input on my M-audio interface could I
    use that ACT function in Sonar to record several(say 8) MIDI tracks at
    a time? Though it might be easier to use one Sonars' drum machines
    (though I'd have to learn another software when I'd rather just get it
    set up and play it it real time with quantize input on) instead of
    using VST to Kontakt? I could probably use a Kontakts' drum sample in
    the Sonar environment but I'm not sure if it would work and sound as
    realistic as playing the Kontakt sample in its' player?
    Any help or advice would be appreciated?
      • Advertising
  2. Dave \Mod Bod\ Modisette Guest
    Message Count:
    Neither of these instruments are drum machines. They have no internal
    sounds and inputting drum tracks with them would be no different than
    using a midi keyboard controller except for the gum rubber pads on them.
    Dave "Mod Bod" Modisette
    http://www.gatortraks.com/forum
  3. Dewittian Guest
    Message Count:
    On Jul 31, 5:56 pm, "Dave \"Mod Bod\" Modisette"
    > http://www.gatortraks.com/forumhttp://www.gatortraks.com
    So they use the USB and software to get power and control output that
    is sent through a separate MIDI out?
  4. Dave \Mod Bod\ Modisette Guest
    Message Count:
    Midi out meaning the midi data from the Nanopad to your DAW midi input.
    Some of them are powered by USB. If there is an alternate 9V power
    input, I usually use that to keep from overtaxing my computer's power
    supply.
      • Advertising
  5. Dewittian Guest
    Message Count:
    On Jul 31, 7:58 pm, "Dave \"Mod Bod\" Modisette"
    > >>> using VST to Kontakt?  I could probably use a Kontakts' drum samplein
    > supply.
    Thanks for the tip about power supply.
    I have a teribyte drive for backup. I leave it on always and it shows
    up as a mapped drive in explorer but the settings put it to sleep
    until I click on it in explorer . ( 3 physical drives and the second
    one partitioned I have the programs on the main C drive.
    The second is partitioned with all my samples on 1 partition and
    sonar files on another partition.
    .. It would be a hassle to unplug the USB drive when I'm not using
    it. Do you think that drive might use resources when sleeping?
    The only time I have drop-outs is when I'm mixing and have all the
    vst, reverb EQ etc... So I bounce all tracks to audio tracks picking
    up all the effects to track each track. Then I work from the new
    file.
    The problem is that any more changes to the final mix on audio tracks
    don't get saved to the old file with the MIDI tracks so I can change
    samples. By the time I'm finished my file is significantly changed on
    the new file with on the audio tracks.
    Does anyone know a way to take a audio track and convert it to MIDI?
    That way I can switch samples and bounce to track again and be done.
    Of course i'd have to do it in the file that still runs on MIDI or
    loose the effects when I bounce.
    Does anybody out there have some advice on my creative process?
  6. SoftShell Guest
    Message Count:
    "Dewittian" <> wrote in message
    news:...
    > >> them.
    > supply.
    file.
    Doesn't Sonar retain the original MIDI tracks when bouncing to audio? Been a
    while since I done that so I'm not sure. If so, archive the MIDI, then save
    the file. If not, copy and paste the originals to new tracks, archive the
    new tracks, bounce the originals to audio & then save the file. Either way,
    the original MIDI tracks are still included in your latest file so you can
    always go back and try out different samples or whatever. Hint : If you
    prefer the newer changes archive the older audio, just in case there's
    something there you want to go back to at some later time. Archiving a track
    not only silences it but also removes all useage of resources including
    associated effects. Only drawback is increased file size. Not too much of a
    problem with terabyte+ HDD's.
    _____________________
    Steve Wilson
    --- news://freenews.netfront.net/ - complaints: ---
  7. Dewittian Guest
    Message Count:
    > news:...
    > > >>> use that ACT function in Sonar to record several(say 8) MIDI tracksat
    > > >>> (though I'd have to learn another software when I'd rather just getit
    > > >> them.
    > > supply.
    > file.
    > associated effects. Only drawback is increased file size. Not too much ofa
    >                                              Steve Wilson
    NOW BACK TO DRUM PAD CONTROLS
    Since I haven't had anything since to old Rolad R-8 drum machine and
    it had nice ruber pads that responded well to velocity changes I'm
    looking for the same thing only cheap used and without sounds. I
    heard that the "Nanaopad" is not as good a feel as the Korg
    Padkontrol. Is anyone out there that programs their drums with a pad
    device???
    What other brands or models should I look at since all I want is
    velocity and a good finger to pad feel?
      • Advertising
Share This Page
