Problem in SONAR 7.0.1 after in inserting softynth in old SONAR project
Discussion in 'cakewalk.audio' started by Rick Paul, Oct 30, 2007.
  1. Rick Paul Guest
    Message Count:
    I'm having a strange, and, at least at the moment, showstopping problem with
    one project under SONAR 7.0.1. I believe, from looking at version stamp
    information in the original SONAR project, that that the project I'm trying
    to remix was created in SONAR 3.1.1 (version seems to be 12.1.1.264).
    I can read the project into SONAR 7.0.1 just fine. It plays back if I play
    it at that point.
    Next I try insertin a softsynth, including its track folder, MIDI track, and
    first audio output track. From that point on, I can't get any playback
    unless I delete the softsynth from the rack.
    The softsynth I was initially trying was Spectrasonics Trilogy, as I want
    to upgrade the sounds on the bass part. However, I also tried TTS-1,
    thinking maybe it was specific to Trilogy, and I get the same result.
    Also, I tried saving a version of the file after having done a bunch of
    other troubleshooting, like disabling other plug-ins and tracks, just to try
    and get it down to lowest common denominator, leaving just a track with
    Trilogy in there as active with everything else archived and/or disabled.
    The idea was to try closing and reloading the project or even closing SONAR
    then starting it again and reloading the project, as I have had a few flaky
    cases where that resolves an impasse in getting sound. But when I reloaded
    the project I'd saved, even after rebooting my system, I get a SONAR poof
    (i.e. SONAR disappears with no crash message or Watson dump) consistently
    (or at least the 2 out of 2 times I tried it). And I do have to reboot
    after the poof because SONAR's process is left hanging even if the
    application doesn't show up in the application part of the Windows XP task
    manager.
    Have any other SONAR 7 users seen this? If so, any workarounds you've come
    up with? At the moment I'm dead in the water on trying to do anything on
    this project since it is mainly some softsynth replacement I want to try.
    About the only thing I can think of at the moment (and I haven't tried it
    yet) is seeing if I can use SONAR 5 or 6 to try to at least get past the
    impasse, then hope it will load in SONAR 7 after that. (It's conceivable I
    could do the remixing I want to do in SONAR 6, but definitely not in SONAR 5
    since I also want to use AudioSnap to tweak the timing of multiple audio
    loops to sound more like they were played together.)
    Rick
    Rick Paul
    Closet Cowboy Music (ASCAP)
    Web: www.RickPaul.info
    MySpace: www.myspace.com/rickpaulmusic
      • Advertising
  2. Rick Paul Guest
    Message Count:
    Replying to my own message with a slight update:
    If I go into SONAR 6.2.1 and try to do the same thing, the project still
    plays after the synth insert. If I then save that file, then go back to
    SONAR 7.0.1 to try to work on the file, the file won't play again. There
    definitely seems to be something messed up in this area on the SONAR 7
    front.
    Rick
    Rick Paul
    "Rick Paul" <> wrote in message
    news:...
    > with one project under SONAR 7.0.1. I believe, from looking at version
    > stamp information in the original SONAR project, that that the project I'm
    > trying to remix was created in SONAR 3.1.1 (version seems to be
    > 12.1.1.264).
    > play it at that point.
    > and first audio output track. From that point on, I can't get any
    > playback unless I delete the softsynth from the rack.
    > try and get it down to lowest common denominator, leaving just a track
    > with Trilogy in there as active with everything else archived and/or
    > disabled. The idea was to try closing and reloading the project or even
    > closing SONAR then starting it again and reloading the project, as I have
    > had a few flaky cases where that resolves an impasse in getting sound.
    > But when I reloaded the project I'd saved, even after rebooting my system,
    > I get a SONAR poof (i.e. SONAR disappears with no crash message or Watson
    > dump) consistently (or at least the 2 out of 2 times I tried it). And I
    > do have to reboot after the poof because SONAR's process is left hanging
    > even if the application doesn't show up in the application part of the
    > Windows XP task manager.
