Hii Guys, I am new here and i'm new to keyboards, i wanted to buy a keyboard for a very long time but i couldn't. After a while i decided to buy one. I'm into trance/house/dance music but i listen to all kind of genres. All i want to ask you is what keyboard should i buy to play trance/house/dance on it as a beginner. Please there are so much on the internet Digital Pianos Keyboard Synthesizers Keyboard Workstations MIDI's I don't know the difference and i really want to get one to start playing Thank you
As always, it comes down somewhat to: 1. budget 2. one mad band or part of a band or option for both? The Y-man
I always wonder which currency it is when people ay $xxx (I revert to Australian dollars of course ) Anyway, given that, some sort of small arranger might have to be the go, although you may not get the flexibility you need.... So have a look on youtube etc for demos of Casio CTK-6000 Yamaha PSRE-423 The price range doesn't quite get you into synth territory - you migth also consider a pre-loved Yamaha MM6 The Y-man
I meant us dollars sorry So do you think i need a small arranger to match up my musical needs ? and by knowing the budget is in us dollars does these two are the ones for me ? Keep in consideration that i'm just a beginner i don't know the difference between an arranger and a workstation or any other keyboard Thank you
Wow by looking to the price of the Yamaha MM6 I think i will go with the Yamaha PSRE-423 Thank you so much for helping me Y-man
The PSR 423 is a very good and solid starter-keyboard with a lot of extra gadgets you will not need in the beginning but will appreciate when you a bit further. You can't go wrong with this one! It is also a basic arranger keyboard, meaning you can download midi's (songs) styles (extra rhythms) and voices (like more guitars, organs, saxes, piano's etc etc) from the net and load them (although a bit limited) into the keyboard and it does a lot more. Lot's to learn when you are new to this and also keyboard-users-language might sound 'spaced' but you will soon be comfortable with it. We all started one day and needed help and advice. Happy keyboard hunting! DickR
