Reaper 3.101
Discussion in 'cakewalk.audio' started by Glennbo, Aug 15, 2009.
  1. Glennbo Guest
    Message Count:
    New version is up with lotsa nice tweaks. You can now drag-n-drop from
    one track's I/O button to another track's I/O button to connect sends
    and receives. It auto pops the dialog box where you can do even more
    sophisticated routings when you do this function. I'm just now giving
    it a spin. Here's the download page, and list of what's new.
    http://www.reaper.fm/download.php
    * 3.101: Fixed high CPU use on zoomed-in recording items
    * 3.101: Fixed grid line drawing of 1/3 beats
    * Actions: toggle show master tempo envelope
    * Actions: faster actions to explode audio by channel, much faster actions to explode MIDI by channel or pitch
    * Actions: separate actions to jump to previous/next beat/measure vs moving edit cursor only
    * Actions: fixed occasional disappearing key shortcut
    * Automation: fixed possible crash when deleting FX envelope
    * Automation: shift+ctrl+drag locks envelope point move to either horizontal or vertical (like in MIDI editor)
    * Bounce: display in transport displays bounced length
    * Editing: fixed bug when moving items across hidden tracks
    * GUI: significant CPU optimizations when drawing time selection, antialiased peaks, fades, envelopes, filled envelopes
    * GUI: dim track I/O button when master/parent send disabled (themeable using track_io_dis and mcp_io_dis)
    * GUI: fixed bug in HSV blend mode
    * GUI: fixed edge line drawing for time/loop selections when decoupled
    * GUI: fixed filled envelope clipping bug
    * GUI: separate theme elements for fade quiet zone and fade area color fill
    * JS: updated Liteon FX
    * Media explorer: checkbox for starting media preview on the bar while project is playing back
    * Media explorer: fixed context menu on Vista/Win7
    * Media explorer: show preview graphics for MIDI items
    * Metronome: fixed output selection menu
    * MIDI editor: event filter stays on top, can be toggled on/off
    * MIDI editor: CC lane dropdowns show which message types are currently in use
    * MIDI editor: inserting notes in drum modes uses smaller of grid size or 32nd notes
    * MIDI editor: view preference to always display note velocity
    * MIDI editor: action to move edit cursor to play cursor
    * MIDI editor: action to set selected note lengths to grid size
    * MIDI editor: better paste-extends-source behavior when using unlooped items
    * MIDI editor: no loop end marker for unlooped MIDI items
    * MIDI editor: fixed clipboard leak in certain paste actions
    * MIDI editor: fixed screen redraws/flashes when selecting notes in list view
    * MIDI editor: action to import lyric events from text file
    * MIDI editor: better display of text/sysex event editing vs adding, better copy-drag behavior
    * MIDI editor: clicking empty space in the lane deselects text/sysex events
    * MIDI editor: fixed copy/paste of text/sysex events in list editor
    * MIDI editor: fixed file-based MIDI item text/sysex event undo/redo
    * MIDI editor: fixed memory leak when deleting text/sysex events in list editor
    * MIDI editor: fixed step sequencer note entry when inline editor is open
    * MIDI editor: fixed text event editing on OS X
    * MIDI editor: fixed text event hit testing in certain instances
    * MIDI inline editor: actions dialog can now run actions
    * MIDI: don't create a new MIDI item when punch recording if there is already a suitable item to record into
    * MIDI: fixed overdub recording when extending source and record pdc disabled
    * MIDI: record overdub/replace modes with record PDC disabled now compensated for track PDC
    * OSX: default to Cocoa UI for AU plug-ins that support it
    * OSX: fixed manually editing JS parameter values
    * Peaks/waveforms: recording items are drawn more smoothly and consistently, update faster by default (configurable)
    * Playback: preserve PDC delayed monitoring now compensates for both track and master/parent PDC
    * Project: fixed project template being inserted when opening existing project in new tab
    * Project: setting maximum project length prevents zooming out much past that length
    * ReaEQ: more regular grid lines
