Question About Intro
Discussion in 'cakewalk.audio' started by Benjamin Goldman, Sep 25, 2010.
  1. Benjamin Goldman Guest
    Message Count:
    Here's another Invention:
    In the beginning their is an ornament played - a mordent. It's a
    quickie and sounds odd to me on one of the patches I used. Sounds to
    me like there's a defect in the file rather than a musical flourish.
    What's it sound like to you?
    Input; ideas?
    http://soundclick.com/share?songid=9685827
    Cheers,
    Ben
      • Advertising
  2. Steve_Karl Guest
    Message Count:
    You mean the quick change from the A to B on the french horn?
    "Benjamin Goldman" <> wrote in message news:-september.org...
    > Input; ideas?
    > Cheers,
    > Ben
  3. Benjamin Goldman Guest
    Message Count:
    > > to me like there's a defect in the file rather than a musical
    > > flourish. What's it sound like to you?
    > > Input; ideas?
    > > -- Cheers,
    > > Ben
    Wow! You're amazing. Yep. It's a quick B-A-B.
    I programmed that horn type sound on the JUNO-106. All my JUNO sounds
    are my own.
    Cheers,
    Ben
  4. Steve_Karl Guest
    Message Count:
    >> > Input; ideas?
    >> > -- Cheers,
    >> > Ben
    > are my own.
    > Cheers,
    > Ben
    I think it sounds odd because it's not working as a slur, like a real horn would play it,
    but working like a more defined note change.
    Try dropping the velocity a bit and dragging the notes to overlap a bit.
    That always works for my orchestra sounds to make them sound more legato.
    S
      • Advertising
  5. Benjamin Goldman Guest
    Message Count:
    > >>> Input; ideas?
    > >>> -- Cheers,
    > >>> Ben
    > > sounds are my own.
    > > -- Cheers,
    > > Ben
    > horn would play it, but working like a more defined note change.
    > bit. That always works for my orchestra sounds to make them sound
    > more legato.
    > S
    I'd just remove the mordent and play it without it. There is no
    velocity sensitivity in a JUNO-106.
    Cheers,
    Ben
  6. Benjamin Goldman Guest
    Message Count:
    > >>> Input; ideas?
    > >>> -- Cheers,
    > >>> Ben
    > > sounds are my own.
    > > -- Cheers,
    > > Ben
    > more legato.
    > S
    Thanks for the input, Steve. I fixed it. Sounds way better now. I'm
    happy with it.
    I love that patch.
    Cheers,
    Ben
  7. dick Guest
    Message Count:
    Pitch Bend! :-D
    dick
    The True Spirit of '08:
    <http://tinyurl.com/2j78qt>
    The Boss Confronting "The American Taliban"®
    <http://tinyurl.com/bt75g8>
    (he's right behind me, isn't he?)
      • Advertising
Share This Page
