- Joined
- Mar 24, 2015
- Messages
- 3
- Reaction score
- 0
Greetings;
Having been an sx70s user for 5 years, I have recently upgraded to the sx90s. Aside from the eye-opening learning curve, I'm having a bizarre problem with the also-newly-obtained FC3 foot controller/pedal.
For the first 3-4 days of use, the pedal was working perfectly - I use it as a sustain pedal; nothing more... but in that role, it was working exactly as expected and hoped.
Only problem is that it was sliding around on me a bit, so last night I picked it up, turned it over, and added some gripper pads. Hooked it back up... all is well... no sliding.
Until today. I sat down to play and found that the pedal was working... kinda backwards. I get sound with my foot off of it. As I press down, the volume gradually goes away. It is exactly as if I was using a volume pedal and not a sustain.
In frustration, I hit the keyboard's factory reset - just in case an unknown parameter had been changed. No luck.
I've checked the General settings, the Controller settings... everything I can think of (and the manual is no help whatsoever). All looks right.
I am out of ideas... anyone else have one?