    * ReaFIR: more regular grid lines
    * ReaVerb, ReaSamplomatic: now multi-project aware (for save-as with media)
    * ReaSamplomatic: fixed noise bug with zero release time
    * Recording: fixed recording pre-roll sample rounding problem
    * Render: fixed render dialog peaks display when certain stem options set
    * Render: more helpful error message if target directory does not exist
    * Render: saving project to RPP via render dialog now adds project to recent list
    * Render: Shup button sends to user default upload target
    * Screensets: better multiproject track view support
    * Screensets: screenset window now updates on save-project action
    * Shutdown: cancelling save while Windows is shutting down cancels system shutdown
    * Shutdown: more stable sequence with undo history open
    * Solo: fixed glitches when unsoloing with routing and PDC
    * Spaghetti cormorant
    * TCP/Mixer: create sends by dragging IO button to another track
    * TCP/Mixer: alt+click on IO button toggles master/parent send
    * TCP: bulk mute/solo by dragging mute/solo button to another track
    * Tempo envelope: snap points to grid when adding and snapping enabled
    * VST: faster startup scan of plug-ins that have not changed
    * VST: more efficient automation for new envelopes or envelopes with square point shape
    * VST: correct return value for audioMasterAutomate
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
      • Advertising
  2. Sue Morton Guest
    Message Count:
    I downloaded but hadn't installed it yet. Looks very good, I'll give it a
    go tomorrow! Thanks for the heads up.
    Sue Morton
    "Glennbo" <> wrote in message
    news:Xns9C68743115D04BrownShoesDontMakeIt@69.16.185.247...
  3. Glennbo Guest
    Message Count:
    In news:h66tqa$l6s$-september.org the killer robot
    "Sue Morton" <> grabbed the controls of the
    spaceship cakewalk.audio and pressed these buttons...
    > it a go tomorrow! Thanks for the heads up.
    I booted up in Windows 7 and decided to get most of my plugs authorized
    so I could see how the performance is compared to Windows XP. So far, I
    am not impressed, as running my Delta ASIO at 64 samples pops and clicks.
    I turned off the indexing service, and that made no difference. It runs
    fine and makes no pops if I increase the latency, but I'm not into doing
    that.
    The other Win7 things I don't like are that it doesn't remember from one
    boot to the next that I re-tasked the microphone input to be line input
    for the onboard audio. Every time I boot, I have to re-task it again.
    The other thing that bugs me is that Dolby 5.1 decodes on shows that are
    uncompressed Transport Stream HDTV, but don't when I compress to DivX.
    Both those items work fine in XP. It's looking more like my $50 copy of
    Windows 7 will be going on the machine in my bedroom, which is a single
    task computer, doing only Beyond TV as a client. Oh well, if I do
    install it on that machine, I'll also stick a TV tuner card in it, so it
    can utilize the Media Center stuff as well.
    ________ __
  4. Sue Morton Guest
    Message Count:
    So I started to install this just now, and discovered 3.102 is already out!
    Sue Morton
      • Advertising
  5. Glennbo Guest
    Message Count:
    In news:h6767h$ldm$-september.org the killer robot
    > out! --
    They evidently found something, and fixed it. I like the fact that I don't
    have to uninstall, kill some registry entries, etc. I just install right
    over the previous install, and I'm done. Just for fun I fired up Reaper,
    let it tell me there was an update, clicked download, closed Reaper,
    clicked install, and I'm up running 3.102 in 0:42 seconds! Shazam! ;)
    ________ __
  6. Sue Morton Guest
    Message Count:
    Me too, VERY convenient and friendly. Which is good, because they've had,
    what, 5000 updates in just a few months? :)
    Sue Morton
    news:Xns9C68A63FD9200BrownShoesDontMakeIt@69.16.185.250...
  7. Glennbo Guest
    Message Count:
    In news:h67b2b$sv8$ the killer robot "Sue Morton"
    <> grabbed the controls of the spaceship
    > had, what, 5000 updates in just a few months? :)
    > Sue Morton
    Hehe, sump'n like that. ;)
    >> right over the previous install, and I'm done.
