Patches, Sound Banks for Triangle II - FREE
Discussion in 'cakewalk.audio' started by Benjamin Goldman, Sep 25, 2010.
  1. Benjamin Goldman Guest
    Message Count:
    Some pretty darn good patches in these banks.
    http://fwd4.me/fy4
    Loading them with the stand alone version is a breeze as one would
    expect. Do it from the Inserted VST in SONAR is another situation all
    together. The one in SONAR only opens it's DEFAULT bank. No others.
    Here's what I do:
    Locate the default bank file and make a safety copy of it. Load
    whatever of the new banks you like into the same folder. Make a copy
    of whatever bank is wanted and rename it as the "default."
    Works like a charms. Well worth using some of those rather than the
    default that comes with the Cakewalk version.
    I like the top three - CapDan, Kered, and Kriminal. The others have
    duplications and some missing names for patches.
    Triangle II is awesome. Reminds me of VA-1.
    Cheers,
    Ben
      • Advertising
  2. Nil Guest
    Message Count:
    On 25 Sep 2010, "Benjamin Goldman" <>
    wrote in cakewalk.audio:
    > http://fwd4.me/fy4
    > all together. The one in SONAR only opens it's DEFAULT bank. No
    > others.
    You can load other banks by clicking on the Triangle II logo, then
    choose Program from the pop-up menu, then Load Bank.
    I like it, too. It's very present and punchy.
    Thanks for the pointer!
  3. Benjamin Goldman Guest
    Message Count:
    > > http://fwd4.me/fy4
    > > others.
    You're welcome and thank YOU.
    Cheers,
    Ben
      • Advertising
Share This Page
