Recommendation? VST reverb and echo
Discussion in 'alt.steinberg.cubase' started by Supoman, Apr 19, 2005.
  1. Supoman Guest
    Message Count:
    I've switched over to sequencing using Cubase SE from Reason. I was
    really spoiled by how easy it was to add reverb and echo in Reason.
    Does anyone know of
    a plug that makes it equally as easy? I don't mind using rewire I'd
    just rather avoid the processor overhead that comes along with rewire.
    Supoman
      • Advertising
  2. Supoman Guest
    Message Count:
    Nevermind. I found them. Under VST Sends. Now I have to figure out
    how to activate them on the tracks.
  3. Aphelion Guest
    Message Count:
    Load them in the Send bank, they will auto activate, sends are on the
    right hand side on the track mixer, activate the bus, and bring the
    level up on the send. click-hold-drag.
    Ap
  4. Supoman Guest
    Message Count:
    OK. Well maybe this is a dumb question but I was always told the
    dumbest quest was the one you didn't ask. I see a reverb and echo
    under my DIRECTX
    plugins. Can I use them with a VST instrument? When I perfrom the
    steps in the last post I only see the vst effect plugins.
      • Advertising
  5. Supoman Guest
    Message Count:
    OK. I've narrowed my problem down. When I add and audio track I have
    access to the reverb and echo plugins that I add to the vst sends rack.
    But when I add a midi track I don't have access to these. Am I doing
    something wrong. Is there a way to route to these? should I just keep
    my eyes open for a reverb that works with midi & vst instruments?
  6. Supoman Guest
    Message Count:
  7. Laurence Payne Guest
    Message Count:
    Audio tracks take audio effects.
    Midi tracks take midi effects. These are restricted to automated
    versions of things you could do by manually editing a midi track.
    VST instrument tracks are special. They appear twice in the Cubase SX
    mixer. Once as the midi control, once as the audio output. You
    can use both.
    CubaseFAQ www.laurencepayne.co.uk/CubaseFAQ.htm
    "Possibly the world's least impressive web site": George Perfect
  8. Supoman Guest
    Message Count:
    Thanks!..Works like a charm and makes complete sense!!
      • Advertising
Share This Page