    > come up with? At the moment I'm dead in the water on trying to do
    > anything on this project since it is mainly some softsynth replacement I
    > want to try. About the only thing I can think of at the moment (and I
    > haven't tried it yet) is seeing if I can use SONAR 5 or 6 to try to at
    > least get past the impasse, then hope it will load in SONAR 7 after that.
    > (It's conceivable I could do the remixing I want to do in SONAR 6, but
    > definitely not in SONAR 5 since I also want to use AudioSnap to tweak the
    > timing of multiple audio loops to sound more like they were played
    > together.)
    > Rick
    > Rick Paul
  3. Rick Paul Guest
    Message Count:
    And yet another reply to myself with yet another update, and what seems
    to have been a successful workaround, though I could have sworned I'd tried
    something like this already:
    Going back to SONAR 7.0.1, I loaded the project at the state before I wanted
    to insert Trilogy again and inserted it. As before, playback wouldn't work.
    I connected an instance of KOMPAKT in the Synth Rack (it was the first
    softsynth in there, and was being used multitimbrally on two different
    parts, but those parts had been rendered in the pre-Freeze "Bounce to
    Tracks"style, where there was a separate audio track for the rendered
    result, the softsynth audio and MIDI tracks were frozen, and I'd
    disconnected the synth in the rack to free up its memory). I tried again
    playing, and still no go.
    Next I disconnected KOMPAKT and tried again. Still no go.
    Next I disconnected Trilogy. As I'd expected, it would play.
    Now I reconnected Trilogy. This time it would play!!!
    Okay, I didn't know whether it was something with the KOMPAKT interaction or
    what, so I decided to exit the project without saving it and load it again
    from the point before inserting Trilogy the first time. (I didn't shut
    SONAR down in between.)
    I loaded the project, it played as expected.
    I inserted Trilogy. The project still played!!!! No needing to
    disconnect/reconnect KOMPAKT or Trilogy this time!!!
    Obviously something must have gotten funked up in SONAR's internal state
    that the playing around I did in the first project cleared and left cleared
    once it was cleared. VERY strange. But at least now I have been able to
    save the project in a state where it is playing with Trilogy. And I'm
    guessing additional softsynth insertions into that project are likely to be
    okay, too, as I generally don't have problems inserting softsynths, Trilogy
    or otherwise, into SONAR 7 projects.
    Rick
    Rick Paul
    news:...
    > front.
    > Rick
    > Rick Paul
    > news:...
    >> I'm trying to remix was created in SONAR 3.1.1 (version seems to be
    >> 12.1.1.264).
    >> want to upgrade the sounds on the bass part. However, I also tried
    >> TTS-1, thinking maybe it was specific to Trilogy, and I get the same
    >> result.
    >> system, I get a SONAR poof (i.e. SONAR disappears with no crash message
    >> or Watson dump) consistently (or at least the 2 out of 2 times I tried
    >> it). And I do have to reboot after the poof because SONAR's process is
    >> left hanging even if the application doesn't show up in the application
    >> part of the Windows XP task manager.
    >> together.)
    >> Rick
    >> Rick Paul
  4. Max Arwood Guest
    Message Count:
    I had something like that happen too. What I did was open in S5 or S4.
    Ignored the message about the new stuff. Inserted the plugin/softsynth in
    4/5 then went back to 7 and it worked. I wish I could remember which it
    was. I do remember opening in 6 and resaving did no good. I seem to
    remember it was EZDrummer inserted after a Kontakt. And the song had
    originated in an older version of sonar like yours.
    Max Arwood
    news:...
    > tried something like this already:
    > wanted to insert Trilogy again and inserted it. As before, playback
    > wouldn't work.
    > or what, so I decided to exit the project without saving it and load it
    > again from the point before inserting Trilogy the first time. (I didn't
    > shut SONAR down in between.)
    > cleared once it was cleared. VERY strange. But at least now I have been
    > able to save the project in a state where it is playing with Trilogy. And
    > I'm guessing additional softsynth insertions into that project are likely
    > to be okay, too, as I generally don't have problems inserting softsynths,
    > Trilogy or otherwise, into SONAR 7 projects.