    ________ __
  8. malachi Guest
    Message Count:
    snip
    I am using Reaper to do demos which I take to pitch meetings at several
    organizations and which have also been pitched to a couple of major and mid
    level artists. I am absolutely unhesitant to stand the sound quality I get
    from this program against anything else I'm hearing out there.
    As for the writing, well, I'm workin' on it.
    malachi
  9. malachi Guest
    Message Count:
    "malachi" <> wrote in message
    news:h67mbg$8rr$...
    > snip
    > mid level artists. I am absolutely unhesitant to stand the sound quality
    > I get from this program against anything else I'm hearing out there.
    > malachi
    Actually, I'm working on it right here...
    http://www.myspace.com/jtrentes
    malachi
  10. kitekrazy Guest
    Message Count:
    They can't seem to get it right.
  11. Sue Morton Guest
    Message Count:
    LOL!!!!
    Sonar can't either. But at least Reaper is trying :)
    Sue Morton
    "kitekrazy" <> wrote in message
    news:h686b2$utg$-september.org...
  12. Sue Morton Guest
    Message Count:
    I spent a couple of hours last night trying to get a simple five-track MIDI
    to play in Reaper without locking up my machine. I did eventually succeed
    but AFAIK I did nothing differently than I did in every previous attempt.
    So I'm not at all sure why I finally got it to work or what was wrong that
    caused my problems. I don't have the time to spare right now, to explore
    and attempt to find root cause, unfortunately.
    I tried a couple of free 3rd party VSTi synths that support SF2 format: sfz
    free (both the one that comes with Sonar as well as the previous version
    last free one rcg audio offered on their site before they folded) and
    VSTSynthFont (from the fellow that created the exceptional stand-alone
    SynthFont player).
    Same MIDI file and all three VSTi's work and play just fine in Sonar 7. And
    of course the TTS-1 works fine in Sonar too. I have not tried the TTS-1
    again in Reaper. Maybe later.
    My machine locked up fully when using the VSTi's interfaces to change
    parameters, load soundfonts and banks etc. in Reaper. Big red switch time.
    Because I have error reporting enabled for all programs, I would first get
    the pop-up (paraphrased) "Reaper has closed -- send report to Microsoft" and
    as soon as I clicked yes the entire machine was off the air.
    Oh I also tried ReaSynth, even though it is not a soundfont player, it comes
    with Reaper so it should work, right? Nope. I did have less trouble with
    ReaSynth but still had it lock up my machine several times too.
    Machine had been rebooted right before I started this test, so long OS
    uptime was not the issue. This machine is rebooted nightly anyhow. XP Pro
    SP3 32-bit with nearly all hotfixes from m$ update. Core 2 Duo 3ghz
    (E6850's) and 2G DDR3 ram, 1333 memory and FSB. Very stable and fast
    machine overall, and Sonar is very stable, works quite well except for the
    bugs that aren't fixed yet...
    Once I got the MIDI to play, using sfz, I found that many of the controller
    commands are not handled correctly by Reaper. Sonar and sfz handle them
    fine, so it is not sfz. (both versions).
    So while the MIDI implementation in Reaper is definitely making great
    advances, and there are many nice new features in this release, it still has
    some way to go in some very basic handling of MIDI.
    Ping Steve Karl: Any interest in chiming in over on the Reaper forums yet?
    Your input would be very valuable to MIDI development in Reaper, if you've
    got the time... :)
    Sue Morton
    > fill
    > use
    > 32nd notes
    > items
    > view
    > events
    > editor
    > disabled
    > project in new tab
    > that length
    > media)
    > recent list
    > shutdown
    > square point shape
    > ________ __
  13. Glennbo Guest
    Message Count:
    In news:h69bme$uk3$-september.org the killer robot
    > controller commands are not handled correctly by Reaper. Sonar and
    > sfz handle them fine, so it is not sfz. (both versions).
    What controller commands are you referring to? Midi pitch and vibrato
    both work. I don't have a pedal, although my controller has an input.
    > still has some way to go in some very basic handling of MIDI.
