problem with video (cubase SX1, winXP)
Discussion in 'alt.steinberg.cubase' started by Hueyduck, Oct 1, 2009.
  1. Hueyduck Guest
    Message Count:
    Hi everyone,
    Any PC cubase user had 3 ways of displaying.
    Hre they are with the probleme I encounter for each of them:
    - video for windows: used to work like a charm on an old PC. Now, on my
    new machine, the first seconds are read correctly and then: black
    screen (inside the VFW windows, that is). Then the video frame stays
    black even if I read agin from the start
    - DirectX: works fine but only the first video on a video track can be
    read. I do'nt like this.
    - Qt: works fine in the window, but the full screen eats like 20% of
    CPU (no harware acceleration seems to be made).
    Bottom line: how can I correctly display the several videos that can be
    on my video tracks, according to you?
    Have you ever experienced these problems?
    Thx for your advice.
    Huey
      • Advertising
  2. Hueyduck Guest
    Message Count:
    Hueyduck a écrit :
    > Hi everyone,
    Just a little hint (maybe): if I move the video part on the video track,
    I am able to read a portion of the video again, and then back to black.
    I'm quite sure there's a setting somewhere for my video card (wich is a
    NVIDIA GeForce 8600GT, btw). For the moment, I'm looking into this
    direction, anyway.
    Huey
  3. Hueyduck Guest
    Message Count:
    Hueyduck a écrit :
    > Hueyduck a écrit :
    >> Hi everyone,
    >> my new machine, the first seconds are read correctly and then: black
    The problem above doesn't occur if I load a RGB version of the video
    file. This is a codec issue .
    I'm getting somewhere. (but talking alone, I'm afraid ;-)
  4. Hueyduck Guest
    Message Count:
    Re: problem with video (cubase SX1, winXP) problem solved
    Hueyduck a écrit :
    > Hueyduck a écrit :
    >> Hueyduck a écrit :
    >>> Hi everyone,
    Ok, i'm a bit ridiculous talking by myself like that, but the info
    could be useful to someone one day:
    this was caused by the codec. I switched to the MJPG codec of ffdshow
    and it works fine in the VideoForWindows version .
    No change in the problem with directX display, though.
    Good night everyone.
    HUey
      • Advertising
  5. Jos Geluk Guest
    Message Count:
    Hueyduck schreef:
    > Hueyduck a écrit :
    >> Hueyduck a écrit :
    >>> Hueyduck a écrit :
    >>>> Hi everyone,
    >>>> black screen (inside the VFW windows, that is). Then the video frame
    >>>> stays black even if I read agin from the start
    Bonsoir Huey. No, I'm following this with interest. I don't use video
    very often, but it mostly works.
    I use the DirectShow video player. As I said, it works, unless it doesn't.
    Jos.
    Ardis Park Music
    www.ardispark.nl
  6. Hueyduck Guest
    Message Count:
    > Jos.
    Jos, could you tell me something, if you are used to the DirectShow display:
    If you put several videos on the same video track (same size, codec,
    bitrate,etc..., could even bve same video repeated), are you able to
    read a video part that is not the first video part of the video track?
    Because ideally, I would use this DS display since it can be "full
    creened" with one click. But this "I only read the first video" bugs me.
    It does that with 2 different PCs, here. All with SX1.
    Huey
  7. Jos Geluk Guest
    Message Count:
    Hueyduck schreef:
    >> doesn't.
    >> Jos.
    > display:
    No, doesn't work. I have never noticed it, perhaps I have never used
    more than one video at a time. The screen freezes at the last frame of
    the first video, and never shows the second one. If you remove the first
    video, the second will play fine. This is Cubase SX2 here (yes, yes,
    planning to upgrade any day now).
    I wonder if they fixed that in later versions. After all, Cubase was
    never intended as a video editing station.
    Jos.
    Ardis Park Music
    www.ardispark.nl
  8. Hueyduck Guest
    Message Count:
    Jos Geluk a écrit :
    > Hueyduck schreef:
    >>> doesn't.
    >>> Jos.
    >> display:
    Thanks for having tested this.
    I think it is more a DirectX issue than a cubase one.
    I have Cubase 5 wich I'm still not using, but it is installed and I will
    test it one day. I'll post the result.
    I do'nt think we can call it video editing :) It's only video
    synchronizing.
    Anyway, as long as one of the three display method works, I'm fine.
    Thx again.
    Huey
      • Advertising
Share This Page