    > Rick
    > Rick Paul
    > news:...
    >> front.
    >> Rick
    >> Rick Paul
    >> news:...
    >>> 12.1.1.264).
    >>> result.
    >>> have had a few flaky cases where that resolves an impasse in getting
    >>> sound. But when I reloaded the project I'd saved, even after rebooting
    >>> my system, I get a SONAR poof (i.e. SONAR disappears with no crash
    >>> message or Watson dump) consistently (or at least the 2 out of 2 times I
    >>> tried it). And I do have to reboot after the poof because SONAR's
    >>> process is left hanging even if the application doesn't show up in the
    >>> application part of the Windows XP task manager.
    >>> that. (It's conceivable I could do the remixing I want to do in SONAR 6,
    >>> but definitely not in SONAR 5 since I also want to use AudioSnap to
    >>> tweak the timing of multiple audio loops to sound more like they were
    >>> played together.)
    >>> Rick
    >>> Rick Paul
  5. Max Arwood Guest
    Message Count:
    Oh yea, I'm only posting this one so you'll quite talking to yourself. <g>
    Just kidding.
    Max Arwood
    news:...
    > wouldn't work.
    > Rick
    > Rick Paul
    > news:...
    >> front.
    >> Rick
    >> Rick Paul
    >> news:...
    >>> 12.1.1.264).
    >>> result.
    >>> played together.)
    >>> Rick
    >>> Rick Paul
  6. Steve Karl Guest
    Message Count:
    Open in 7 ... save in 7 close everything ... reopen newly saved version .... try that?
    "Rick Paul" <> wrote in message news:...
    > If I go into SONAR 6.2.1 and try to do the same thing, the project still plays after the synth insert. If I then save that file,
    > then go back to SONAR 7.0.1 to try to work on the file, the file won't play again. There definitely seems to be something messed
    > up in this area on the SONAR 7 front.
    > Rick
    > Rick Paul
    >> I'm having a strange, and, at least at the moment, showstopping problem with one project under SONAR 7.0.1. I believe, from
    >> looking at version stamp information in the original SONAR project, that that the project I'm trying to remix was created in
    >> I can read the project into SONAR 7.0.1 just fine. It plays back if I play it at that point.
    >> Next I try insertin a softsynth, including its track folder, MIDI track, and first audio output track. From that point on, I
    >> can't get any playback unless I delete the softsynth from the rack.
    >> The softsynth I was initially trying was Spectrasonics Trilogy, as I want to upgrade the sounds on the bass part. However, I
    >> also tried TTS-1, thinking maybe it was specific to Trilogy, and I get the same result.
    >> Also, I tried saving a version of the file after having done a bunch of other troubleshooting, like disabling other plug-ins and
    >> tracks, just to try and get it down to lowest common denominator, leaving just a track with Trilogy in there as active with
    >> everything else archived and/or disabled. The idea was to try closing and reloading the project or even closing SONAR then
    >> starting it again and reloading the project, as I have had a few flaky cases where that resolves an impasse in getting sound. But
    >> when I reloaded the project I'd saved, even after rebooting my system, I get a SONAR poof (i.e. SONAR disappears with no crash
    >> message or Watson dump) consistently (or at least the 2 out of 2 times I tried it). And I do have to reboot after the poof
    >> because SONAR's process is left hanging even if the application doesn't show up in the application part of the Windows XP task
    >> manager.
    >> Have any other SONAR 7 users seen this? If so, any workarounds you've come up with? At the moment I'm dead in the water on
    >> trying to do anything on this project since it is mainly some softsynth replacement I want to try. About the only thing I can
    >> think of at the moment (and I haven't tried it yet) is seeing if I can use SONAR 5 or 6 to try to at least get past the impasse,
    >> then hope it will load in SONAR 7 after that. (It's conceivable I could do the remixing I want to do in SONAR 6, but definitely
    >> not in SONAR 5 since I also want to use AudioSnap to tweak the timing of multiple audio loops to sound more like they were played
    >> together.)