    I use SFZ, Vsampler, and even Livesynth Pro in Reaper all the time and
    never have even a hiccup. I even have used the TTS-1 in several projects
    with no problems. The TTS-1 only has the first stereo outs exposed in
    Reaper (rather than all four stereo outs), but that's never been a
    problem for me as I tend to use it for things like horn sections, which
    are ok coming out stereo.
    ________ __
  14. Sue Morton Guest
    Message Count:
    I had trouble with program changes, bank changes, portamento, pedal up/down,
    tempo sweeps. I'm using GM standard commands only. They all work as they
    should in S7 from same midi tracks. I verified using the Event Lists in
    Reaper and in S7 that the midi "appeared" to import correctly, so unless the
    displays are incorrect in Reaper, that was not the issue.
    Sue Morton
    news:Xns9C697F8D9F21ABrownShoesDontMakeIt@69.16.185.250...
  15. Glennbo Guest
    Message Count:
    In news:h69g77$307$-september.org the killer robot
    > up/down, tempo sweeps. I'm using GM standard commands only. They all
    > work as they should in S7 from same midi tracks. I verified using the
    > Event Lists in Reaper and in S7 that the midi "appeared" to import
    > correctly, so unless the displays are incorrect in Reaper, that was
    > not the issue.
    I always use SFZ in a single instrument configuration, so I never send
    it any bank or patch changes, and I don't have a pedal on my keyboard
    controller. I just recorded this using three instances of SFZ, and
    three midi tracks driving one instance of a TTS-1. No program or bank
    changes, just six different instrument parts on six differnet tracks.
    http://www.soundclick.com/bands/page_songInfo.cfm?bandID=403575&songID=7979980
    ________ __
  16. Sue Morton Guest
    Message Count:
    I'd like to see Reaper become very solid and dependable on the GM standard
    first, then see where they take it from there :)
    And I'd like to see Reaper get more solid handling VSTi's and DXi's, all my
    crashes with Reaper are nearly always due to some plug, that works in Sonar
    (was not shipped with Sonar).
    Sue Morton
    news:Xns9C69951AA879DBrownShoesDontMakeIt@69.16.185.247...
    > controller.
  17. Glennbo Guest
    Message Count:
    In news:h69nur$io4$ the killer robot "Sue Morton"
    >> send it any bank or patch changes, and I don't have a pedal on my
    >> keyboard controller.
    > standard first, then see where they take it from there :)
    I used to be more interested in the general midi standard, but these days,
    I use so many single instrument, specialty plugins like the B4 organ, FM7,
    and Superior Drummer 2 that my stuff isn't going to be general midi anyway,
    especially when there are real guitars and basses in the song.
    > all my crashes with Reaper are nearly always due to some plug, that
    > works in Sonar (was not shipped with Sonar).
    I generally avoid DXi's, although there are two or three that I don't have
    the equivalent of in VSTi, so I still use them from time to time.
    ________ __
  18. Sue Morton Guest
    Message Count:
    news:Xns9C699AEC57E45BrownShoesDontMakeIt@69.16.185.247...
    > anyway,
    That's probably true for a lot of folk. Nonetheless, the support is needed
    I think.
    All the crashes last night were with VSTi's, I didn't use a DXi.
    Bottom line. IMO the MIDI aspects are still flakey. Just because some
    people don't run into problems, doesn't make that issue any less valid for
    those that do. The program shouldn't lock up or lock up Windows completely.
    I hope the Reaper developers recognize and agree with that -- and address
    it.
    Sue Morton
  19. BobF Guest
    Message Count:
    >> out! --
    Try that with 37-11 GB of sampler content!!! ;-)
  20. Glennbo Guest
    Message Count:
    In news:h6a0nt$127$-september.org the killer robot BobF
    >>> already out! --
    >> don't have to uninstall, kill some registry entries, etc. I just
    >> install right over the previous install, and I'm done. Just for fun
    >> I fired up Reaper, let it tell me there was an update, clicked
    >> download, closed Reaper, clicked install, and I'm up running 3.102 in
    It don't werks!
    ________ __
      • Advertising
Share This Page