    >> Rick
    >> Rick Paul
  7. Rick Paul Guest
    Message Count:
    "Max Arwood" <> wrote in message
    news:yryVi.1515$%...
    Hmmm, I wonder if NI products may be the common denominator. I know I've
    also seen problems in SONAR 6 with getting sound out in some cases with
    KONTAKT (2?). Whatever it was, though, it is definitely very strange.
    Rick
    Rick Paul
  8. Ull Guest
    Message Count:
    On Mon, 29 Oct 2007 23:50:18 -0700, "Rick Paul"
    The only problem I've had with 7 and I'm not 100% sure it's happened
    in 7.0.1 is with things not starting properly. Sometimes I have to
    stop and start again. I don't think I'm working on anything that
    doesn't have at least two instances of Kontakt 2 at the moment.
    I have been using the Chris Hein Warwick Bass library lately with the
    AmpegSVX plugin or my Ibanez with the same plugin. I may start
    something with Trilogy but don't usually leave it. It seems to require
    too much LF taming for me. ( I do love the Acoustics just when playing
    for joy along with some lovely insane break beats. I haven't recorded
    any of that. It's how I unwind and warm up my chops. I guess DnB is a
    guilty pleasure for me. I love it.)
    Ben N. Moore
  9. Sue Morton Guest
    Message Count:
    <rant>This is the type of c**pola I experience with Sonar all the time.
    When I'm working on a project, I don't have the time to do this futzing
    around hoping to make it work (if it even will, sometimes no joy regardless,
    there's a bug)... This is why I'm wanting a replacement to Sonar. Something
    much more stable. Don't know if it exists, I'm still looking... I feel
    your pain guys. This just SHOULD NOT happen.</rant>
    Sue Morton
    > Max Arwood
    > news:...
    >> seems to have been a successful workaround, though I could have sworned
    >> I'd tried something like this already:
    >> wouldn't work.
    >> And I'm guessing additional softsynth insertions into that project are
    >> likely to be okay, too, as I generally don't have problems inserting
    >> softsynths, Trilogy or otherwise, into SONAR 7 projects.
    >> Rick
    >> Rick Paul
    >> news:...
    >>> There definitely seems to be something messed up in this area on the
    >>> SONAR 7 front.
    >>> Rick
    >>> Rick Paul
    >>> news:...
    >>>> 12.1.1.264).
    >>>> track, and first audio output track. From that point on, I can't get
    >>>> result.
    >>>> track with Trilogy in there as active with everything else archived
    >>>> or even closing SONAR then starting it again and reloading the project,
    >>>> getting sound. But when I reloaded the project I'd saved, even after
    >>>> crash message or Watson dump) consistently (or at least the 2 out of 2
    >>>> times I tried it). And I do have to reboot after the poof because
    >>>> in the application part of the Windows XP task manager.
    >>>> I want to try. About the only thing I can think of at the moment (and I
    >>>> 6, but definitely not in SONAR 5 since I also want to use AudioSnap to
    >>>> played together.)
    >>>> Rick
    >>>> Rick Paul
  10. polymod Guest
    Message Count:
    "Sue Morton" <> wrote in message
    news:3KFVi.2605$%...
    regardless,
    Something
    This is what happens when people like us take a zillion ingredients and
    expect the results to tast like Wolfgang Puck made it. <g>
    All kidding aside, computers are flaky. What works on one system crashes
    another. It took me months to resolve a problem that ended up being a bad
    mobo....or whatever you call it.
    Good luck with your soup Sue!
    Poly
  11. Glennbo Guest
    Message Count:
    In news:O4GVi.1582$ the killer robot "polymod"
    <> grabbed the controls of the spaceship
    cakewalk.audio and pressed these buttons...
    No they're not!!! They're crunchy!!! <g>
    Remove YourHeadFromYourAss to Reply by email
    ________ ____
    / ____/ /__ ____ ____ / __ )____
    / / __/ / _ \/ __ \/ __ \/ __ / __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_____/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  12. Sue Morton Guest
    Message Count:
    But that's just it, Poly -- I run an average of 10 midi tracks with simple
    synths like TTS-1, no outboard equipment except for mics and preamps, and
    darn few (if any) plugins, and only the ones that came with Sonar. No
    rewire, no Kompact, Kontakt, etc. Just mix to stereo wav and export. Pretty
    dang simple. You'd think that much could be stable? {sigh}
    Sue Morton
    "polymod" <> wrote in message
    news:O4GVi.1582$...
    > Poly
  13. polymod Guest
    Message Count:
    news:OzHVi.2614$%...
    Pretty
    Wow. I had no idea you were having that much trouble. My sympathy.
    If you have that much instability with so little going on, could it possibly
    be the computer and not Sonar?
    Poly
  14. Rick Paul Guest
    Message Count:
    "Steve Karl" <> wrote in message
    news:RtAVi.8369$%r.1641@trnddc01...
    > .... try that?
    Yeah, I'd mentioned that the first time, I think. That version is the one
    that made SONAR (7.0.1) go poof! :-( In any event, I did ultimately get it
    working through some seemingly random connecting/disconnecting of softsynths
    in the synth rack voodoo. ;-)
    Rick
    Rick Paul
  15. Sue Morton Guest
    Message Count:
    Nope, tried on all different computers... different hardware, all XP Pro
    though. Before and after SP2 and so on. I would just like to sit down and
    WORK, and there's always some nonsense that stops the process... never had
    that problem very often with hardware!!!
    Sue Morton
    news:jbIVi.878$...
    >> simple
    > Pretty
    > possibly
    > Poly
  16. Steve Karl Guest
    Message Count:
    > "Steve Karl" <> wrote in message news:RtAVi.8369$%r.1641@trnddc01...
    > Yeah, I'd mentioned that the first time, I think. That version is the one that made SONAR (7.0.1) go poof! :-( In any event, I
    > did ultimately get it working through some seemingly random connecting/disconnecting of softsynths in the synth rack voodoo. ;-)
    > Rick
    I meant the current version 7.0.1 I was just shorthanding.
    The real thought was that once saving in the V7.0.1 format and reopening ...
    S
    > Rick Paul
  17. Les Cargill Guest
    Message Count:
    Re: Problem in SONAR 7.0.1 after in inserting softynth in old SONARproject
    Mine are all chewy. I must be doing something wrong... too much
    oil, no doubt...
    Les Cargill
  18. Rick Paul Guest
    Message Count:
    news:6mKVi.965$TO4.341@trnddc07...
    > news:...
    >>> .... try that?
    >> one that made SONAR (7.0.1) go poof! :-( In any event, I did ultimately
    >> Rick
    That's what I thought you meant, and that's the thought I was replying to.
    That is, I did try saving in 7.0.1 format and reopening, and that revised
    version of the file is what made SONAR poof. That has helped in some
    scenarios in the past, but not this particular one. Only the synth
    disconnecting/reconnecting "voodoo" (as in "I'm not 100% sure what I did,
    but it worked that time, whereas I thought I'd don't something similar
    before that didn't work") ultimately got it working.
    Rick
    Rick Paul
  19. Glennbo Guest
    Message Count:
    In news:4727adc8$0$11486$ the killer robot Les
    Cargill <> grabbed the controls of the spaceship
    > oil, no doubt...
    Overclock them at 350 degrees for 20-30 minutes, or until golden brown!
    ________ ____
  20. Glennbo Guest
    Message Count:
    In news:4XIVi.17709$ the killer robot
    "Sue Morton" <> grabbed the controls of the
    spaceship cakewalk.audio and pressed these buttons...
    >> possibly be the computer and not Sonar?
    > Pro though. Before and after SP2 and so on. I would just like to sit
    > down and WORK, and there's always some nonsense that stops the
    > process... never had that problem very often with hardware!!!
    Have you tried using different notes? ;)
    We let a guy sit in live with us once who turned out to be a metal head.
    After playing one song with us, and returning to his table at the club, our
    front man says over the PA, "those notes aren't in our music!!!". <G>
    ________ ____
      • Advertising
Share This Page
